Question about Texas Instruments TI-Nspire CX CAS Handheld Color Graphing Calculator with Computer Algebra System
HOW CAN I Simplify on a rational expressions on a TI36XPRO
How do I tell wether a number is rational or irrational?
If a number can be expressed as a ratio of two whole numbers then it's rational.
Alternatively, if a number can be expressed in decimal with a finite number of digits or as a repeating decimal then it's rational.
Oct 12, 2014 | Computers & Internet
What can constitutes a rational expression
Haha it's not an expression which shows you are not crazy.
It is a fractional formula in which the top and bottom line are algebraic polynomials, whether low order (like x + 1) or higher order (like 4x^3 + 8x^2 - 7x + 5). See here
http://tutorial.math.lamar.edu/Classes/Alg/RationalExpressions.aspx
Apr 01, 2014 | Mathsoft StudyWorks! Mathematics Deluxe...
Is 8/3 a rational number
A rational number is a number that can be expressed as the RATIO (see rational) of two integer (whole) numbers. 8 is an integer, and so is 3. The number 8/3 is a RATIO of two integers :it fits the definition of a rational number.
Oct 29, 2013 | Mathsoft Computers & Internet
How do I simplify radical expressions with fractions on a TI-nspire cx cas
If the results' display mode is set to exact, the calculator will give you exact results.This means that if the result has radicals you will obtain a rationalized expression: any radicals left will be in the numerator. This is the default behavior of the calculator when display mode is st to EXACT. There are no more simplifications to perform.
However (because I am not certain what you mean by simplification) I will add that if any number in your calculation has a decimal mark, the result will be given in its decimal representation. (Is this what you mean by simplification.
Further, if you do not care for exact result switch the display mode to APPROXIMATE.
I am enclosing a screen capture to show you what happens.
Sep 11, 2013 | Texas Instruments TI Nspire CAS Graphing...
`What constitutes a rational expression? How would you explain this concept to someone unfamiliar with it?
A rational expression is a ratio of two polynomial expressions.
Example R(x)=P(x)/Q(x) where P(x) and Q(x) are polynomials of the indeterminate x.
Sep 27, 2012 | Mathsoft StudyWorks! Mathematics Deluxe...
Simplifying radicals on fx-115ES
If your calculator is SetUp for Math Input/Output (MATHIO), a result that gives a radical will remain in radical form. If a radical appears in a denominator the whole expression is rationalized: Any radical left is put in the numerator. 1/Sqr(3) is displayed as Sqr(3)/3.
Feb 01, 2012 | Casio FX-115ES Scientific Calculator
Can this calculator find the sum of two rational expressions??
All calculators can calculate the sum of two numerical expressions (no letter symbols).
To be able to declare that this calculator can add two rational expressions ( with letter symbols or not) and displays them as a rational expression (result) I would need to know the EXACT Model.
Aug 15, 2011 | Casio Office Equipment & Supplies
Just simplify this rational algebraic expression 16a^2-8a 1/4a-1
16a power of 2, -8a,),,(1/4a-1) are these two prolems polynomials, to be multiplied togethor? is 4a to the third power-18a squared+8a, used the distributive property
Michael
Oct 04, 2010 | Mathsoft StudyWorks! Mathematics Deluxe...
Hello, I am in college and I am having trouble with Rational Expressions
The first page that a Google search for Rational Expression returned is Paul's Online Notes. Here is the link
Hope it helps
Sep 19, 2009 | The Learning Company Achieve! Math &...
Variables
This calculator cannot handle symbolic algebra.
Use the rules to simplify the expressions: Get rid of the parentheses using distributivity od multiplication with respect to addition; group similar terms (terms with x, terms without x).
Hope it helps.
May 07, 2008 | Casio FX-115ES Scientific Calculator
Texas Instruments TI-Nspire CX CAS Handheld Color Graphing Calculator with Computer Algebra System Logo
27 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
