Question about Home
I changed the batteries in my melodies in motion clock and it chimes and the music tries to start then it chimes again I took batteries out and put them back in but no results Help Please
SOURCE: Samsung Juke not able to put music in!! Need help!!
I had the same problem. It happened when I deleted all the songs off. Here's what I did:
I took out the battery (leave it out for like a minute)
Turned on the phone
Plugged the USB into the phone....then into the computer
I then got to pop up to sync/view files
Then I unplugged it and was able to go to my music
Posted on Dec 03, 2008
  • 16 Answers
SOURCE: lg rumor doesnt vibrate
o well all you have to do is go to the store and then they will send you a new one and they will take yours to be looked at and make sure you didnt drop to hard or anything and then they will let you keep the new one and they will take your old one i hope i helped!
Posted on Jan 03, 2009
SOURCE: Buick Rendevouz 2002 Security Sign is up Car has Start problems
have the alternator check out. A good alternator should give produce voltage 13.8v or 14.5v ,but not greater than 15 volts
Posted on Jul 05, 2009
  • 16 Answers
SOURCE: Quartz president wall clock, I need to set the chime
I have a pendulum wall clock from the president collection. If yours is the same or similar, the following may help:
*Look at the back for a slide switch labled "start" at the top and "set" at the bottom and move it to "set"
*Look for for small push buttons. They represent the hours and minutes. Push each in turn, the number of pushes to represent the time, ie, for 09:45, ignore the first(0), push the second 9 times(9)-push the third 4 times(4)- push the 4th 5 times(5). When done, push the slide switch back to "start".
If yours is the same as mine - a wall hung pendulum clock with Westminster chimes, made around 1988. I would be happy to scan and send a copy of the instructions.
John
Posted on Nov 03, 2010
  • 4736 Answers
SOURCE: I have a desa
Sandra, the contacts in bell push may need cleaning, as well as some minor readjustment of the contacts. Insects love to get into the bell push and can clogged it up. If you find that this doesn't solve the problem, Contact the Zenith Company 800-858-8501 to purchase a replacement.
Posted on Mar 09, 2011
How do I change melodies?
The melodies should change each hour on it's own. You can change the melodies manually by pressing the demo button repeatedly. If the songs don't change each hour, you might try new batteries. I'd recommend Japanese batteries like Fuji, or Toshiba. I use Varta which is a German brand battery that's equivalent to either Duracell, or Energizer, and have no problems. If you've had the clock for a number of years, or have had it hanging in direct sunlight, or near a heat source it could be in need of professional assistance, and or repair. (if possible)
Mar 01, 2015 | Seiko Melodies in Motion Clock
When my melodies in motion clock plays the music (Beatles), it sounds distorted.
You may have a loose speaker wire connection or the speaker could be bad.
Dec 09, 2013 | Seiko Melodies in Motion Clock
Motions will not work but time and music does
That just happened to me, check and make sure you have the batteries in correctly for the movement part. They are both supposed to be in the same direction on my clock for the movement and I had the AA batteries in opposite of each other!
Nov 12, 2013 | Seiko Melodies in Motion Clock
Brand new out of box,,does not chime or play music at the top of the hour.
Take it back for an exchange or refund. You have a defective unit.
Nov 03, 2013 | Seiko Melodies in Motion Clock
My seiko musical wall clock doesn't play music anymore
To test your Seiko Melodies in Motion Clock:
1) Check the volume knob in the back of the Seiko clock to make sure the volume has not been adjusted all the way down.
2) Make sure the on / off switch is set to on.
3) If it is extremely dark in the room, the clock will not play, it has a light sensor. Make sure the room is well lit.
4) There are separate batteries usually that operate the clock and the music. Change the batteries paying special attention to any acid / corrosion caused by old batteries. Clean out any acid and it should play. Also, be careful not to touch the positive or negative contacts on the new batteries, as this could inhibit proper connection.
If you have done each step above and it is still not operating, your clock is defective. Contact Seiko Service Center directly at: 800-722-4452 extension 3.
If you have had the clock less than a year, and it was purchased from an authorized dealer, it is under warranty, and any repairs will be free. Otherwise, there may be a charge for the repair.
Feb 23, 2011 | Seiko Melodies in Motion Clock
Home Logo
29 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
