Question about Refrigerators
Which side of the cool plus button makes it colder. Cool or - (minus)
  • 1314 Answers
SOURCE: fridge side not cold, freezer cool
yes replace the control box damper assembly as some of the early ones did not work well if i had your serial number could be more specific but don't rate me till were done. also do you hear the evaporator fan running when you open the door
Posted on Jan 11, 2008
SOURCE: 2003 Maytag Plus Dual Cool Side by Side
Check to see if the bacl of the fridge is iced over, if it is the fridge is not defrosting, 99% of the time it is the defrost control circuit board located in the upper right hand corner of the fridge.
Posted on Jun 12, 2008
Technopro
  • 243 Answers
SOURCE: what does the plus/minus button on the chevy malibu shifter do?
I suppose its a sports mode function where the + enables you to upshift and the - to downshift.
Try using this mode when you are driving as you might like it if you used to drive manual cars before...
Cheers
Posted on Feb 02, 2009
kentguidry
  • 51 Answers
SOURCE: Fan not working. Turbo cool reads error
Verify you have voltage at your fan. If you have voltage and the fan is not running then it will need to be replaced.
Posted on Feb 17, 2009
  • 131 Answers
SOURCE: What is the plus and minus button on the left side
it might have a feature known as auto stickwhere you can control the up and downshifts by moving the shifter they usually wont shift through the gears at a stand still as you have to start in first but form there yopu should be able to control when 2nd 3rd and 4th kick like a manual with no clutch hope this helps
Posted on Feb 27, 2010
Temperature settings 1, 2, 3, 4, 5 means
refrigerator dial settings work from hot + 5 degrees (5) to real cold (1) 0 degrees and in the freezer section they work in the opposite direction (1) is cool - is minus 5 degrees and ( 5) is minus 25 degrees
those figures are example figures to show how the temperature in the units will be in relation to the dial numbers
Apr 27, 2015 | LG LSC26905TT Side by Side Refrigerator
Could you send me a diagram of how to hook up the two six volt house batteries.
Hi if you want to join two batteries to make 12v place the batteries side to side and. Connect the negative from one battery to the plus of the other. Then connect the batteries in the vehicle as normal plus to plus minus to minus. If the vehicle is 6v then connect plus to plus and minus to minus this will give you 6volts and double the amps. Hope this helps. Regards Jim...
Apr 11, 2015 | Cars & Trucks
Admiral side by side fridge is not staying cool
Hi, fridge produced today's time do not possess the condenser on the back of the fridge but underneath. Most people handled exclusively fridge and uses. The problem begins when after some time of use
accumulates a large dirt suspension that starts to block the airflow that cools the gas flows and who to be with cool before it flows to the evaporator to colder gas produced in the evaporator temperature minuses. If the gas is hot at the entrance of the evaporator does not produce a very low temperature as well as produces more ice who eventually begins to block the flow of cool air inside the refrigerator. It should also check de defrost circuit who also may be damaged. What should be tilted for cleaning your refrigerator and use the vacuum cleaner from time to time.
Jun 17, 2014 | Admiral 26 cu. ft. Side-By-Side...
How to temp. to cool
Push & hold the red wine button & the white wine button. This will start the adjustment process. Let go of both & use the plus & minus buttons to control the temp. When you are done hit the light button & the unit will record the new temp.
Feb 16, 2012 | Haier BC112G Wine Cooler
Refrigeratior side only cool, does not get colder when control is increased
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 09, 2010 | Maytag MZD2766GES Side by Side...
If damper fails would it stop fridge side getting cold? does damper require a neutral conection
No the damper,(i call them flapper door,lol) is just a manually operated door that is on a physical linkage, mechanically operated manually, no power is used nor required. a failure will be stuck closed, which is the COLDER setting. which seems as if it is ok, except it means colder freezer!! and as the reefer is reliant on the freeezers evaporator and airflow totally, anyone pegging or setting to max colder is making the door close to reefer, thus starving the reefer and making freezer colder as irt actually says but almost nobody turns it to warmer to cool reefer down more!
Nov 01, 2010 | Whirlpool Refrigerators
How to I make it run at 2 channels, 2ohm per channel to get the 250 watts per channel?
If you are looking at the termianl side of the amplifier...you have on the left hand side a plus and minus, this will be the left speaker........the next terminals are the line in from thr radio head unit (RCA), then plus and minus for the right hand speaker. This is the basic setup for a 2ohm , 250W RMS output......please make sure to attach plus and minus to plus an minus on the speaker and not get them mixed around.....you WILL notice the difference
Sep 20, 2010 | Sony XM-SD22X Car Audio Amplifier
THE UNIT DOES NOT COOL ANDY COLDER THAN ROOM TEMPERATURE.
does the compressor run ? if so you could have a low refrigerant charge, a sealed unit resrtiction, leak or defective compressor.
Apr 30, 2010 | Haier HVUE08A Wine Cooler
Freezer won't cool past 13 deg.
Check for lint in the compressor coils. Make sure the defrost timer is working. Mark the small dial on it and wait a half hour.
Apr 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge does not cool below 40 degrees
This is a common problem and a design fault...
Jun 25, 2008 | Samsung 24.8 Cu. Ft. Side-by-Side...
Refrigerators Logo
23 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
