Question about Sport & Outdoor - Others
Black rife gunsmiths in florida - Sport & Outdoor - Others
SHOT A EXTRAHOT RELOADED RND NOW CANT GET BOLT TO OPEN
The best and safest option would be to take it to a gunsmith
If you want to try to fix it yourself try gently knocking the bolt forward until you can lift the bolt handle to the up position if possible if that works pull bolt rearward if it is to hard stuck put a brass rod down the barrel and drift the case out
If the rear of the case breaks of you will need a case. Extractor to try and remove the body of the case still in the chamber
After all this you may still need to find a gunsmith
Apr 14, 2016 | Mossberg Trek Rifle .243 Win 22in 4rd...
How do i clean my black powderrifle
I hear black powder is quite corrosive and leaves a lot of residue, especially in calibres of less than half an inch.
I strongly suggest you seek experienced and specialised advice about your question to give you a better chance of enjoying your weapon safely for a very long time.
A traditional gunsmith would be a very good place to begin and making contact with a black powder club would also be a good move.
Feb 20, 2015 | Optics
How to disassemble a remington 700 bolt ?
You'll need a tool similar to this one, James:
http://www.brownells.com/gunsmith-tools-supplies/rifle-tools/bolt-tools/dissassembly-tools/remington-bolt-disassembly-tool-prod7650.aspx
Aug 10, 2014 | DNZ Products DNZ Dednutz Remington 700...
Black screen after returning from florida
plug in > if charge light comes on and screen black proceed.... if no charge light comes on on laptop your charger's not working
plug into external monitor > if the external monitor works fine with laptop then your LCD is not working, you can look for the Function key (should be bottom left) and the monitor button (probably f7) and switch back and forth... this should tell you if the lcd works or not.
Apr 20, 2009 | Gateway MX6027 PC Notebook
The rifle missfires about every third shot.
It sounds like you've either have a weak firing pin spring, or the follower may be giving you problems. Did the gunsmith check for excessive headspace??? If not, he or she probably should. This can not only cause mis-fires, it may also create a dangerous situation otherwise. I'd DEFINITELY get a second gunsmith to check this out for your own safety! I'm a gunsmith myself, and wouldn't risk it ever.
Apr 08, 2009 | Panasonic KX-T7630 Corded Phone
Sport & Outdoor - Others Logo
144 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
