Question about Pioneer Computers & Internet
Need to reset password on my pioneer 4100 - Pioneer Computers & Internet
Does the pioneer deh-4100 single din have a built in blue tooth? Thank in advance
No. Pioneer models with built-in Bluetooth have a "B" in the model number.
Jul 15, 2015 | Pioneer Car Audio & Video
I need a password
You may have to reset the modem. Hopefully you have all the details on hand for your broadband account available? That way once the details are in you can set the administrative password to whatever you wish. But write it down & put it somewhere safe. :)
Aug 09, 2014 | Siemens SpeedStream Modem (4100) (SS4100)
Can't Get into BIOS
BIOS passwords can be reset in two ways:
1. using software 2. using hardware.
I would first try resetting using software, here are two software apps to reset or retrieve BIOS passwords.
!BIOS - is a PC BIOS toolkit offering password removal/decrypt and BIOS settings modification/backup/restore.
You can download it here:
http://www.syschat.com/download120.html
CmosPwd - Cmos password recovery tools
http://www.syschat.com/download121.html&act=down
Good Luck!
Jul 25, 2012 | Gateway Computers & Internet
Lost password for Pioneer AVICF910BT and want to reset
Hello
If you did forget the password, there is no other way than contacting the nearest authorised Service center for Pioneer at your town. No adjustments cannot be done with this set, except deleting the present password. But to delete the present password, you must have the original password you did set at first. OK.
Nov 22, 2011 | Pioneer AVIC-F910BT Car Video Player
How to reset zyair 4100 with factory defaults ? I have made a restauration of the configuration and now, I can't access it anymore !!!
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
There is a great article at Working with Windows Wireless Networks or There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
Jan 20, 2011 | Zyxel ZyAIR G-4100 Wireless Router...
I need to change my user name and password it has a big pond email address at present new email address is adivar@tpg.com.au password is tpg123
You need to reset the modem buy holding down the reset button and then the default page should come and enter in your new user and passwordl
Nov 21, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
Cannot remember password for my router .. how can i change the password?
For that you have to reset password first.
Press reset button for 10 seconds it is in back side of router.
Then connect your router to computer with ethernet cable.
Then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
Then you can see configuration page.
Try this password before reset.
Let me know if you need more assistanse.
Thanks.
Sep 21, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
Siemens speedstream 4100 eternet ASDL modem
Hii,
the password and the user name would be given to u by the company from where u have the taken the internet connection ....
Oct 30, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Siemens Speedstream 4100 Modem installion
As you are using speed stream 4100 modem and it has a5 lights, if u have a 1 solid light for power and other all the 4 lights are flashing, It indicates either u need to upgrade the firware of modem or you may try Hard reset option of modem..At the rear sode of modem you will have a reset hole / button, u may press that using some paper clip...unplu all the cables and wait for 2 mins...connect them back in..all the lights will come up but the internet..u need to check IP address by doing IPCONFIG, whatever gateway u r getting (probably 192.168.1.1) type that into adressbar of IE and putthe correct user name and password, asked code u may get from the bottom side of ur modem...get into GUI og modem and put your complete email address and password, save settings ...Ok and restart the modem...it will be ready to go.
Sep 12, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
Computers & Internet Logo
Top Pioneer Computers & Internet Experts
Computer Links
David
David
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
