Question about In Office Equipment & Supplies
How do i load 11x14 oaper in WF7620 - In Office Equipment & Supplies
Why is my Epson WF7620 showing" cassette 1 insert correctly"
The switch inside that makesxeither an electrical connection orca mechanical one tells the printer that the paper tray is home loaded and awaiting commands is not being activated by the tray
The switch has become faulty overtime and needs,a replacement
The bit on the tray that pushes the tray loaded switch has broken off the tray is missing the switch or a wiring fault has developed
And the switch has no power so it still can't see the tray even if it is loaded thus error paper tray missing continuously is being displayed
Jul 04, 2016 | Epson WorkForce WF-7620 Wireless Color...
Hi i'm looking for a main board schematic for an epson wf7620 main board
The main board will not have any place on it to tap for use by extra device. Tap into the power supply leading to the board.
May 18, 2015 | Epson WorkForce WF-7620 Wireless Color...
Epson workforce wf7620 error code 0x9D
I have a WF-2650 and the printer is displaying error code 0x9D. Does anyone know how to fix it?
Mar 04, 2015 | Epson Office Equipment & Supplies
Printing 11x14 photos
First use a photo processing programme (like say Photoshop or PS Elements - or if you have not got that (can be expensive) get the free Faststone Image Viewer and size the image to twice the paper size you want, then use the crop tool to select half the image and save that as a file with a name where you can find it again. Do the same with the other half. You will now have two files, each half of the paper size. As they will have small borders, print and trim the borders, so you can then mount side by side to achieve what you want. I would advise to NOT try and print without borders - that can introduce other problems - just accept having to trim the small borders from normal printing.
Apr 09, 2014 | Epson Stylus NX230 Small-in-One USB...
How do you fax a document that is 11 by 14 inches?
Most fax machines and printers will scan and fax an 11x14 document. Just check your owners manual to see if any settings need to be changed AND contact the person you are faxing to let them know to put 11x14 paper in their machine, or some of the print may be lost if the fax will be printed on two 8x11 sheets.
If you don't have your owners manual, post a question and include the manufacturer and model number of your fax machine or printer and one of us will look it up for you.
Feb 10, 2010 | Office Equipment & Supplies
I want to use 11x14 paper on my dj1280 but it is not in the menu. neither is there a provision for user-defined paper sizes. what to do?
The 1280 isn't compatible with 11x14 paper. You can either use legal size (8.5x14) or ledger size (11x17), but you can't customize it to use 11x14.
The best solution would be to print onto 11x17 paper and then cut it to 11x14.
Jan 14, 2010 | HP DeskJet 1280 InkJet Printer
Cannot print 11x14 paper on my Canon Pro9000 printer.
The printing software you are using should have that size for you, I use photo gallery, after you select the image the pop-ups should be your printing software with the paper size choices.
Sep 10, 2009 | Canon PIXMA Pro9000 Photo Printer
When printing back side of paper, paper turns sideways and tears in half.
see that u r feeding the oaper straight. Try to feed the paper manually instead from automatic feed. Also remove the curl of the paper form the top end by hand before feeding
Aug 11, 2009 | Canon imageCLASS D680 Laser Printer
How can you print on 11 x 14 paper borderless with a canon 9000?
sir just read the manual if your printer is capable of printing 11X14 borderless.
thanks
alecz
Apr 23, 2008 | Office Equipment & Supplies
35 people viewed this question
Top In Office Equipment & Supplies Experts
Jason
rugby prop
Are you an In Office Equipment and Supply Expert? Answer questions, earn points and help others
