Question about Sharp Televison & Video
My sharp tv runs normal for the first 2 to 5 minutes then it turns off automatically... then unplug for a few minutes then turn on again, runs normal then shut donw for a few minutes...
    Sergeant:
  • 187 Answers
A good tech can find out what is wrong with the set. The power supply has a protection mode which causes the shutdown. Also, there is a memory chip that a Sharp repair center can connect to and read out the fault history. A shop that talks about replacing a board is not a good place to go to. You need a shop that can isolate the malfunctioning parts and replace the part at the circuit level, not at the board level.
Try this site for a repair shop near you:
http://www.tvrepairpros.com/
Pls rate my suggestion.........
Posted on Jul 25, 2009
Testimonial: "karthik316 thank you so much sir. your tips were so helpful..i have fixed my sharp tv. God less. Call me Chad"
My Sharp LE820 Aquos LED TV recently auto turn itself off, when I turn it back on, a few good 10 minutes or so later it automatic turn itself off again.
Please check that the sleep timer did not somehow get set. If it's not the sleep timer, check if the panel stays ON longer after it's been off for awhile to cool down. Possibly a heat problem with the power supply or main board.
Jan 15, 2015 | Sharp AQUOS 52in. LE820 LED LCD HDTV
I have rear projection tv sharp 55u-wp7h. Unable to turn on tv due to view timer automatic turn on. what cause that and how to fix the problem?
I'm having same issue with same TV. It powers off after about an hour and red power light starts flashing. Only way to power back on is by unplugging TV and waiting a while, then plugging it back in, but then the TV will turn off again after a few more minutes, red light flashing again. I've checked the sleep timer and it is turned off, so any other solutions to this problem? All capacitors on power board look fine (not blown). I've read it could be solder joints in power board need to be resoldered.
Dec 17, 2010 | Sharp 55R-WP4H 55" Rear Projection...
The TV will shut off after a few minutes and then cannot be turned back on until you unplug and replug it. Then it will shut off again after a few minutes. How can I fix that? How much would a repair...
it sounds to me that there is a bad capacitor or perhaps a cold solder joint somewhere in the power section of your tv. not sure how much repair would cost, but i will say it's about $50 to have an service tech come out and lok at it.
Aug 08, 2010 | Sharp 27J-S100 TV
THE HEATER RUNS FOR 2-3 MINUTES AND AUTOMATICALLY
Thermal safety is tripping, clean it out , no repairs viable for theses units,
May 23, 2010 | Honeywell HZ365 Ceramic Compact Heater
Plasma TV turns off by itself-won't sty on for
when i turn my 32 inch VIVIO plasma tv on it turns pff by itself. i want to know why this is happening
Dec 07, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Hard to get started when powering up to watch.
definitely, something wrong with it. TV shouldn't take more then a few seconds to start, I suggest, while it still under warranty, give Sharp a call to get it fixed.
Nov 27, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
My Samsung hcn4226w won't stay on.
There are many protective circuits inside the set that will shut it down if a problem is detected. It sounds like there are intermittant detections of problems and the "restart" temporarily clears the problem. If the unit is no longer under warranty, open up the back with the set unplugged and try reseating all of the boards and connectors. The trip may have jared a few things loose. Update this with the results.
Thanks,
Dan
Aug 20, 2009 | Samsung HCN4226W 42" Rear Projection...
New Sharp Aquos LC37X20E. After 30 mins turns itself off to standby and comes back on after 2-5mins (even though the automatic return to stanby has been set to "disable"). Eventually after...
According to Sharp it is a software problem. Engineer came, installed software update ,10 minute job.....TV worked fine for 1/2 day unfortunately: Then images turned black and white in all channels TV turned itself off, and stanby and OPC buttons started flashing. When TV came back on its own 10 mins later , screen had 2 large square staines superimposed in image (as if it was a burnt screen)...Engineer will be back next week...all quite sad really for a new TV.....will keep u posted
Jul 03, 2008 | Sharp Televison & Video
TV turns of automatically
could be noumerous things: 1. check power supply, too high or too low voultage may cause TV to shut down. measure it to detarmine if power supply is faulty. 2. check convergence board. If either of these 2 fuses on the convergence panel are open then replace the STK output devices PLUS check for any resistors in that circuit that may have overheated and changed value. Use actual fuse values, putting in a larger fuse, even to try and diagnose problem, will cause more severe damage. 3. Check for bad solder connects on the PC board in the area of the power cord and related components. good luck
Mar 26, 2006 | Sharp 27C-240 27" TV
Televison & Video Logo
119 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
