My screen is flicking on and of - Computers & Internet
Flicking screen on Samsung UN60FH6003F, replaced main & power board and LSVD cable.
Check out the inverter board. It supplies the backlighting on screen so you see picture. If it is messed up it could be responsible for the flashing. Assuming you see a normal picture in between flashes!
Dec 08, 2015 | Samsung Televison & Video
Flicking screen
Could be the invertor, bad connection or GPU issue. Try an external screen. That will point you in the right direction.
Dec 16, 2013 | Dell Latitude D520 Notebook
Motherboard problem
I would suggest buying a cheap Graphics Card, You will have more control over the graphics output and the system memory will increase. By using the onboard graphics you are eating into the System RAM and if you have only the minimum system Ram then your system will be slow.
Jan 21, 2012 | ASUS M2N68-AM SE2 Motherboard
Initially, on turn on, the screen would flick white and keep flicking white until its turned off. Normally after waiting a few hours, seems to work OK, but now, it won't even turn on/power up even if...
If both screens flased and then it went off the logic board has failed, but if it was just the top screen flashed the bottom screen is faulty and needs to be replaced. can you post back and tell me which one one it was.cheers.
Feb 04, 2010 | Nintendo DS Lite Console
Flicking on and off
If the LCD screen flicks on and off and you can see a dim image on the screen when you view at a sharp angle, then most likely you have a faulty inverter or a faulty CCFL lamp.
Check out LCD Parts for service, parts, DIY info. Use this Link :-
www.lcdparts.net
Sep 11, 2009 | ViewSonic VE710S (Silver) (Black, Silver)...
Screen flicks black every so often
check control panel for screen refresh rate .and change rate too see if that helps.
Apr 28, 2009 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
