Question about Frigidaire Freezers
We have a Frigidaire freezer that has a working light inside but has stopped freezing. Is there anything we can check to keep from loosing all of the items inside it?
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 9 Answers
I would check to see if the compressor is running(humming or making a continuous noise). The compressor is in the back of the freezer and approximately the size of a football.
If is not running but you do have power, there may be a problem with one or more of these:
The compressor
The Thermostat
The overload, relay, or capacitor
The defrost timer
The condenser fan motor
You might need to call a repairman.
You might
Posted on Apr 28, 2017
My frigidaire freezer is not freezing....the hi temp light is on. The model # is LFFU17F5HWH.
is the unit running, can you hear the compressor , it the freezer fan running check to make sure no wires have been pulled off
Apr 22, 2014 | Freezers
Hello Cory Mitchell - If your freezer is not cooling, it could have a floating restriction in the lines or something more complicated like an issue with the seal system that only a professional can repair. This can conclude the compressor not working correctly, the evaporator fan not turning, or even coolant in the lines at incorrect levels to properly cool. If the compressor was running, humming or even a little warm then that was typically normal. Also try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and the door. Now close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing. If it proves to be ineffective, connect with a professional to accurately pinpoint any potentially more serious issues.
Feb 13, 2013 | Frigidaire FFFC07M2KW 7.2 Cubic Foot Chest...
I have a Frigidaire upright freezer. Power coming into freezer. Light inside works, and the temp setting on the door works. Not getting any power through the system to the compressor.
Contact a professional. The power supply source needs to be testing to the compressor and see if the power is fine, or if the compressor is faulty and not drawing needed power.
Aug 15, 2012 | Frigidaire Freezers
It is not wanting to freeze. but it does keep things frozen. and some times water does come out at the botton
Check that it set cold because its not below -2 or -5 thats why dose not freeze anything it needs to be at least by -10 to -18
Jun 04, 2011 | Frigidaire 14.1 cu. ft. Upright Freezer...
Moisture forming on inside of freezer
is there anything that's preventing the door from fully closing( too fully)? the door gasket might be the culprit (problem).
May 04, 2010 | Frigidaire 13.7 cu. ft. / 388 liter...
Not freezing
Check your circulatation fan. It may be stuck. Keep me informed The Raz Shack
Apr 20, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Alarm goes off and freezer not cold
The light indicates the need for a new battery (9V)
Jul 21, 2009 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Frigidaire twin freezer not working
Check the freezer back wall for snow or frost.If it's there you have a defrost problem.
May 25, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
someone suggested to me the other day to put weter foods closer to the top the ones with dripin water and more solids down at bottom they said this changes the climate inside to be more economical
im just passing this info cause ive never had or been in contact with a upright freezer
May 13, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer not keeping items completly frozen
thius suggests the defrost system not working and the defrost drain blocked. take off the back panel inside the freezer, melt off excessive ice and free the drain at the bottom with hot water and patience
Apr 30, 2007 | Frigidaire 13.7 cu. ft. / 388 liter...
Freezers Logo
69 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
