Question about Exercise & Fitness
How do you watch YouTube - Exercise & Fitness
The tread mill stops suddenly and shoes an error
there must be a reset button somewher try that it will surely work again without any error............
Dec 10, 2011 | Fitnex T30 Treadmill
I just turned my treadmill on after not using it for about 3 months. Once I get started and get to about 2.5, it shuts off. I turned it off and restarted it and it happened again. I turned it off again...
Most of the time its caused from not lubricating between the treadmill belt and deck. This causes friction and the surfaces wear putting greater stress on the electronics. The treadmill is shutting down to protect the electronics.
Proceed watching this videos with mechanical adjustme and lubrication:
http://www.youtube.com/watch?NR=1&v=USSgbsZbDLQ
http://www.youtube.com/watch?v=hKbAqvuOBS0&feature=related
http://www.youtube.com/watch?NR=1&v=KiEZDNe0F8Q
http://www.youtube.com/watch?v=wjrVjYe2LYQ&feature=related
http://www.youtube.com/watch?v=CuMjcPLYehw&feature=related
http://www.youtube.com/watch?v=yX_0vRPdMfU&feature=related
http://www.youtube.com/watch?v=zXeHMWTcLUY&feature=related
Of course you must shure after you did this,If there are some electrical and electronic problem. Motor+Controller Board and Transformer. Go to the 2nd Troubleshooting section:
http://www.youtube.com/watch?v=qgb2TY3WCkg&feature=related
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
http://www.youtube.com/watch?v=GPI6dFJCUA4
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitness
http://www.fixya.com/support/r10786838-test_procedure_dc_motor
http://www.youtube.com/watch?v=23ZgWaVEQjA
http://www.youtube.com/watch?v=dxpOOPetVLo
Apr 26, 2011 | Proform XP Weight Loss 620 Treadmill
I have apro/form 620 electric treadmill starts working then suddenley stops
Most of the time its caused from not lubricating between the treadmill belt and deck. This causes friction and the surfaces wear putting greater stress on the electronics. The treadmill is shutting down to protect the electronics. You should stop using the treadmill AND test the following:
1) Mechanical adjustment &Lubrication:
After you did this and the problem persist , you may have electrical and electronic problem go to the next section videos:
2nd) electrical and electronic Test:
sincerely.
Mar 11, 2011 | Proform XP Weight Loss 620 Treadmill
I just got this treadmill from a friend at work. She had it about 2 years and already had replaced the motor in it. Her son never used it after the motor replacement and hardly had used it before that....
Most of the time its caused from not lubricating between the treadmill belt and deck. This causes friction and the surfaces wear putting greater stress on the electronics. The treadmill is shutting down to protect the electronics. You should stop using the treadmill .
Do the following Watching the videos:
1)Mechanical adjustment and lubrication
If the problem persist go to Test the electrical and electronic section:
2)
Mar 03, 2011 | Proform XP Weight Loss 620 Treadmill
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
