Question about Furniture
How to replace the battery in wine enthusiast cork remover?
4 Suggested Answers
  • 905 Answers
SOURCE: Wine Enthusiast 16-bottle thermoelectric wine refrigerator DEAD
usually bad power supply, if the cooling fan isn't running either. These are horribly inefficient coolers that use a lot of power to accomplish little cooling. The power supplies are quite notorious to burn up.
If your supply is 12vdc output, you might be able to replace it with a supply from radio shack. dont use a battery charger though.
Posted on Nov 02, 2009
jim9550
  • 6 Answers
SOURCE: how can I replace a pig tail on a bottle opener
Nobody sells a replacement, unless you are using the very expensive screw pulls. They do have replacement parts.
Posted on Nov 05, 2014
laughton5983
  • 2166 Answers
SOURCE: My question was not answered. The cork which was removed from the wine bottle is stuck in the Rabbit electric wine opener. The device is fully charged. There are no switches.
Remove the foil cutter then get a tooth pick and push it into the small hole beside the charge port twice to reverse the corkscrew to eject the cork
Posted on Jan 09, 2017
Oster electric wine opener wont pull out corks. Half of the cork, or part gets stuck up in the unit. Has always worked fine up until day before yesterday. Is is shot? Or cork puller not sharp anymore?
You need to replace the battery pack, pull it out and see what type of cells are used, then build a new battery pack, did this on my own opener and wow it really rocks, lots of power.
Dec 31, 2016 | Oster Refrigerators
Cork stuck in sharper image wine opener
The black plastic ring is secured on the clear tube that you can see the corkscrew through with four little plastic snap tabs. I used a pair of channel locks to gently pull the ring off those tabs. Once you do that you have access to the inside of the clear tube and can reverse the corkscrew and get your broken cork out. Blow debris out and reassemble. Good as new! Even if you break one tab it should still hold, and if you break multiples use some super glue to hold it in place, that will be your last chance to fix it, but at least you've doubled the life of your toy. Good luck!
Aug 05, 2014 | Home
How can I replace a pig tail on a bottle opener
The following seems to work, but might be tough if you don't drink the wine first. http://www.youtube.com/watch?v=5Y82j3R7tXw
Jul 02, 2014 | Home
Won't pull cork out
Battery may be soft. N/G
If it goes in with No Problem and will not pull out
May 21, 2014 | Waring Pro WO50 Cordless Wine Opener
The cork is stuck in the wine opener when I was trying to release the cork after the wine was opened
I used a long tweezers -- about 1 ft long. I held the cork in place, then pressed the reversed button. It came right out.
Feb 22, 2014 | Brookstone Automatic Wine Opener
Do you have any helpful hints on how to cork a bottle of wine properly?
The most important secret to corking a bottle of wine is to make sure that the corkscrew enters the cork at a straight angle. If it doesn't, it becomes easier for the cork to chip and thereby decreasing the value of your wine.
Jan 10, 2013 | Home
Waring wine opener wont pull out cork
We learned that NONE of these electric wine openers like the new "plastic" corks. Take a needle nosed plyers and hold the cork tightly(as it sits inside the housing) and gently push the button to release the cork. it should work.
Apr 14, 2012 | Sunbeam Kitchen Appliances - Others
Nov 02, 2009 | Refrigerators
Furniture Logo
157 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Furniture Expert? Answer questions, earn points and help others
