Question about Air Purifiers
Where can I get two ionizing wires for my Professional Plust Ionic Breeze Quadra?
  • 12 Answers
SOURCE: Ionice breeze quadra Model # S1637
had the same problem with ionic pro ca500. i took the unit apart and found a fuse that was blown and it works now. sorry but i don't know if there is any repair shops.
Posted on Aug 03, 2008
SOURCE: Ionic Breeze - Press Blue - Press Geen button
The blue means the germicidal lamp is operating. Re: green light - Normal operation at all power levels involves a pre-programmed cycle of altering high and low air movement. Press the the green to override the regular power control setting and run the unit at maximum power for five minutes. Your previously selected power level will resume after the five minutes has elapsed.
Posted on Dec 12, 2008
SOURCE: ionic breeze quadra
If you are talking about the 2 thin wires inside the unit, it can be fixed if you are good with taking things apart. You have to do an almost complete tear-down of all the internal components (many hidden screws). You can replace the broken wire with a .009 or .008 gauge E string for an electric guitar. This can be found at a local musical instrument store. The string must be cut to almost the exact length. The wire has a spring tension mount on a small circuit board. If the replacement wire is too long, there will be too much slack, too short and you will not be able to put it back together. I did this and it took me hours. I removed about 80 screws to disassemble it.
Posted on Dec 16, 2008
  • 6 Answers
SOURCE: Ionic Breeze Quadra won't turn on
Okay, after working on my Ionic Breeze Quadra I have fixed it. My problem was it wouldn't turn on even though the fins were clean.
1. Unplug
2. Turn the machine upside down (there are 4 screws holding the bottom stand on) remove the screws
3. once bottom is off there are 2 screws sideways helping the hold the 2 sides together. Remove those 2 screws.
4. Turn the machine uprgiht and remove the middle fins (the ones you clean)
5. Remove the 4 screws that are deep in the 4 holes when you look down inside (you can't see the screws, I had to feel for them with a phillips head narrow screwdriver)
(it will be easier if your screwdriver has magnetic head for next step.)
6. after removing the 4 screws gently work lose the top (part that has the little lights and turn on push switch)
7. turn the breeze on its side, you will find about 5 or 6 tiny screws holding the two sides of the outside louver case together. Remove all these screws. You will be thankful for the magnetic end, I have small fingers and still had a problem catching the little screws.
8. You don't want to remove both sides, just one side is fine.
9. Being careful of the wires (I left that side alone) I worked from the wire free side and using a bottle of rubbing alcohal and lots and lots of q-tips I gentle cleaned off all the gunk on all the little metal pieces at the bottom of the breeze (on the inside where the wires are). Clean as good as you can, you will find the metal pieces covered with what looks like tar but it comes off with the alcohal.
10. Using a can of 'canned air' like you'd use for a computer, gently blow the rest of the breeze parts getting all the dust away but being careful not to damage the electronics. (there are a lot of little computer boards). I didn't find any dust in the electrical parts in the very bottom of the breeze, just above where the fins are and some at the top where the controls are.
11. I cleaned the 1/2 I took completely off with some rubbing alcohal, gets that **** off pretty good but didn't mess with the side with the wires, just blew the dust out, gently cleaned a bit and on the outside.
12. To put back together, first I gently put the outer middle pieces together and then gently put the control top back on and replaced those 4 screws. Then I put the 10 or 12 tiny screws back into the middle, then the 2 screws in the bottom sides and 4 screws putting the stand back on. I stood it up, plugged it in (make sure its dry) and turned it on and the light came on and it is working great.
I've had mine for 3 years so I think they occasionally need a thorough cleaning. Except for the canned air I bought nothing else. Everyone has rubbing alcohal and q-tips in their homes. When I first started I didn't know how to dismantle it and tried to clean the inside with long q-tips but it was too hard. Those little metal pieces in the bottom make some sort of connection to the fins we pull out and clean so I guess they need good contact.
I hope I've helped all of you with the problem of the Ionic Breeze Quadra and I suspect any other iconic breeze type machine by sharper image pretty much comes apart the same way and may have the same problems. I don't know how to post this so that everyone can see it as a general solution. Maybe you guys at FixYa can help with that. --- Harry Potter Without the Wand (and a female to boot!)
Posted on Mar 08, 2009
  • 6 Answers
SOURCE: my ionic breeze quadra GP silent air purifier has no power: stopped working!
1. Unplug
8. You want to take off the screws from both sides but only remove one side.
Tip
Sharper Imaage Ionizers
Ionized air purification systems have been proven to be ineffective for cleaning the air. These reports have been published by Consumer Reports as well as the EPA. Sharper Image filed a lawsuit against Consumer Reports and lost. They were ordered to pay Consumer Reports legal bills as well.
Sharper Image issued a recall on all Ionic Breeze Ionizers and filed for Chapter 11 at the same time.
Ionizers have been proven to create an ozone that is harmful to anyone with breathing problems.
Here is a link to the EPA report
Here is an article from CNN.com about The Sharp Image
Support for Ionic Breeze isn't possible since Shaper Image has recalled the product.
Your best bet to keep the air clean in your house is to use a hepa filtration system.
on Jul 12, 2008 | Sharper Image Professional Plus Ionic...
I believe that the motor on my Ionic Breeze unit is broken. Can I replace it??
Ionic breeze units don't have motors. I thought they just moved the air by ionization.
The unit might need to be cleaned. Check you owners manual or the manufacturer for instructions.
Dec 09, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
Broken "wire/filament' in ionic breeze quadra
This does NOT work. The electric guitar wires burn out in 1-2 months.
Jul 13, 2009 | Sharper Image Professional Plus Ionic...
How to get replacement parts for Sharper Image ionizer?
one of the electrodes broke off the botto of one of my towers.
Dec 26, 2008 | Sharper Image Professional Plus Ionic...
Ionic breeze
There isn't one. The reason why Sharper Image went out of business is because the Ionic Breeze was proven to be ineffective product and harmful to use in some cases based on Consumer Reports data as well as data from the EPA. They sued Consumer Reports, lost the case, and had to pay all the legal bills.
The Consumer Products Safety Commission is going to making decision on all ionizers by the end of the year. It's quite possible that no one will be selling them anymore.
There is thread I left in the Ionic Breeze section about the EPA data on ionizers and the harmful effects of using them as well as a link about what happen to Sharper Image.
This product should have been regulated a long time ago. Orek and few others are going to be pulling the plug on them real soon.
Aug 27, 2008 | Sharper Image Professional Plus Ionic...
Ionic Breeze Quadra GP
Aug 14, 2008 | Sharper Image Professional Plus Ionic...
Professional Series Ionic Breeze Tabletop
Jul 29, 2008 | Sharper Image Professional Plus Ionic...
Ionic Breeze Silent Air Purifier GP
Ionic Breeze products are no longer being supported because Sharper Image has gone into bankruptcy because the units were proven to be ineffective for cleaning the air by Consumer Reports magazine and by EPA studies. In face they have proven that ionizers can be harmful to use if you have breathing problems.
Here is an article about Sharper Image
Here is the EPA article
Jun 30, 2008 | Sharper Image Professional Plus Ionic...
My ionic breeze, quatro, quit working, no power. Can you suggest repair. Note, not an outlet problem andy
May 04, 2008 | Sharper Image Professional Plus Ionic...
Air Purifiers Logo
125 people viewed this question
Top Air Purifiers Experts
Are you an Air Purifier Expert? Answer questions, earn points and help others
