Question about Cell Phones
Terramax gattaca can't set it - Cell Phones
How to Make the Matrix Raining Codes by Using Only Notepad?
thats easy..
open notepad then copy and paste the following text
@echo off
color 0a
cls
:a
set /a a=%random%
if %a% geq 16384 set /a aa=1
if %a% lss 16384 set /a aa=0
set /a b=%random%
if %b% geq 16384 set /a bb=1
if %b% lss 16384 set /a bb=0
set /a c=%random%
if %c% geq 16384 set /a cc=1
if %c% lss 16384 set /a cc=0
set /a d=%random%
if %d% geq 16384 set /a dd=1
if %d% lss 16384 set /a dd=0
set /a e=%random%
if %e% geq 16384 set /a ee=1
if %e% lss 16384 set /a ee=0
set /a f=%random%
if %f% geq 16384 set /a ff=1
if %f% lss 16384 set /a ff=0
set /a g=%random%
if %g% geq 16384 set /a gg=1
if %g% lss 16384 set /a gg=0
set /a h=%random%
if %h% geq 16384 set /a hh=1
if %h% lss 16384 set /a hh=0
set /a i=%random%
if %i% geq 16384 set /a ii=1
if %i% lss 16384 set /a ii=0
set /a j=%random%
if %j% geq 16384 set /a jj=1
if %j% lss 16384 set /a jj=0
set /a k=%random%
if %k% geq 16384 set /a kk=1
if %k% lss 16384 set /a kk=0
set /a l=%random%
if %l% geq 16384 set /a ll=1
if %l% lss 16384 set /a ll=0
set /a m=%random%
if %m% geq 16384 set /a mm=1
if %m% lss 16384 set /a mm=0
set /a n=%random%
if %n% geq 16384 set /a nn=1
if %n% lss 16384 set /a nn=0
set /a o=%random%
if %o% geq 16384 set /a oo=1
if %o% lss 16384 set /a oo=0
set /a p=%random%
if %p% geq 16384 set /a pp=1
if %p% lss 16384 set /a pp=0
set /a q=%random%
if %q% geq 16384 set /a qq=1
if %q% lss 16384 set /a qq=0
set /a r=%random%
if %r% geq 16384 set /a rr=1
if %r% lss 16384 set /a rr=0
set /a s=%random%
if %s% geq 16384 set /a ss=1
if %s% lss 16384 set /a ss=0
set /a t=%random%
if %t% geq 16384 set /a tt=1
if %t% lss 16384 set /a tt=0
set /a u=%random%
if %u% geq 16384 set /a uu=1
if %u% lss 16384 set /a uu=0
set /a v=%random%
if %v% geq 16384 set /a vv=1
if %v% lss 16384 set /a vv=0
set /a w=%random%
if %w% geq 16384 set /a ww=1
if %w% lss 16384 set /a ww=0
set /a x=%random%
if %x% geq 16384 set /a xx=1
if %x% lss 16384 set /a xx=0
set /a y=%random%
if %y% geq 16384 set /a yy=1
if %y% lss 16384 set /a yy=0
set /a z=%random%
if %z% geq 16384 set /a zz=1
if %z% lss 16384 set /a zz=0
echo %aa% %bb% %cc% %dd% %ee% %ff% %gg% %hh% %ii% %jj% %kk% %ll% %mm% %nn% %oo% %pp% %qq% %rr% %ss% %tt% %uu% %vv% %ww% %xx% %yy% %zz%
goto a
Dont copy this line or anything below it.
once the text is pasted into notepad. click file then Save As...
where is says Save as type: click the drop down and select All Files
the save Type the File name: as Matrix.bat
or you could just google how to make a Matrix bat file.. LOL
Oct 20, 2016 | Microsoft Computers & Internet
Ps3 was owned by someone else and they put a block for mature games how do you get the block off
Unless you know the password they used you would need to completely re-initialize the unit as it was a new one, from the beginning, to wipe it out completely and set it back to factory defaults (sledge-hammer reset).
There is no way I know of to retrieve this lost password if you do not also know the owner's PSN information, which I'm sure you cannot get to. You might Google the question.
Feb 14, 2015 | Sony Playstation 3 (PS3) Console
I have a sonic terramax watch and everything work except the arms for time do not move. Anyone have an answer for me
This watch have two batteries. When you open tha back you'll see a big battery mounted on the printed circuit board (PCB). If you unscrew the screws from PCB and take it out, you'll find under it the mechanism with the battery from the analog watch. Replace that battery and "Have a good time"... :-)
Aug 10, 2012 | Watches
Can not change time zone on sharper image model lm521 projection clock
I got to liking the Sharper Image LM521 Digital Clock so much that I finally took the time to figure out how to manually set it-it was that or toss it! The instructions are as follows:
NOTE!!!
AFTER installing fresh batteries, or removing and reinstalling the batteries:
Successively pressing the "SET" button results in steps 1.) to 11.) below, each of which describes the particular/specific LM521 clock function you you can manually set.
HOWEVER, pressing the "SET" button after the clock had been previous set and running, will start the manual clock settings from step "2.)," "SET Offset Hours..." To start from step 1.), remove and reinstall the batteries.
PROGRAM/MANUAL SETTING MODE
After inserting the batteries:
The whole LCD screen lights up showing the different settings, etc.
After several seconds, the LCD screen clears and displays:
A flashing antenna
Upper left hand side of the LCD display. USA Time Zone Map
Middle right side of the LCD display (if necessary, to see, remove and reinsert batteries).
WAIT FOR AUTO TIME SET
A flashing antenna
> This indicates the clock is trying to auto set the time according to the WWVB radio/satellite time signal. Set on windowsill for best chance of success.
If it can't detect the signal, mannual setting is required, starting with the time zone.
> Manually set time ONLY if you are absolutely certain the WWVB signal cannot be found. Otherwise any manual time setting will be auto set to the WWVB time when its signal is detected, which may be many hours later.
SET USA Time Zone
1.) Press "SET" -- US time zone
> press "MODE" repeatedly until the desired time zone is reached.
5 = Eastern standard time (default setting)
6 = Central standard time
7 = Mountain standard time
8 = Pacific standard time
9 = Alaskan standard time
SET Offset Hours to Compensate for Satellite Signal
2.) After step 1.) above, press "SET"
A flashing "-7h" (minus 7 hours, default) and flashing USA Time Zone map appear.
This default setting worked just fine in New Mexico, MST, and may also work for your time zone as well.
> Press "MODE" to set from "-0" to "-12h" (minus 0 to 12 hours).
> Set to "-0h" if the satellite time signal set your clock to the correct time for the US time zone you live in.
> Set from "-1h" to "-12" to offset the time set by the satellite signal in case it does not match the time in your time zone. (E.g., 3pm -1h = 2pm.)
> NOTE: The default setting is -7h. If the satellite signal resets the time, say to 9pm, the time displayed will be 2pm (9pm-7h)--but if it should display 5pm instead to match your time zone, then set offset to -4h. Hence, the need to correctly set the offset hours if the -7h default value does not work for you.
SET Daylight Savings Time (DST)
3.) Press "SET" -- DST (Daylight Savings Time)
> Press "MODE" to set ON/OFF
SET Time
4.) Press "SET" (5no = seconds)
"5no" displays, plus flashing bars for seconds (not minutes as it falsely seems).
> Press "MODE" to set from 0 to 60 seconds
5.) Press "SET" (set hours)
> hour bars flash > press "MODE" to set hours
6.) Press "SET" (set minutes)
> minute bars flash > press "MODE" to set minutes
SET Date
7.) Press "SET"
> press "MODE" set year
8.) Press "SET"
> press "MODE" set month
9.) Press "SET"
> press "MODE" set day
SET Week Day
10.) Press "SET"
> press "MODE" set week day, Mom through Sun (Mo is default)
SET Standard (12) / Military (24) Time
11.) Press "SET"
> Press "MODE" set 12/24
CEILING DISPLAY:
SET/ROTATE Ceiling Projected Time/Temp Position
12.) Repeatedly press button with four tiny arrows pointing opposite each other (rightside of "DSPL" button) until the Time/Temperature display on the ceiling is oriented how you want it.
SET Ceiling Projection Brightness, or turn off
13.) Pressing button with sun symbol (leftside of "DSPL" button) cycles ceiling display from off, to brightness levels 1, 2, and 3.
SELECT between Ceiling Projected Time, Temp or Both
14.) Pressing "DISPL" repeatedly cycles between M0 (time), M1 (temperature), M2 (time & temperature auto switch every second or so).
Jan 23, 2012 | Audio Players & Recorders
MY asus pc continues to not wake up. I have to
POWER OPTION
control panel---->power options--->change plan setting--->
Turn off the display-never
Put the computer to sleep-never
control panel---->power options--->change plan setting--->advanced power setting
-set hard disk "turn off hard disk after" to never
-set Sleep "Sleep after" to never
-set hybrid sleep setting to off
-set hibernate after setting to never
Restart pc
POWER OPTION
-set display to never
Restart pc
Jul 15, 2010 | ASUS Eee PC 900 Notebook
Screen goes blank after a few minutes
POWER OPTION
Restart pc
POWER OPTION
Restart pc
Jul 14, 2010 | Dell Inspiron 1318 Notebook
Think pad t42 monitor keeps turning off. I tried changing power settings to never ... did not help still doing the same thing anything else I can do? thanks
POWER OPTION
Restart pc
POWER OPTION
Restart pc
Jul 02, 2010 | IBM ThinkPad T42 Notebook
I want to find out how to set up our Canon CFX0-L4000 fax Machine
CANON CFX-L4000 UNOFFICIAL MANUAL
RIGHT KEYPAD
FUNCTION
SET
01 DATA REGISTRATION
02 DELAYED TRANSMISSION
03 POLLING
04 MEMORY REFERENCE
09 REPORT
11 UP
13 +
14 LEFT
15 SPACE
16 RIGHT
18 CLEAR
19 DOWN
Keys 1-20 are speed dial keys. If speed dial is not set, message is displayed and manually entering the telephone number is prompted. Press STOP to clear.
Pressing FUNCTION accesses the menus associated with keys 1, 2, 3, and 4. After accessing a menu, the cursor keys, SET, and occasionally the telephone key pad are used for selecting options and setting values.
EG. Setting a speed dial number:
FUNCTION - DATA (01) - SET - SET - UP/DOWN to select speed dial number - SET - UP/DOWN to set number/name - SET - UP/DOWN/LEFT/RIGHT/PHONE KEYPAD to enter value - SET
EG. Setting unit telephone number
FUNCTION - DATA (01) - DOWN once - SET - DOWN once - SET - PHONE KEYPAD to enter number - SET
EG. Retransmit from memory (assumes memory light is on)
FUNCTION - MEM (04) - DOWN once - SET - UP/DOWN to select document number (LEFT/RIGHT to view associated telephone number) - SET
EG. Delayed transmission
place document into feed - FUNCTION - TX (02) - SET - PHONE KEYPAD to enter time to send - SET - PHONE KEYPAD to enter phone number - SET - SET - document is scanned and will be transmitted at set time
for full guide you will have to search and purchase one.
May 28, 2009 | Canon Office Equipment & Supplies
My playstation will not read dvd's and just recently stopped reading games. I'm just wondering how to reset the entire system
  1. From the XMB™ home menu, go to icn_settings.gif(Settings) > icn_syssettings.gif(System Settings) > [Restore Default Settings].
  2. Once you select [Restore Default Settings], you will see a list of settings that will be restored. Scroll through them and press the icn_btnx_color.gifbutton to restore the settings.
  3. After the operation is complete, you will see the initial setup screen that appeared the first time you turned on the PLAYSTATION 3.
    You will need to go through the initial setup process before you can use the PLAYSTATION 3.
IMPORTANT
The Restore Default Settings feature will erase any previously saved settings and restore all of the following settings to the default:
  • BD/DVD Settings
  • Music Settings
  • Chat Settings
  • System Settings
  • Date and Time Settings
  • Accessory Settings
  • Display Settings
  • Sound Settings
  • Security Settings
  • Network Settings
  • Internet Browser Settings
Read this next paragraph carefully!!!!!!
Also, do not confuse "Restore Default Settings" with the "Restore PS3 System" option (the next option down on the menu). The "Restore PS3 System" will not only restore the default settings, but it will also delete all hard disk content. (You will lose all saved content from your PS3 system's hard drive if you use "Restore PS3 System.)
Apr 21, 2009 | Sony Playstation 3 (PS3) Console
Cell Phones Logo
54 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
