Question about John Deere Garden
John Deere GT-245 PTO clutch not coming off, bolt is off, the lower part of the clutch came off not the rest of it help how do I get the rest off I tried a puller
John Deere GT245 PTO clutch, clutch not coming off
  • John Deere Master
  • 7,515 Answers
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Posted on May 17, 2017
I have a john deere STX38 riding mower, the cutting blades will not turn on when I pull the PTO switch, I have replaced the PTO clutch and switch.
Make sure that the wire going to the clutch is securely in place and making connection. Also, there may be a wire coming from that connection that goes directly to a bolt that secures the engine to the mower. This is a ground wire.
Nov 12, 2017 | John Deere Garden
How to remove and replace pto clutch on John Deere x300 mower
Unplug the wires to the clutch, the wires plug in on the right side. Remove the bolt retaining the clutch, 5/8 socket. You might need to take 2 pry bars, one on each side of the clutch on the top side to work it loose.
Jul 30, 2017 | John Deere Garden
Wiring diagram for LX172 John Deere
Type into google john deere riding mower wiring diagram for pto switch clutch circuit then click images
May 12, 2016 | John Deere Garden
How do I remove the electric pto on my John Deere 245 garden tractor
Best Manuals
Sep 19, 2015 | John Deere Garden
How do you remove the center bolt on the pto clutch
The easiest way to remove one is an impact wrench; otherwise, you would block the flywheel of the engine so it won't turn and use a pull bar.
You will need block the flywheel upon installing as you will need to torque the center bolt to about 55 ft lbs and don't forget to burnish in the PTO clutch.
Jul 30, 2014 | John Deere Garden
John deere stx 30 pto wont engage
Check your fuse or for a broken wire( or shorted)
Jul 19, 2014 | John Deere Pto Clutch For Stx38 And Stx46...
Why wont john deere stx 30 pto wont engage
Most of these mowers have a safety switch between the PTO switch and clutch. A safety switch or relay is most likely the problem. Hope this will help ya.
I have a john deere stx38, has no spark. Engine turns over fine but will not fire. JW
Check the HT lead for cuts or breaks and then replace it anyway then check the on/of switch for rest
Jul 09, 2010 | John Deere Pto Clutch For Stx38 And Stx46...
John deere 997 z trak pto not working,changed pto switch not help
You may have a defective park brake switch or the pto clutch could need to be adjusted.Does the machine **** down when you try to engage the pto?If so also check the seat switch.To adjust the pto clutch you need a 9/16' wrench and tur all three lock nuts on the clutch a half turn at a time a retry the clutch,keep going until it will stay engaged.
Nov 08, 2009 | Garden
Garden Logo
119 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
