Tv say no signal, what do we do now - Televison & Video
How do I get a signal from my Jack OA8200 digital tv antenna.
The signal meter should show you available TV transmitters. If you have received a signal at this location before and you definitely are sure it is powered up the antenna is defective. Check for anything that appears loose or broken. If the meter indicates a signal check the cable that goes to the TV.
Oct 28, 2014 | Jack OA-8000 Digital TV Antenna
No signal on my bush 320GB satellite HD digital tv recorder
i have a signal while watching TV
But when i try to record it states no signal
Dec 03, 2012 | Televison & Video
Is this model, RCCA 20f512t, a digital model?
No,This tv is a CRT tv-(Tv Tube).All small tvs with CRTS design are analoge tvs.Tv must have a Converter box to convert for analoge tv to DTV signals to recieve for free broadcasting DTV tv stations signal.Must have pay signals like satalite Dishes,Cables or Telecoms signals.This tv can be use without a Converter box.
Jul 02, 2011 | RCA 20F512T 20" TV
Our toshiba rezga 47lz196 colour is off. There doesn't seem to be any red. All the skin tones are green. Blue shows up but all the other primary's are green. We have green, blue, yellowish, black and...
There are only two possibilities for this problems for this tv.One: the tv incomming broadcasting signal cable wire that is plugging into ur tv Tuner signal board could be bad.U can test this out the incomming broadcasting signal cable wire is good or bad pretty easily by just plug it into another tv to find out the incomming signal cable wire is bad or good.Two: If the tv incomming broadcasting signal cable wire is good by plug it into a another tv.Than ur tv the tv Tuner signal board is the causes and the problems.The tv Tuner signal board CPU chip is bad.U can do some mechanical work like take things aparts and putting it back together again?Yes.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Apr 27, 2011 | Toshiba 47LZ196 47 in. HDTV LCD Television
Trouble adjusting the color.. NO reds and can't seem to dial them in. Thanks, Chris
Recheck ur tv incomming broadcasting signal cable wire like hook it up to another tv,see if another tv is getting the red color,if not the incomming signal wire is the problems.If it the tv problems,than the tv Tuner signal board is dying,require changing the tv Tuner signal board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Apr 17, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
I have hooked up cable to the RF connector but it will not show a picture. I also tried an anntenna and it does not pick up a picture either. All I get is snow. However, I had a VCR/DVD combo connected and...
This tv is analog tv,will not get today free air tv broadcasting signal.Today free air tv signal are all digital free air broadcasting tv signal now.Anolog tv must have a pay cables tv or satalites tv signals to get a picture on analog tv set.U want analog tv to get the free air digital tv broscasting signal.The analog tv,must have it broadcasting tv signal must go through a box call a Converter box to able to produced a Digital free air broadcasting signal for analog tv to get a digital broadcasting tv signal.
Nov 07, 2010 | RCA F27442 27" TV
TV saying no signal
The TV will flash this "No Signal" when it does not see a live signal at the selected input of your TV.
It sounds like the signal at the TV's input is not good to the TV, or the main board in the TV is having a problem and processing the signals correctly.
Try selecting a different woring device connected to the TV's input like HDMI1, Component1, or ..... to see if other inputs are working on the TV.
Good Luck.
Jun 27, 2010 | LG 42LH200C LCD TV
No signal and theres signal
sounds like you need a new tuner replaced or the ssb(small signal board) inspected. The tuner recieves the cable signal and converts it into an intermidiate signal which in turn the ssb processes into audio and video signal.
Sep 09, 2009 | Sony Grand WEGA KF60DX100 60" Rear...
Is my tv digital?
It is not a matter if your TV is compatible with a digital signal, it is the signal being offered to the TV.
Meaning, if you are using Cable TV, you are fine and need no further action because the digital signals are already converted by the Cable Box into either an analog TV (RF) signal, or a PBR (RGB or Comp.Video) signal which the TV understands via a separate input (external video input).
Feb 14, 2009 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
