Question about Impact Computers & Internet
Impact of corruption and unethical behavior - Impact Computers & Internet
What's Tactical Social Marketing? Is Not Social Marketing About Behavioral Change?
Social marketing is definitely an approach that's accustomed to address proper (upstream), in addition to operational (downstream) issues. Social entrepreneurs typically concentrate their efforts downstream on individual behavior change. But, frequently, until norms are moved and also the preferred behavior is viewed as acceptable as well as desirable, the alterations searched for may have a limited impact.
Nov 04, 2015 | Computers & Internet
I would like access to my boyfriends facebook, because I know he is doing things that are not appropriate Is it possible without the password
Hacking is illegal and unethical. We do not give assistance to those who are attempting it, regardless of reason. If your boyfriend's "inappropriate" behavior is illegal, recommend you report this to authorities. If by "inappropriate", you mean he is not being faithful to you, then hacking only makes you a criminal. If he is doing those things, just move on.
Was Hillary Rodham, staff atty. for US House Judiciary Committee fired for lying and unethical behavior?
This has been a persistent but unconfirmed story around her conduct during the Watergate hearings. There is no confirmation, or other evidence that it is true. She did change jobs after the hearings but that was normal.
Mar 07, 2015 | Cars & Trucks
Electrolux/Simpson Dishwasher appears to have corrupt processor program - Is there a way to reflash the micro?
No. You would need to replace the board, though I've never seen this happen unless PCB is covered in cockroaches.
What is it doing? you may have a different problem causing the erratic behavior
May 14, 2014 | Electrolux Washing Machines
Entrapment by fellow employee for reason of dismisal
That is just unethical. I believe every organization whether small, medium or large has a Policy in place to mitigate such behavior.
Nov 28, 2013 | Baby Gear
Memory card not work in my cell
either your memory card is corrupted, damaged or not formatted, OR the memory card you bought is not compatible with your phone! be more specific. Tell us why it isn't working or what behavior it does! but hope this helps and gives you a hint
Jun 20, 2009 | Nokia 6280 Cellular Phone
Hp pavilion dv2000 notebook will not boot up
hi,
i m in Hong Kong. The stupid HP repair center charged US 90 just for inspection!!!!! They they said the whole motherboard had to be replaced, thts additional US 630 dollars, the thing is just 1.5 yr old. They also said i don get to keep the broken mother board after replacement. This is simply irresponsible, unethical, sleazy and UNJUST!!
Thanks. right now the computer is fixed for US70. when i hv time, i'll open it up and see if i can figure it out how it was fixed. The shop suggested tht the computer wont last too long. This is such bad quality for HP... Sorry, i hv to do the following for other victims to find this easily:
(can some creative netizen bring this to the public light to pressure HP to do the ethical things??)
bad quality HP. hong kong HP pavilion dv2000 series manufacture problem. HP unethical.
Sep 21, 2008 | Computers & Internet
My hp computer shuts down unexpectedly
The most common reason behind this type of behavior is a failing hard drive. When a Hard drive is failing it causes corruption in the filing system used by your operating system. if this is the case, its is recommended that you backup all your data as soon as possible.
Though this is the most common reason, by no means is this the only reason. It could be caused by the following:
  • Corrupt Operating System
  • Bad RAM
  • Bad Power Supply
  • Case Short
These are just a few of a possibilities. You will have to be a little more specific as to its behavior before and/or after your unit unexpectedly turns off.
Sep 16, 2008 | Computers & Internet
Computers & Internet Logo
23 people viewed this question
Top Impact Computers & Internet Experts
Andrew Taylor
Andrew Taylor
JonSnell Electronic
JonSnell Electronic
Are you an Impact Computer and Internet Expert? Answer questions, earn points and help others
