Question about Pasquini Coffee Makers & Espresso Machines
Replacing group head gasket on a pasquini livia 90
  • 1089 Answers
SOURCE: need a manual for Pasquini Livia 90
Hi I have one that I wrote if you want it. Send me your e-mail and I'll sent to you.
Posted on Jun 10, 2009
mrpsespresso
  • 16 Answers
SOURCE: Pasquini Livia 90 - No water from the group head
The problem could be calcium built up blocking the jet and stopping the flow of water through your 3 way solenoid valve.
Otherwise the 3 way solenoid has stopped working. The 3 way valve part #91004 is $105 + shipping.
If you capable of removing the top and 3 body side of the machine, you can contact me and I can walk you through diagnosing if this is the problem with the jet or the valve. Before you call, make sure you have a philips screwdriver, 14 and 15mm open ended wrench or crescent wrench, flashlight, and paper clip.
My experience is working over 10 years at Pasquini as a master technician running the home repair sales and service center.
I stock all Pasquini parts for any service of your Pasquini espresso machines and grinders. Contact us for any of your Pasquini sales and service needs.
Posted on Nov 15, 2009
  • 1089 Answers
SOURCE: After several failures, I replaced
Hi
Check the wire on the water reservoir to make sure that it is properly connected.
Check to make sure the wire connection is clean and making good contact.
If the machine turns on the connection is dirty, so you will need to remove nut and clean.
There is a level probe on top of the boiler (actually 2) The right one (yellow wire) is the low level probe and it will not let the boiler turn on unless it sences water at the probe. If it is scaled it can't tell if there is water in the boiler and the element will not heat. Remove and clean the probe.
Posted on Jun 03, 2010
  • 1089 Answers
SOURCE: pasquini service in washington dc
Hi
If they are blinking slowly check this. Check the wire on the water reservoir to make sure that it is connected. You can try grounding this wire and see if the machine responds.
Water level may be low in the reservoir. Are you using distilled water or reverse osmosis water. Don’t. The computer can’t tell if have water in the reservoir, because it need’s minerals to conduct the small current for the computer. If they are blinking fast you may need a new computer.
Posted on Jul 04, 2010
guru_fixya
  • 944 Answers
SOURCE: My pasquini livia machine is
You have to take apart the system for changing the gaskets.If you are not a technical savvy don't try for it.Here is the parts diagram for your machine.Many of my fixya customers took apart the system to change the valve and they suffered a lot to fix it again back.All the best.
1 Boiler end gasket 11 Expanse Valve 21 Group gasket 2 Heating element 12 Drain 22 Refill solenoid 3 Gasket for above 13 Pressurestat 23 Group touch pad 4 Steam + water valve 14 Main switch 24 Drip tray grill 5 Pop off valve 15 Group 25 Water flow meter 6 Bleed valve 16 Group solenoid 26 Drip tray 7 Water level Probe 17 Group handle 27 Basket 8 Auto refill relay effect 18 Filter basket single 28 Steam-water valve knob 9 Heater exchanger injector 19 Plastic gasket 29 Manual refill valve 10 Heat wand 20 Site glass 30 Shower screen
the gasket look like this.I will cost around 12$.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Jan 03, 2011
Direction replacing goup solenoid
As you have put it water flows from boiler to group head so the arrow on the solenoid should be this direction.
Aug 15, 2012 | Pasquini Livia 90 Espresso Machine
Water gushes out of the group when back washing.
If you replaced the group gasket, then you might want to check the top of the blind filter basket to make sure it has no dents. If you were having the same problem while brewing espresso, I would say carefully remove the gasket and clean the head thoroughly then use a mirror and check to make sure there is no coffee or small pieces of rubber in there then put the gasket back on and try to brew a coffee. Since the problem is only happening when you backwash the only thing different is the basket.
Jun 04, 2012 | Pasquini Livia 90 Espresso Machine
I have a Pasquini Mod. LIVIA 90 120V 1200W. When I insert my group handle completely to the right to make coffee, it will slide to the left or comes out when it is inserted most of the times. Even if...
Hi
Yes you need a new gasket. They will normally last no more that 1 year. It's best to order 2 gaskets so you have one on hand when this happens, so you don't have to wait for the new gasket.
Aug 23, 2011 | Pasquini Livia 90 Espresso Machine
I need the parts diagram for the pasquini livia 90
I found something on amazon, click here and take a look: Amazon com pasquini livia 90 parts. I hope this was helpful. Cheers
Nov 18, 2010 | Pasquini Livia 90 Espresso Machine
The portafilter basket leaks out the sides no matter how firmly held in place or the quantity of coffee in the basket
Hi
You need to replace the brew head gasket. It becomes hard and will not seal. Order 2 gaskets because 1 always fails on Friday before a big party on Saturday.
Nov 29, 2009 | Pasquini Livia 90 Espresso Machine
The handle is leaking water
Hi
Your brew head gasket needs replacing. They get hard after about 6 months to a year depending on how long the machine is on. if it on 24/7 it need to be changed every 6 months. If turned off daily every year. The gasket is up where you install the portafilter to make espresso. The black ring is rubber and that is what need to be changed. Have one setting right here on my desk.
Nov 09, 2009 | Pasquini Livia 90 Espresso Machine
Filter basket sticking in the group head
It sounds like the solenoid is not discharging after a coffee is made, try back washing machine with purocaff. If the soap comes out of the small pipe on the right and dumps into the drain tray you are back in business if not you might to clear the pipe.
May 11, 2009 | Pasquini Livia 90 Espresso Machine
Leaking from the grouphead
The fix to this problem is replacing the group head replacement done every 8 months to a year. The part number is #90907 $4.50+shipping and I have this in stock.
Feb 18, 2009 | Pasquini Livia 90 Espresso Machine
Oct 18, 2008 | Pasquini Livia 90 Espresso Machine
Coffee Makers & Espresso Machines Logo
78 people viewed this question
Top Pasquini Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Steve
De Brewerz
De Brewerz
Level 1 Expert
Are you a Pasquini Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
