Question about Vacuums
Does not steam no more, used maybe 10 times already broken,
Hi -- For my White Wing Steam Cleaner: After I plug in the unit, and wait over 10 minutes, the Pressure gauge shows that the pressure at 2 (maybe 2.5, I can't recall as I'm typing today) -- not...
Re: Low pressure on WhiteWing steam cleaner
1. Make sure the safety switch for the hose handle on the right side of the hose handle is turned to the closed position. To do that, push it away form the hose.
2. Make sure the steam release button (next to the on/off button on the control panel on the steamer) is in the Off position.
3. Make sure the safety cap is tightened.
4. Make sure you have enough water in the tank (at least half a bottle of water)
I hope this helps.
Jul 31, 2011 | Vapor WhiteWing Steamer Canister Vacuum
Very little water comes out when handle compressed but no steam. what do I do? Machine is only about 6 months old and has been used maybe 4 or 5 times.
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the
Shark Manuals that you need.
heatman101
Nov 11, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I plug my Polti in and absolutely nothing happens, no lights come on nothing, I've changed the fuse but still noting
There maybe a broken switch or the motor may be burnt out. Take it to a used vacuum store and they will give you sound advice.
Oct 07, 2010 | Polti Eco Pro 3000 Canister Steam Vacuum
No steam. Feels a little warm at bottom of unit, but no steam. I've used this maybe 6 times. A. Cyr
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Sep 30, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
First time i used it
hmm....!! may u should check for 4 any manufacture covered plastic, did u try refering to the user manual ??
plz try it out !!
n also check for power supply regulations !!
thank u !!
Jul 16, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
