Question about Raypak Pool & Spa
I have raypak 2100 heater model pr265al-en. Its leaking water. Please help on what to look for. Mom and I live alone & last 2 times I had problems they almost scammed us.Please help,can I fix myself?
    New Friend:
  • 66 Answers
If your lucky its leaking from the drain plug or pressure switch. Take the sides off the heater. If its a simple fix you will now be able to see the leak, and should be able to make the repair yourself. if not it is undoubtedly the heat exchanger. Rheem/Raypak calls it tube bundle. I suggest a repair technician for this as there is internal parts to inspect and look for proper operation.
At least now you will have the knowledge beforehand when the technician comes and says its a 1000.00 repair its not a simple lucky fix he should have caught for a faction of the cost.
Posted on Apr 29, 2017
remove side by plumbing it has wires going to it and threaded into header
Mar 30, 2013 | Raypak Pool & Spa
Heater is corroding pilots at an alarming rate..........1 per there a potential fix or is it time to replace
check for leak in heat exchange if ok then if water is under 70 degrees it will condense and rain down on the pilot generator
Jan 21, 2013 | Raypak 2100 Pool Heater Gas 266000 BTU'...
What is causing the "shorted on water sensor"?
I have a RayPak 2100 heater and I have the following error:
Water sensor shorted. How do I resolve the problem?
May 31, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
Raypak 2100 pool heater won't heat, PRS and HL2 error codes.
Well, I replaced the pressure switch with no joy. I tried all 5 levels of pressure 1-5 and every wiring combination. Finally, I returned the new $70 pressure switch and took the 2 wires and tied them together (jumped them). Here's the only downside...If you run your pump in backwash, recirc, waste, or any mode that would cause water to bypass the heater it MUST BE OFF. Otherwise, let it ride. It's working great and I hope to go into October weather permitting.
May 11, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Service light comes on our Raypak RP 2100 pool heater.
this usually indicates a high limit must first ascertain if you have a component failure or a true high tempature condition.your model has 2 limit controls and they are both located in side panel on water in/out header
Sep 16, 2009 | Raypak Pool & Spa
Raypak 2100 ignites then it turns off or shakes bangs HL1
Check the bypass in the header for damage. HL1 along with the banging/popping is too low of water flow through the heater and the water is getting to hot.
Sep 06, 2009 | Raypak Free Hydraulic Lift Gate Delivery -...
Pool & Spa Logo
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
