Question about Sander Tools & Hardware - Others
Where can I purchase drive belt for Stanley belt sander Model 0.4 #80493?
    New Friend:
Lowes also look up sanding belts .com some are 40 percent off the cost
Posted on Jun 20, 2017
  • 359 Answers
SOURCE: Porter Cable belt sander
try to rig the nozzle of a shop vac to the part where the bag would normally connect and run the sander simultaneously with vac for a few minutes and see if that helps
Posted on Jan 11, 2009
  • 1996 Answers
SOURCE: Porter Cable 352V belt sander eats belts
I've never had any particular problems with norton belts. All belts will require some adjustment as they wear in,however.
Try this: Put a new belt on, turn the sander upside down and rest it on the front handle. Get a good grip on the rear handle and turn it on while you use your other hand to turn the tracking adjustment. Just center the belt on the drum. I don't know what the manual tells you to do, but that's what matters, that the belt rides across the platen without hanging out loose in space or running up against the housing of the machine. If it does ride in against the housing, and you don't track it away, eventually you'll have a groove worn right through the side of the machine.
If you try this, and it still doesn't work, make sure the drums are secure and look right. Is it possible the machine was dropped and the drum bent? If so, parts will have to be replaced.
The only other cause I can imagine is that there is some kind of something jammed inside the housing that is protruding into the belt pathway that they're getting caught on, but that seems unlikely. Check anyway. Look with a flashlight.
There are better belts available than Norton, but they should work.
Some belts have an arrow on the inside of the belt indicating the direction of travel. Make sure if yours does, that you put it on that way. I try to install them so the joint will tend to ride up over the work instead of the work tending to want to tear the joint apart, but this is not always obvious, depending on the mfr.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Apr 02, 2009
  • 1996 Answers
Maybe you can use a linked belt to replace it. Check the width of the old drive belt, and give these folks a call: Lee Valley
SOURCE: How do you replace the drive belt on a Porter Cable Belt Sander
If you don't mind, let me know the outcome.
Posted on May 28, 2009
SOURCE: looking for a manuel for a makita belt sander model #9401
There is a black metal ******** one side that is actually a lever and with the tip of a screw driver or the like, pops out and releases the front roller.
Posted on Nov 24, 2009
I have a stanley 80493 belt sander 3 x 21 model 04 I need to get a belt for it, where can I find one ?
You can contact Sears they will find the part for you or go on Stanley tool site and e m ail them the part # or u can go to ur local hardware or mini bike shop they will have various size belts
Dec 11, 2014 | Tools & Hardware - Others
I need a drive belt for a Stanley belt sander
Unless there is a model that I have never seen, the sandpaper is the drive belt on belt sanders.
Jul 04, 2014 | Hand Tools
Belt slips on Stanley belt sander model H-31A
On most belt sanders the back wheel or the idle wheel has an adjustment on it, loosen the bolt that goes through and slide back. Some have an adjustment screw that will pull or push the idle wheel. That should be on the inside of the wheel.
Mar 05, 2014 | Hand Tools
Need motor brushes for a stanley heavy duty 4'x24' belt sander. type: 497, model A, amps: hi-8.5, lo-7.0, volts 115, serial # 457244. thanks, tom
I had the same problem, cannot find spares. I went to a local tool hire company and purchased two brushes (Part No. L41F10). You will need to shorten them by approx.1/4"", swap the springs and cut down the metal terminal to same shape as the original. A small 1/2 round file, junior hacksaw and about 15 minutes should get you going.
I am looking for a trigger (on/off) switch to suit my sander, if anyone can help I would appreciate it. Only other option seems to fit an inline switch to supply cable.
Jun 15, 2011 | Garden
We have a really old Stanley 3" Belt Sander that has a worn electrical cord. We want to replace the cord; however, we cannnot get to sander open in order to install a new cord. We have all the...
use a screwdriver (rubber handled) to smack around the tool to losten it. you hill find that the seam will start to open.. then carefully pry it open with a flat blade.. if it is hard in one area look close to see that you didn't miss a screw ... jay
Jun 06, 2011 | Stanley Tools & Hardware - Others
I have a Ryobi BE-321 belt sander. The drive belt is strtipped. Are replacement belts still available?
Yes, you can purchase a new belt here:
Oct 27, 2010 | Tools & Hardware - Others
I have a Porter Cable Model 371 2.5" X 14" Belt Sander. I broke a belt, when I did it jammed and also broke a rubber sleeve that covers the Drive Wheel. I have yet to find this rubber sleeve in any part...
Unfortunatly that sleeve is not available, you will need to purchase a whole new drive wheel. The Drive wheel is $9.66 from DeWalt Service Net. Porter Cable, Delta & DeWalt are all owned by Stanley Black & Decker, you can contact DeWalt Factory Service for all parts. 1-800-4-DeWalt You can order the parts on-line, over the phone or though a local service center. The website is Below is the parts diagram for your sander. The part number for the drive wheel is A16439
Oct 10, 2010 | Porter Cable 371K Factory Reconditioned...
I have the same sander, and cannot get parts anymore, so I carefully cut out a piece of sheet metal, and drilled holes, and put it on. so it might not say stanley, but who cares? I don't. and if it doesn't last as long, who cares. its more help than I got from stanley, who was bought out in 1973 from what I read.
Oct 18, 2009 | Stanley Hand Tools
Nov 14, 2008 | Tools & Hardware - Others
Tools & Hardware - Others Logo
293 people viewed this question
Top Sander Tools & Hardware - Others Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sander Tool and Hardware - Other Expert? Answer questions, earn points and help others
