Question about Garden
Huskee riding mower model 13AF673H131 is stuck in 1st gear, will go forward and reverse but not switch to other speeds.
5 Suggested Answers
SOURCE: riding lawn mower
You'r sitting on the mower back to front
Posted on Feb 05, 2009
  • 6468 Answers
SOURCE: huskee heavy duty riding mower only has one gear, drives forward, even in reverse
there is varible pulley under the center tin cover that pulley changes dia and after sitting they stick check that pulley
Posted on Apr 12, 2012
ineedabin50249
  • 755 Answers
SOURCE: jcb 532-120 1998 will only drive forward in 1st and 3rd gear but will drive in reverse gear in all speeds
I used to work on one of these , I think these are electronic shift modules , may be a dirty plug on the trans , may have the linkage off ,I forget ,
Posted on Sep 15, 2014
  • 43113 Answers
SOURCE: What can I do to fix the problem of the riding mower not going in forward or reverse.
it could be a worn out belt .
Posted on Nov 18, 2015
I have reverse but no forward took apart no chiped or brocken gears replaced bearens on small gear shaft shimed top beveled gear still does same thing
should of mentioned the make and model...
also check the belt tensioner arm... they'll get stuck and not apply pressure in forward but in reverse... also seen it do it the other way around...
Apr 28, 2015 | Garden
Huskee madel 13af673h131, won't crank
I guess you were sitting on the seat while trying to start the unit, so Try to apply power direct to the starter, if it turns over buy a solinoid. If it doesn't the starter may be bad. To check the engine: take out the spark plugs and try to turn over the engine from underneath by hand, using the pulley. This will tell if the engine is siezed up
Apr 10, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Mower slips in and out of forward gear but rides perfect in reverse;What do I need to adjust?
Reverse is a different gear set than forward gears. Sounds like forward gear set has a broken tooth. Not an easy fix.
Jul 18, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Huskee heavy duty riding mower only has one gear, drives forward, even in reverse
Apr 10, 2012 | Garden
I have an MTD mower tha tis ver jerky in forward, reverse is fine. What could it be? The trans is about 2 years old. I thisnk it could be the clutch plate or the differentital, however, reverse works fine...
Assuming that the model you have is a single speed transmission with variable speed belt system and that the mower has never been used to tow anything heavier than a dump cart. 9 times out of 10 its usually the forward gear shift key not allowing it to go all the way into forward gear. Might be able to ajd the shift linkage to acomodate a tighter mesh with the input and ring gear
Nov 23, 2009 | Mtd Garden
Huskee jerks while going forward
Go to... http://mtdparts.arinet.com/scripts/EmpartISAPI.dll?MF&App=MTD&TF=Empartweb&Lang=EN&searchDB=MTD&loginID=MTDCon&LoginPWD=&xmlPostDest=http://www.buymtdonline.com/webapp/wcs/stores/servlet/processShoppingCart_10101_19502_-1_19502 Enter the brand (Huskee) and model number, not the one you listed, but the one under the seat... hit search and click on illustrated parts, then click on Mower Deck. That will show you the routing and belt number.
Jul 06, 2009 | Garden
Will not go into gear
a hydro uses a foot pedal on the right side , you push forward to go forward or rock the pedal rearward to go in reverse - a regular transmission has a shifter usually between your legs for reverse 1st 2nd or 3rd gear - you also said the blades wont engage . are they electric ( with a switch ) or do you manually move a lever .
Oct 23, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
