Question about Hitachi Televison & Video
Have a hitachi ultravision tv model 53sbx01b no remote has a parental lock for channels can i reset tv without remote
  • Hitachi Master
  • 10,263 Answers
Try getting a factory remoter from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Posted on Jun 27, 2017
chris5563
  • 37 Answers
SOURCE: How to disable parental lock
You can try these codes 2211 or 3308 if they do not work you will need to reset the unit. You will need to unplug it for 45 minutes that will reset the TV to factory settings. Then the pass codes I provided should work.
Posted on Nov 07, 2007
ctf1800
  • 4402 Answers
SOURCE: hitachi ultravision
Check IC601, C603 for leakage, I601 and vertical pulse detector QN05
for poor convergence check RK42 for open circuit.
Posted on Jan 07, 2008
SOURCE: Un lock child Lock.
Press and hold the DISP button on your remote for 3 secs.
Posted on Mar 10, 2008
HAL DIE EPROME YT SIT AN TV VIR EEN SEC EN SIT EPROM TRIG EN SIT TV AN
Posted on Jan 31, 2009
How to solve Samsung 42" Tantus Parental lock problem
Posted on Apr 18, 2009
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Jun 28, 2008 | Sansui DTV2760 27" TV
Channels will not change with remote or at the TV controls
Have a close look at the owner manual or Google the model for one as many sets have a LOCKOUT that locks both the remote and front/side buttons on the set out.
Nov 04, 2012 | Hitachi Ultravision P50S601 50 in. Plasma...
I have a 50" hitachi ultravision HDTV model:
yes, unplug all power from the set for a while---may have had a power loss and the set reacted in this way.
Aug 31, 2012 | Televison & Video
I have a Hitachi Ultravision tv model #53SBX10B. When I turn it on it won't show a picture or sound. Can you help me solve this problem?
replace both of your STK ICs they will have part # on them STK392-110 use 150s Mats has them 1-800-628-1118
ICs are big black ICs
Sep 15, 2010 | Hitachi 53SBX01B 53" Rear Projection...
Manual menu button not working after adding channel-no RCA remote only disconnected DirecTV remote
Normally if you unplug the tv for 10 min everything resets, if not look behind for a reset button
May 13, 2009 | RCA F25216BC 25" TV
All of a sudden ...no sound
The Time Warner support walked me through getting my SAP turned off on the CABLE BOX.
Nov 06, 2008 | Hitachi 53SBX01B 53" Rear Projection...
Parental lock
Child Lock
Combos
OR TRY THIS..
CTC169AU
CTC185's
CTC203's
TX808 Chassis
Mar 26, 2008 | RCA TruFlat 27F520T 27" TV
Rear projection child locked
you had accidentaly enterd numbers into the tv and you do not remember.it dosnt matter what you do.you will never get it, the trick is that you will have to get the eprom or microchip lift off the set board to reset it self then put in back.that will solve your problem.good luck if you cannot do it get a tech.
Mar 26, 2007 | Hitachi 50SBX78 50 in. Rear Projection...
Televison & Video Logo
85 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
