Question about Dryers
Wiring diagram for motor to three way switch an reversing switch
mydogisk
  • 50 Answers
SOURCE: cutler hammer a10ano series a-1 contactor
There should be 2 contactors for forward and reverse. you have to wire them so that the power coming in will switch 2 opposite phases to reverse.
Posted on Apr 10, 2009
  • 5481 Answers
SOURCE: 1996 ford explorer sunroof wont close
This website shows it has manuals and online diagrams like that. Sometimes a dealer parts guy will run you a copy of a parts diagram. It is a 13 year old vehicle- a salvage yard may have something torn apart that you could see.
Posted on Jun 10, 2009
SOURCE: WIRING OF 3-WAY SPEED SWITCH FOR HAMPTON FAN
1 - Red/Pink
2 - Purple
3 - Yellow
L - Black
Posted on Jun 20, 2009
protek480
  • 1714 Answers
SOURCE: how to wire a 110v reversible motor to three-way
I have a diagram I made s few months ago for one of my customers. I will sen it on to you later today. It is a bit tricky...Craig
Posted on Sep 08, 2009
puertobori
  • 7733 Answers
SOURCE: older milwaukee half inch drill
Try eReplacementParts.com : Power Tool Parts and Tool Repair
Posted on Nov 02, 2010
Drivers side window not working
the red/yellow and red/blue are the power/ground wires to the motor. You should get power on one and ground on the other when you operate the switch. The polarity should reverse when you operate the other direction. The blue wire is a pulsar wire to give motor feedback to the switch.
Jul 23, 2017 | 1999 Honda CR-V
Essick air compressor wiring diagram
telepathy do not work that hot as in hollywood movies...
you need to provide a model or at least if this is three phase or single phase...
single phase is easy, you have cord with three wires, earth, active and neutral.
you need to open connection box on your compressor and you will find three wires there terminating in junction box, earth connect to earth (usually green or green with yellow stripes), then you have your neutral (usually brown or black) and active (usually blue or red), connect them, do not put cover on yet, plug cable into the power point and switch on/off power. check if motor is rotating in correct direction, if fuses are not blown... if motor is rotating in wrong direction - switch power wire with neutral wire, it just meant that you wired it in reverse...
do not need diagram for that...
do not forget to give some points...
Dec 30, 2013 | Park Tool Inf1 - Shop Inflator For Use...
I need to turn the propel that is backwards, i bought this electric motor but is bacckwards
Check the motor wiring diagram, you may be able to reverse the rotation. Usually all it takes is switching wire #5 and wire#8 to reverse rotation.
Mar 09, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
1997 Chevy Lumina, I replaced the passenger side power window motor due to the factory one failing, The person before me cut all the wires going to the motor and toggle switch in their attempts to fix /...
There is a wiring harness on hinge side of passenger door correct, take a look at the wiring colors. Hope you can read it. At the window switch, the outside wire on either side is voltage or ground depending on which direction, up or down, reversing motor. You don't need the window switch for testing, you should be able to operate from driver door master switch. If you get the wires reversed, the only thing that will happen is, up will be down and down will be up, if that happens, reverse the wires. Just my opinion.
At the window switch, top middle wire is lockout, so only the driver can operate the windows.
Apr 26, 2017 | 1997 Chevrolet Lumina
Our shop has an accuturn 4502 tire changer.I would appreciate a wiring diagram/schematic that includes the capacitor,motor and the (junction block?)
115v USA wiring. We replaced our A.O. Smith 312P458 with a Century C524 motor. Century has bought out A.O.Smith and this is the interchange motor. The drum switch has four wires going to the motor (plus a ground). 2 wires are Hot and Neutral in Forward and Reverse (I refer to these as Line)and 2 wires are Hot and Neutral in Forward and swapped in Reverse (I refer to these as Switched Line).
On Century motor, remove Brown jumper wire all together. Hook up as following:
Pin1=Blue, Orange, Line
Pin2=Empty
Pin3=Black, Switched Line
Pin4=Red
Pin5=Switched Line
Pin6=White, Yellow, Line
Dec 01, 2010 | Bosch Vehicle Parts & Accessories
How to wire a 110v reversible motor to three-way
Sep 08, 2009 | Kitchen Appliances - Others
Jun 09, 2009 | 1996 Ford Explorer
Wiring question
could you please let me know what colors are the wire infact if you go on line there will be a basic diagram for your type of fan/lamp assy. just type in the model muber, then as the browser for the wire diagram,it should be on line.. nbcrca:)
Apr 10, 2009 | Dryers
Cutler hammer a10ano series a-1 contactor
Apr 10, 2009 | Plumbing
Fan motor capecitor
go to electric motor shop . take oem capacitor. replace with exact replacement. rule on capacitors is uf or mf rating must be exactly the same. voltage can be higher. for instance if you have a 370 cap you can replace it with a 440 cap but never the reverse. to pull a bad 120 cap and replace it with a 230 cap is ok. but to pull a 440 cap and replace it with a 230 cap is a no no.cap rating must remain the same . volt rating can be higher but not lower.if motor still turns in reverse look at the reversing leads. see wiring diagram on the side of the motor. most replacement motors can run cw or ccw. by switching the reversing leads you can effect direction. usually wired up orange to orange and purple to purple. switch org to pur and pur to org and motor runs opposite direction. be sure you have a new correct cap for the new motor. every new motor should have a new cap and they are different usually.one motor might be a 5 mf cap and the new motor might require a 15 cap! be sure power is off and you check it three ways. looks off, checks off with a meter, and is off when shorted with a screwdriver.good luck
Oct 17, 2008 | LG Electronic Window Air Conditioner
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
