If I have a jumbo remote with the code search button button when I push it, the light won't stay solid red. What do I do?
antiochpc
  • 1314 Answers
SOURCE: Compaq Presario 4400us
Either the new power supply you purchased is not functioning correctly. But, assuming it is now that you are getting some form of power to your PC, it is very likely the motherboard. Whatever fried your old power supply (or it could have just been the power supply itself) most likely fried your motherboard in the process. Probably not the CPU since the MB can't even post.
Posted on Jun 21, 2007
SOURCE: code search-innovage jumbo remote /sharp television
code 118 116 101
Posted on Feb 01, 2008
SOURCE: Innovage Jumbo Universal Remote Control
If you don't have the code do this! I worked for me.... Hold code search until light stays on... then select item to program <tv, vcr, dvd,exct..>... then press power button once... It will blink every couple of seconds and run thru the codes it self..... wait for the item choosen to turn off.... Then quickly press enter... TADA PROGRAMED!!!!! continue for each item to be programed. Be patient there are up to 500 codes! Can take Up to 10 min, But better than wasting $10.00$ good luck
Posted on Aug 04, 2008
  • 5 Answers
SOURCE: Emerson Jumbo universal remote code search feature does not work
The Learn feature on this remote worked well for me. It takes a little time because you have to teach it the code for each button but it worked well for my cable remote, which I had never been able to get any universal remote to work with.
Posted on Jan 08, 2010
  • 74 Answers
SOURCE: TV won't turn on. Red light on front stays on
hi
this sounds like a fault on power supply board most likly a capacitor 1000uf 25 volt working> look on the power supply board the faulty capacitor will be enlargded on the top it might pay you to replace all the 1000uf cap,s onthe power board. regards windyhouse
Posted on Jun 17, 2011
Can't get my jumbo universal remote to work with my sam sung tv model #LN22B350F2D
You can use CODE SEARCH SETTING for the Jumbo Universal Remote. Have you tried it?
This is an alternative method to programming your device without using the code list. The remote control will scroll through the list of codes to identify the correct code for your device.
  1. Turn onthe device that you want to set.
  2. Aim the remote control at the device and press and hold down the CODE SEARCH button for at least 3 seconds until the red LED lights up solid red.
  3. Press the device button for the item you wish to program, e.g. TV,DVD,VCR, etc. and the LED light will blink once and then remain solid red.
  4. Press ON/OFF button on remote slowly and repeatedly until the device you are trying to program shuts off. (Note: LED will blink once each time you press ON/OFF button).
  5. Once this occurs, press ENTER button to store the code and the LED light will turn off.
Thanx
Jul 20, 2010 | Innovage Jumbo Remote Control
I would like the codes for the Innovage Jumbo Universal Remote
You can have the Innovage Jumbo Universal Remote search through its codes to find the proper one automatically. These are the steps to program it for a TV:
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
To program the remote for your VCR, repeat this process starting with turning the VCR on, then follow the steps substituting the VCR button for the TV button.
I hope that helps.
Nov 22, 2009 | Innovage Jumbo Remote Control
Need codes
The Toshiba TV codes for an Innovage Jumbo Remote are: 013, 049, 089, 105, 109, 117, 118, 120, 159, & 178.
If they don't work, you can try the auto-search function to see if aother brands' codes work:
  1. Turn on your TV.
I hope that helps.
Nov 18, 2009 | Innovage Jumbo Remote Control
Innovage Jumbo Universal Remote and Comcast Cable
I do not see Comcast cable codes in the manual, so I recommend using the auto-search function for both CABLE and SAT to find one that works for you.
To have the remote try each CABLE or SAT code it knows one at a time, follow these steps:
  1. Turn on your cable box.
  3. Press the CABLE or SAT button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the cable box turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the cable box turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
Nov 11, 2009 | Innovage Jumbo Remote Control
Unable to find code for time warner cable on the innovage Jumbo universal remote
I recommend using the code-search function of the Innovage Jumbo Remote for both CABLE and SAT to try and find the one that works with your Time-Warner cable box.
I hope that helps.
Nov 03, 2009 | Innovage Jumbo Remote Control
I have an innovage jumbo remote did not loose it!!! LOST THE DIRECTIONS TO PROGRAM IT.
You can program the Innovage Jumbo Remote by entering three digit codes, or by using the auto-search function.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
  1. Turn on your TV.
I hope that helps.
Oct 31, 2009 | Innovage Jumbo Remote Control
I need the codes for the jumbo innovage control for an advent tv.
I don't see Advent TV codes in the Innovage Jumbo Remote manual.
Here are the Code Search instructions:
  1. Turn on your TV.
  2. Press and hold down the CODE SEARCH button for 3 seconds until the red LED lights up solid red.
  3. Press the TV button on the remote. The LED will blink once and then remain solid red.
  4. Press the ON/OFF button on the remote slowly and repeatedly until the TV turns off. The LED will blink once each time you press ON/OFF.
  5. Once the TV turns off, press the ENTER button to store the code. the LED light will turn off.
Oct 11, 2009 | Innovage Jumbo Remote Control
Do you have innovage remote codes for Vizio VO320E
I don't see Vizio TV codes in the Innovage Jumbo Remote manual.
  1. Turn on your TV.
Oct 10, 2009 | Innovage Jumbo Remote Control
I need the codes for myInnovage Jumbo remote
To find the codes to program your dvd into the Innovage Jumbo Remote, you can look your brand of DVD up in a list, or you can use the automatic Code Search function.
  1. Turn on your DVD.
  3. Press the DVD button on the remote. The LED will blink once and then remain solid red.
  4. Press the ON/OFF button on the remote slowly and repeatedly until the DVD turns off. The LED will blink once each time you press ON/OFF.
  5. Once the DVD turns off, press the ENTER button to store the code. The LED light will turn off and your remote control is now programmed for that DVD player.
Hope that helps.
Oct 03, 2009 | Innovage Jumbo Remote Control
CODE FOR TDE SYSTEMS UNIVERSAL REMOTE CONTROL
CANNOT PROGRAM THE TDE SYSTEN=MS JUMBO REMOTE WITH CODES FOR A CITIZEN TV
Mar 01, 2009 | Universal Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
