Question about Cell Phones
I have an older panosonic phone I would like to add more blocked numbers the limit is 32 hope you can help thanks
How can i block a number in nokia lumia 610
there are 2 ways :
  1. Swipe right to the app list
  2. Scroll down until you find 'Settings' (tap)
  3. System
  4. Scroll down until you find 'call+SMS filter' down the list, then tap to open
  5. select accept then add the numbers u want in blocked numbers
or if u want to block a number called u in log :
  1. Head into phone history (Phone)
  2. Long press on a contact
  3. On the pop-up dialog, select 'block number...'
Jul 27, 2016 | Nokia Lumia 610 Unlocked Black
How do I block a phone number from calling?
If you don't want to get phone calls, FaceTime calls, or messages from a certain person, you can add them to your blocked list. You can also filter out iMessages from people who aren't saved in your contacts.
Learn all the details at https://support.apple.com/en-us/HT201229
Hope that helps!
Jan 20, 2016 | Apple iPhone 5c
Block number
Go to menu, scroll to contacts, then select 'No screening' option. You will find word empty, click on options just on lower left corner of the LCD then select add number. Now type the number you want to block and click ok. Hope you enjoy.
Jun 14, 2013 | Nokia 1112 Cellular Phone
I want to block two numbers that constantly call my phone how do i do that
Blocking numbers is dependent on the type of your mobile phone. Usually Samsung phones have a blacklist feature. You can also call your Service provider to block the number for you. Hope this helps.
Apr 03, 2011 | Cell Phones
How do i block messages and calls from a certain number??
Thanks for posting on fixya and we are pleased to help you at the earliest.
You can either call up the service provider of your SIM card and block the number or you can reject call with the following simple steps. To reject calls from certain numbers automatically, use the auto rejection. To activate the auto rejection and set up the reject list, 1. In Menu mode, select Settings ? Application settings ? Call ? All calls ? Auto reject. 2. Scroll left or right to On. 3. Select Reject list. 4. Press ? Add ? New. 5. Enter a number to reject and press . 6. Repeat steps 4-5 to add more numbers. 7. Select the check boxes next to the numbers. 8. Press ? Save. 9. Press .
Hope it helps you. Great time. I appreciate your valuable feedback.
Nov 03, 2010 | Samsung B3310 Cell Phone
Want to know how to block a caller from phoning my home phone.
There are a number of ways to accomplish this if you need to.
Normally your landline phone company will have a paid monthly service called CALL PRIVACY, or CALL BLOCKING, or CALL SCREENING, or some other name like that. Each local phone service provider will have their own name for their particular version of this product so you will have to contact yours in order to find out the exact details, operating instructions and cost.
This service will effectively allow you to block certain numbers from calling your home phone. You can either enter the numbers into the system manually, or if their Caller ID is hidden, then just press a certain key sequence right after they call in order to automatically add them to the block list.
After that, your phone will no longer ring at all when that number calls you and the calling party will hear some kind of automatic rejection message and then be disconnected.
Generally this service will cost a few extra dollars a month on your phone bill and will normally allow you to block up to about a dozen separate numbers.
If you need to block more numbers than that, then you may need to set up your own customized call blocking system using a home computer hooked up to your home phone landline. There are a few excellent software programs you can get which will monitor the incoming calls to your home phone line and automatically block any that you designate as undesireable.
As I said, these customized call blocking systems normally require you to have a basic home computer system connected to your phone line and running full time. If this is not objectionable and you have an older spare desktop computer system lying around, then it would not take much effort to set it up. The main advantages to this method are that there is no limit to the number of callers/numbers that you can block, and the only paid monthly subscription you require from your local phone service provider is their Caller ID feature.
Here is a link to one excellent software program that you can download and use completely for free:
http://download.cnet.com/PhoneTray/3000-2074_4-10540928.html?tag=mncol;8
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated where you can read about the software, check out other user's reviews, and download it completely for free if you decide you want to try it. This particular program offers many additional options as well beyond just simple call blocking if you want to get really creative, but a basic system is pretty easy to setup if that is all you need.
I hope this was helpful.
Good luck and take care.
Joe.
Mar 19, 2010 | Panasonic Lands Phones
I don'tknow how to block a contact on a lg arena phone
please follow the steps carefully
  1. Step 1 Call the T-Mobile customer servicemag-glass_10x10.gif phone number located on your phone bill. Tell them you would like to hear about T-Mobile's call blocking service. The customer service then tells you how you can block all the calls coming from your T-Mobile cell phone by adding this service to your plan. When you select this service, anytime you dial a number from your T-Mobile cell phone, the number will come up Restricted on the call receiver's caller ID.
  2. Step 2 Dial *67 prior to any number on your T-Mobile phone that you want to block, if you want to just block one call at a time and choose which numbers you dial are blocked. This is another way you can call someone and to have it appear as a Restricted call on the other end.
  3. Step 3 Program your T-Mobile phone to block all calls to any one individual. Do this by tapping Add a Contact on your T-Mobile phone. Type in the name of the person you want to call. Then tap Add Phone Number. Punch in *67 then the number.
  4. Step 4 Tap the person's name to call him, when you have the person's number programmed into your phone with the *67 first. Every time you tap the person's name, you will be calling him from a blocked number.
hope you dooooo...
please rate me
thank you
Sep 20, 2009 | LG KM900 Arena Cell Phone
Block one number from calling and texting me
Hi
some Samsungs have a 'block list'. I am quite sure that the D900 has it. All you have to do is when you receive a text from this number select options, and you should see in sub menu 'add to block list'. I am not sure if it also blocks calls once added to the list? Hope that helps?
Apr 26, 2009 | Samsung Omnia i900 i908 Premium Orange...
Blocking a phone number
if you want to block your own number dial *67 before you dial... to block someone else try dialing
To activate Call Block or add a telephone number to the rejection list, dial *60. If you dont know the number to be blocked, dial *60 immediately after hanging up from the call. To turn off Call Block, dial *80. Call Block cannot block calls from some cellular phones, pay phones or business lines. It also cannot block most long distance numbers.
hope this helps...please rate...thanks
Jan 13, 2009 | Uniden Cordless Phone
Need to block a number from my phone
how to block number on my panosonic phone
Aug 13, 2008 | Lands Phones
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
