Question about Emerson Televison & Video
Emerson 32" HDTV hdmi tv won't pickup antenna channels after scan. It says no channel registered . How do I fix this.
  • 362 Answers
SOURCE: Toshiba 26AV502U Won't Pick Up Channels
Hi albertogiler, I am happy to help, you will need to attach a antenna to the tv to pick up OTA over the air signals, depending on your location you may be able to use a set of rabbit ears, I have provided a link to a site that will explain in depth. http://www.antennaweb.org/aw/welcome.aspx
Let me know if this helps and please rate this solution. lone99star
Posted on Jan 13, 2009
  • 5188 Answers
SOURCE: can't get all digital channels
There are several possibilities assuming you have an outdoor antenna with the amplification. You are too far from the transmitter or the station is still on a low power digital transmitter until the analog broadcasts end. Additionally, there may be buildings, hills or trees in the way. The first one is called the digital cliff - you either have enough signal for your tuner or you don't. Some stations may need to add transmitters to cover the secondary areas that could still receive the analog signal. The second possibility will either resolve on Feb 18 or June 12 or anywhere in between. (It will depend on your station and the Digital TV transistion delay bill. Some stations are changing frequencies with the transistion and can't go to full power until another analog station moves its frequency.) The last one can't be resolved.
If you have an indoor antenna, you can try moving it around to get better results. My household has an amplified outdoor antenna with a rotator to get the antenna to line up with the signal. We have two analog stations that give problems when we look for their digital signals. We hope the issue will resolve with the changeover since we have seen the signals on both stations improve when they wanted to broadcast football games.
Posted on Feb 07, 2009
SOURCE: I have a Westinghouse 26 inch TV.
I carried my Westinghouse TV to the basement. Unplugged the antenna from the digital converter box and connected it to my digital TV. I then re-scanned for channels and found channel 9. After carrying the Westinghouse TV back upstairs, I connected the original set-up and tuned to channel 9 which was now showing on the screen as no signal. From that point I moved my VHF dipoles until I had located the correct position for reception. A little labor intensive, but I was fortunate to have another antenna that was receiving channel 9.
Posted on Feb 20, 2009
  • 45 Answers
SOURCE: no tv signal on my olevia 232-s12
cable or Ant.. ? after the scan if there is no channels found (0 digital, 0 analog) then try with cable or Ant to see if any of them work.. if they still don't pick up any channels and the whole yellow progress line goes across.. then it sounds like the tuner on the tv is bad.. and the tuner is part of the main-board so the whole main-board will have to be exchange or repair.. contact Amergence technology they are a 3rd party repair center that service Olevia TV's and they will be able to give you an idea on the repair cost..
<<< Amergence Technology number is 866-965-3842 >>
Posted on Jul 28, 2009
SOURCE: Dynex 32 Inch Installation Problem
Hi I Just Bought A Dynex 32 Inch HDTV. I Did A Auto Scan And It Didnt Pick Up Any Digital Channels? Am I Suppose To Have An Antenna Or Digital Box? How Do I Get Th Channels To Come In?
Posted on May 03, 2010
HDMI input works ok. Hooked up external antenna. Did channel scan. It will only scan for analog channels. Has analog raster on screen. It has no information on menu page for digital channel scan.
do you have the air option in the scan menu see
http://tv.manualsonline.com/manuals/mfg/sanyo/dp42841.html
page 9 important fact cable digital gets wiped by air digital channels
You may be able to get around this via a digital hd tv decoder box and then have it on a hdmi input on the TV as a backup to the cable if you can't have both cable digital channels stored and aerial digital channels stored
Oct 09, 2016 | Sanyo DP42841 42" LCD TV 1920x1080,...
After scanning channels tv still does not have picture or sound
What type of input and what type of cable have you set to ?
(a) Antenna - Coax cable (75 ohm)
(b) STB - HDMI
(c) DVD - HDMI or
(d) DVD - Red+White+Yellow
(e) DVD - Red+White+Optical (if your TV and DVD support it)
Most TV cannot find any channel when scanned without a proper external /internal antenna
Aug 11, 2016 | Element Electronics FLX-3211B 32 in. LCD...
Hdmi cable for 40" led TV WHAT ARE THEY FOR
The hdmi cable is used to connect the tv to devices so it can be displayed on the tv. Devices such as, but are not limited to, computers, bluray/DVD players, gaming consoles, etc...
For channels, you have two options.
1. You would need to purchase a cable package from one of the options in your area. They will run a line I to your house and provide you with a cable box in which you connect the cable box to the tv via hdmi cable.
2. You can purchase an antenna and plug it into the tv. Run the channel search and you'll have those channels. Some TVs may have built in antennas but if yours doesn't, I'd go for a simple antenna from target or best buy. Or you can purchase it online.
Thanks!
Sep 22, 2014 | SEIKI Digital SE40FY19 40" LED TV...
I cant pick up any channels on my 32'' Emerson hdtv with my channell scan
Did you select antenna in the setup menu?
If you did and still can't receive anything you may not be receiving signals strong enough. Read the setup instructions in the manual. link below.
LC320EM9 EMERSON LCD TELEVISION Manual
Sep 09, 2014 | Emerson LC320EM9 32 in. LCD HDTV
The tv keeps saying run auto channel scan
I have run the auto scan many times and it never finds any channel. I found that you have to put it on the HDTV, PC, AUDIO channels in order to watch or connect anything on the TV. Try doing that.
Sep 13, 2013 | Proscan PLDED3273A 32" LED 720p HDTV with...
I know this tv has digital capabilities, so i don't need to get the digital box, what do i need to watch my local channels? i have directv but does not include local channels (ie. fox, abc, nbc).
Hello
To tune the local channels do the following.
1 Press the MENU key on the remote control to
display the Main menu.
2 Use the CURSOR "UP" or "Down"
keys to highlight
Manual Channel Search. Press ENTER.
3 Use the CURSOR "Up" or "Down"
keys to select Cable,
Air (Antenna), or Digital Add-On.
After the search is complete, the HDTV will exit the
menu system and return to normal TV viewing.
IMPORTANT FACT: This HDTV maintains only one database
of digital channels. Therefore, when you search for
cable channels, the database of antenna digital channels
will be deleted. You will only be able to receive those
ClearQAM channels your cable company provides.
NOTE:"Not available" will appear on the screen
when an option is unavailable.
TUNING MODE UNAVAILABLE MENU OPTION(S)
Analog RF Digital Caption
Digital RF None (all Menu options available)
Video 1 Manual Channel Search, Channel Scan
Memory, Digital Caption
Video 2/3 and Manual Channel Search, Channel Scan
HDMI 1/2 Memory, Digital Caption, V-Guide
OK.
Feb 08, 2011 | Sanyo DP32648 32 in. LCD TV
Nov 28, 2009 | Televison & Video
I have a 32" Toshiba 32AV500U 32-Inch 720p LCD HDTV along with a HDTVi VHF/UHF HDTV Indoor Antenna. I purchased the TV and antenna about a year ago. I am unable to get any digital TV, only analog. I was...
Look in your manual for a channel scan entry. It should be an item in your setup menu. What this does is re-scan for all the signals it can receive.
Once the scan is done, it should display all the channels that are viewable in your area
Jun 20, 2009 | Toshiba 32AV500U 32 in. LCD HDTV
Televison & Video Logo
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
