Question about Lands Phones
How to fix msg on phone check tel line - Lands Phones
2 Suggested Answers
  • 6771 Answers
SOURCE: brother fax p275
Remove the backup battery and unplug the fax machine and leave overnight. By morning I'am hoping it will wipe everything clean when plugged back in along with the battery. But it will mean you will have to set your date and time again.
Posted on Mar 08, 2012
In normal condition phone continuously ringing what do
There could have been a short or ground in the telephone line (Tip and Ring). Please check the connection of the Tel line cord in the junction box. If your Tel line consist of 3 wires, disconnect all three wires, lift the handset, connect only 2 wires going to Exch Line or Trunk line (Local Tel Company) until you hear the dial tone. Leave the other wire disconnected.
This helped me isolate the problem, I hope this applies to you.
Best regards.
Sep 02, 2015 | Lands Phones
All phones are plugged in and operating but i get a busy signal on all in talk mode
I assumed when you say all phones are operating means there's power and are charging.
1. There could be some phones that are loading the Tel line. Disconnect all phones and plug it one by one while checking the dial tone. If all phones gives busy tone, there coulb be a problem in the Trunk line or the Tel Company line.
2. There could be a short or resistance in the line. Check the connection in junction box between your house and the Tel Company cable.
3. If you have an analog Tel set, you can check the dial tone directly from Tel Company cable that comes in to your house.
I hope this helps.
Best Regards.
Sep 01, 2015 | Panasonic KX-TGEA20 Additional Digital...
Landline displays screen message Check Tel Line. Can't phone out or receive calls. Lights on the black box are out. I checked outlets, etc. E mail is weiner_@live.ca, land line 250-590-5196. Thank
I had to reboot our Shaw box three times last night before the phone started working again. Not sure what triggered the "check tel line" in the first place. My husband had just finished a phone call, I was going to make one right after him. The msg appeared as soon as he hung up. Interesting about your having a Uniden phone; it's the same brand as ours. This is the second time in a year that we've run into this problem. As for your old phone, is it analog? Reason I ask is, our rotary analog phone will work when the digital one doesn't.
Jan 05, 2013 | Lands Phones
Check tel line error msg
Have you checked for dial tone on the line? It sounds like you have a problem with the inside wiring to the phone jack. To test your dial tone out call you number and use a screwdriver and stick it inside the phone jack on the wall, if you have dial tone to the jack you will hear the "short" that you are putting on the line.
Oct 16, 2012 | Uniden DECT 6.0 Cordless Phone ID
Brother fax p275
Mar 07, 2012 | Brother Office Equipment & Supplies
How do you send a tel contact by SMS to another contact on the milestone
when you click on the contact, there will be an option "share contact", it will put contacts tel number in new text msg
Jan 21, 2011 | Motorola Mobility MILESTONE Cell Phone
"check tel line" message?
have you paid you bill? Seriously ring your provider and get them to check your line out.
Feb 12, 2010 | Lands Phones
What is wrong when the phone says Check tel line?
The telephone cord may not be connected correctly.
  1. Unplug both ends of the cord connecting the wall jack to the telephone base.
  2. Insert one end of the cord to the TEL LINE jack on the base.
  3. Make sure that the cord is inserted correctly in the TEL LINE jack on the phone.
  4. When you insert the cord you should hear a click.
  5. Insert the other end of the cord to the wall jack.
  6. Make sure cord is inserted correctly.
  7. You should hear a click.
Feb 02, 2010 | Uniden DECT 6.0 Cordless Phone ID
Message reads: "Check tel line"
You can remove your telephone line from the base unit and fix it to stranded telephone unit and hear the dial tone.If it heard then some inductor or else part may be broken inside the base unit due high current surge.If the dial tone didn't heard from the other phone also check for the corroded line cord or modular box fault with the tel line.There should be 30 Volt-50Volt D.C.Voltage at your wire ends.
Rana.rishanranatunga@gmail.com
May 18, 2009 | Panasonic KX-TG1033S Cordless Phone
Seems to be a key mapping problem
I have a pretty good guess.... someone may have intercomed her phone from another station and then pressed the MSG key. This would leave an intercom message and should light up the message waiting light. Then when you press the MSG button you are returning the intercom call. If nobody ever answers the intercom call the return message will not be completed and it will continue to try and return the call whenever you press the button. SO... if this is the case you just need to have someone answer the other phone that is being called and it should start working the way you are used to again.
Oct 23, 2007 | Inter-Tel Axxess Corded Phone
Lands Phones Logo
29 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
