Red flashing light on the panel. what does this mean
A boat with a flashing red light at night what does it mean
The only requirement for a sea going vessel to use a light that is flashing red at all is for a wind in ground craft. (a pontoon enabled aircraft) that is flying close to, landing on or taking off from water.
Nov 06, 2016 | Televison & Video
How to fix your gas furnice
most gas furneses have a red light on circuit board wich is located on intake. turn heater off then have someone turn it back on while you watch the circuit board. count the # of times the red light flashes before it pauses. it will flash in a cycle. for instance it flashe 3 times then pauses for 5 secounds then flashes 3 times again on and on. look on the back of the panel cover,their will be a diagram, in the diagram their will be dianostic report that will include what that # of flashing red light and what it means. for examle 3 flashing red lights ps stuck open. that means pressure switch stuck open. replace the part and your back up and running.
on Dec 18, 2009 | Heating & Cooling
Red light keeps flashing on 50e47-170 how do I fix
The red flash is flashing in a pattern, should be a diagram on the furnace panel that shows trouble shooting codes.... led on means you at least have power...
Feb 20, 2015 | Home Security
What does black screen with red light flashing mean?
The red flashing light is showing a fault code,watch the light and count how many flashes between pauses,then google your tv model number and the number of flashes to find the possible cause of the problem..
Oct 14, 2014 | Televison & Video
Panasonic viera 42" UT50Z What do 3 red flashes on standby light mean for trobleshooting
Three flashes of standby light denotes a fault to SOS D-board. If you wish to get more details about this fault, check the link sited below. Blinking codes many brand TVs are given in detail. Pull up older posts there by its left sidebar.
Jun 16, 2013 | Televison & Video
Set won't turn on, 10 red flashing lights
This is an error code and depending on brand/model number can have a number of meanings---
You can GOOGLE the model number with "error codes" etc to get an idea of what likely your error code means.
Mar 19, 2012 | Televison & Video
Probable lamp failure, lamp won't turn on leading to red light to come on. How many times does it flash? 3 means safety switch bad, 5 flashes means lamp or lamp ballast failing.
Sep 30, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
Bottom left lights. when i turn on tv red light flashes what does mean
bottom left lights. when i turn on tv red light flashes what does mean
Jan 02, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
Red light and 2 green lights on front panel on.
This is an error code it means the TV is in protection mode. Which means it has detected a problem and is preventing power up so not to cause further damage. Error codes are generally 2 numbers 1 seq of flashes a pause and a second sequence of flashes. Most common problems for LCD are Video logic / Main input board or the power supply. For more info and possible solutions post your make and model.
For parts and info check.
or E-bay
Oct 20, 2009 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
