Question about HP Garden
Have 22 hp Tecumseh with 60 psi.compression. is that to low
  • 1388 Answers
SOURCE: Drops compressiom from 120-60 psi after 3 new pressure switches
When the pressure switch fails the comperssor will overpressure to the point of safety release at about 150 - 160 psi. It sounds as if your compressor is not producing enough pressure to cycle off at 120 and just keeps running. This happens when air is leaking from fittings or worn cylinder / reed valves. Don't worry, with some simple tests we will find the actual problem. I am assuming that your compressor is oilfree type. If there are leaks the compressor may not reach set pressure. I use soapy water on all connections and on the head/headvalve (remove plastic covers to get to all parts that may leak) while compressor is running. Make repairs as necessary. If still low pressure, while compressor is running and has reached max obtainable pressure (in your case 60 lbs), carefully place finger over intake port hole (remove filter). If the compressor is pumping normally but leaking there will be ample suction at intake and cause the compressor to speed-up when intake is obstructed with finger. If you feel plenty of suction and no visible (soapy water) leaks, then the problem is probably the cylinder /ring is not correctly seating /scratched and air is leaking past cylinder. Make sure that the cylinder /piston ring is properly aligned and that the lip on the vinyl ring is up toward the head. On oilfree compressors you can examine the cylinder by pushing the piston all the way up, then look for scratches neer top of cylinder. If scratched, pressure is leaking past cylinder, install cylinder kit. If you do not feel suction but rather air blowing out of the intake, (do this test when tank has reached 60 psi) then the problem is the headvalve plate/reed valves are leaking. The reeds must seal perfectly on their seats and not be bent or have obstruction. Replace as necessary. If reeds or headgasket is leaking the discharge air will be very hot. Only one other thing to check and that is the intank check valve. Easy to check. Run compressor till you have about 50+ lbs in the tank then unplug compressor. Carefully loosen the inlet hose at checkvalve and listen for air leaking out of tank. (check valve is the brass valve at tank) If leaking replace checkvalve. Use caution when removing head to try and save the gaskets. If you have oil type pump, and no air leaks (soapy water test) suspect reed valves/valve plate. Good luck on your repair and email if you have other question.
Posted on May 09, 2009
SOURCE: bostitch cap2040-of will not compress over 60 psi
just had the same problem with the cap2040 .. fixed with about 5 cents of wd40.
previous post was on the right track. theres a stuck pressure relief valve.
1. find the 1/4 inch black plastic hose running from one side of the compressor to the switch box unit and guages.
2. follow this plastic hose to where it meets the pressure relief valve and enters the switch box.
3. the pressure relief valve is a small black plastic unit with a little ring of copper at the point where the plastic hose enters the valve. the valve will be somewhat loose if you tug on the hose you may notice the valve shift 1 mil or two.
4. the valve is held in by a C-clip from the backside. to remove the valve look for a small plastic tab with a hole in the top of it. this tab is the C-clip. it'll be directly behind the valve. and in a very tight spot. using small needle nose plyers or a small screw driver, pry the C-clip UP and out. the valve will come right out.
5. to disconnect the plastic hose from the valve, press the brass fitting with a screwdriver or the like and pull the hose out of the valve. it's a typical pressure fitting if you're used to those.
6. spray some WD into the valve and reconnect it to the hose by pushing the hose into the valve, it'll lock itself in place.
7. turn on your compressor and listen/watch/feel for the air coming out of the backside of the valve. you should see a small brass pin at the end of the valve. when operating properly, this copper pin should stick out about 3mm. at this point, the pin is probably stuck inside. you mission is to free the pin.
8. work this little brass pin with a small screwdriver - gently and from both sides. separate valve from hose again if needed. it's spring loaded and will eventually work loose. run some air through it to clear out the WD. repeat with WD until the pin is freed and sticking out about 2-3mm.
9. before reassembly, cut off about 1/4 inch off the end of the plastic hose, this will ensure you get a good solid connection with the valve. there's enough hose so you can lose up to an inch before having issues.
10. reassemble in reverse. the hardest part will be putting the C-clip back in. took me 2 tries and about a minute with small needle nose.
good luck..
little late on this post .. but maybe it'll still help you or someone.
Posted on Dec 30, 2009
  • 2702 Answers
SOURCE: have 60 lbs compression is this low , poulan chain saw mod p3314
60psi hmmmmm??? it wont even start up on that?? yes it is very low
most engines run on about 120 to 180psi and the 120psi end being low! how did you test this presher??? you need a good true screw in gage and a very strong swing to build the presher up a push in gage is usless and a soft pull wont build the presher up,,,it dont realy matter how big the engine is or how many cc's it is it still needs to get to 120psi to start and run well,,,,me thinks you may need a set of piston rings fitted to this engine just to run it up,
Posted on Jun 29, 2010
  • 3 Answers
SOURCE: makita concrete saw dpc7321 won't start has fuel
I'm a retired engineer and work PT as a tool tech for an HD rental ctr.
Compression on a new cylinder/piston is 160 psi. When it drops into the 130~140 psi range the saw becomes hard to start. Below 130 the saw will not run properly and at 90 they are toast. This is mainly due to improper fuel/oil mix (must be one bottle of 50:1 synthetic oil per gallon of regular gas. I use 6 bottles to 5 gallons for addition protection). Because this type of tool works in extremely harsh conditions (concrete dust) it is also imperative to keep the air filters clean. Wash the foam pre-filter after each use with plain water from a garden hose and discard after operating 6 times. Toss away (change with new) the paper filter if dust is present or when changing the pre-filter. Also check the carb hose to the cylinder inlet for cracks. My cost to get a cylinder/piston from Makita runs app. $130. When looking into the cylinder, streaks on the exhaust side indicate improper fuel/oil mix. Streaks on the intake indicate dirty air intrusion.
Good Luck.
Posted on Nov 30, 2010
  • 1388 Answers
SOURCE: my craftsman air compressor #919176820 2 HP 12 gallon 200 max psi will not compress over 125 psi
If your compressor is oil-less type, most likely pressure is leaking past piston ring. To verify, remove cover to expose bottom of cylinder (unplug compressor and let out all air). With flashlight, examine the upper-most part of the cylinder (turn motor by hand till piston is at top of stroke). If top of cylinder is scratched, then pressure is leaking past.
For many years now, stores are in a race to have more HP and PSI to attract customers. Customer is really the loser because components used to make the units can not handle the higher pressure. Normally small 115v compressors are set to cut out at 125psi and larger two stage units will cut out at 160psi. Small compressor set to 200psi makes for short lived compressor. Could be compared to driving your car at 100mph all day every day. Longest life is attained when unit is being used at about 60 to 75 % of capacity.
To allow your compressor to reach cutout pressure and keep working for a while, lower cutout to 120psi (pressure switch may be adjustable). To restore to 200psi, replace cylinder/ ring.
If your compressor is oil type, suspect leaking reed valves.
Posted on Nov 28, 2011
4.5 hp 4 cycle Tecumseh new carb, sprays gas out carb and floods plug. Very little feel compredsoon
check float in carb probably stuck or sticking causing needle valve to stay open
May 02, 2017 | HP Garden
What should the PSI read on a compression test for a 5 HP Tecumseh engine?
This check is difficult because of the internal compression release that most small engines are equipped with.
This link helps to better understand what to expect.
COMPRESSION TEST on 4 Cycle Engine with Automatic Decompressor
Hope this helps?
Jan 17, 2016 | Tecumseh 5hp Engine Snow King Mtd Blowers...
What should the psi be on a compression test for a 5 HP Tecumseh engine??
Anything lower than 90 psi should be a concern. 110 or so should be good
What is the the compression lbs for 18 hp intek brigg and stratton engine
you should see at least 60 psi but 90 is better... do to the compression release mechanism if the engine cranks slow you might not see anything above 60...
Aug 18, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
When I check the compression on my 26 hp briggs and Stratton I get 90 psi on one and 120 psi on the other. is this ok or do I need work. I lose power on mower deck start up and thicker grass and up hill
no it is not ok. The low side will have a problem as they should be 120psi. It could be a head gasket but most probably will be incorrect valve adjustment hold a valve slightly open
Aug 17, 2013 | Briggs & Stratton Briggs Stratton Intek V...
I have a 99 sienna and the cylinders have low pressure what can i do?
If cylinder compression is too low, the car may not even start because of it. Have a shop do a compression test or a leak-down test to check the internal health of your engine. A good engine should have pressures of 150-200 psi in all cylinders and be close to each other. A worn or high mileage engine may have pressure as low as, say 125 psi, but if still balanced (close readings), would still run decent. Compression below that, especially below 100 psi, is serious trouble. ignition spark refuses to ignite the air/fuel mixture and you get a misfire-a non-working cylinder. Low compression can be caused by worn piiston rings or poor valve sealing. Low compression in 1 or 2 cylinders can be a valve problem, burned valves or valves not seating properly.
A leak-down test will check each cylinder and if there is a problem, the test will find the cause of the problem.
Dec 11, 2012 | 1999 Toyota Sienna
Tecumseh low compression
if its low but has some remove the head and check the head gasket and valves
Jul 31, 2012 | Garden
Low side pressure specs for 2003 silverado2500hd
Ambient Air Temperature
Relative Humidity
Service Port Pressure
Maximum Left Center Discharge Air Temperature
Low Side
High Side
13-16°C (55-65°F)
150-246 kPa (22-36 psi)
730-1190 kPa (106-173 psi)
12°C (54°F)
19-24°C (66-75°F)
Below 40%
150-280 kPa (22-41 psi)
900-1390 kPa (131-202 psi)
14°C (57°F)
Above 40%
179-137 kPa (26-46 psi)
990-1500 kPa (144-218 psi)
16°C (61°F)
25-29°C (76-85°F)
Below 35%
218-328 kPa (32-48 psi)
1240-1640 kPa (180-238 psi)
17°C (63°F)
236-342 kPa (34-50 psi)
1290-1680 kPa (187-244 psi)
18°C (64°F)
Above 60%
250-365 kPa (36-53 psi)
1340-1760 kPa (194-255 psi)
20°C (68°F)
30-35°C (86-95°F)
Below 30%
266-386 kPa (39-56 psi)
1500-1940 kPa (218-282 psi)
21°C (70°F)
280-397 kPa (41-58 psi)
1540-1990 kPa (224-289 psi)
22°C (72°F)
Above 50%
300-430 kPa (44-62 psi)
1600-2070 kPa (232-300 psi)
24°C (75°F)
36-41°C (96-105°F)
Below 20%
328-439 kPa (48-64 psi)
1810-2240 kPa (263-325 psi)
25°C (77°F)
337-457 kPa (49-66 psi)
1840-2290 kPa (267-332 psi)
26°C (79°F)
Above 40%
355-474 kPa (52-69 psi)
1890-2340 kPa (274-340 psi)
27°C (81°F)
42-46°C (106-115°F)
Below 20%
391-491 kPa (57-71 psi)
2130-2500 kPa (309-363 psi)
29°C (84°F)
Above 20%
397-508 kPa (58-74 psi)
2160-2550 kPa (313-370 psi)
30°C (86°F)
47-49°C (116-120°F)
Below 30%
451-552 kPa (65-80 psi)
2420-2790 kPa (351-405 psi)
33°C (92°F)
Jul 10, 2011 | 2003 Chevrolet Silverado 2500HD
Garden Logo
Top HP Garden Experts
Dennis Key
Dennis Key
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a HP Garden Expert? Answer questions, earn points and help others
