Question about Garden
Have a kohler model cv740 was running shut off went to restart kicked back then poped back out exaust seem like out of time replaced the SAM with new coil package same trouble
  • 48 Answers
SOURCE: honda cr125 86, engine kicks back
timing it"s all in the timing when it stalled it jumped time
Posted on Jan 13, 2009
woobie dog
  • 1273 Answers
SOURCE: 1976 JD 214 lawn mower Kohler engine K321AQS
When it shuts down crack the fuel cap and listen for the woosh of a vacuum on the fuel tank. If you hear this, clean the pinhole vent in the fuel cap, or replace it. Being partially plugged would cause you to be starved for fuel and could explain your issue, and why it goes away after a period of time.
Regards, --W/D--
Posted on Jul 19, 2009
SOURCE: Brother's Craftsman 22.5hp Kohler engine starts an...
Kohkler engine 22.5 hp will not restart in the morning,unless you shot some start fuild in the air cleaner
Posted on Jun 29, 2010
  • 289 Answers
SOURCE: My 1996 E250 4.9
I am running out of timr so please, sorry.
Replace the fuel filter.
Posted on Sep 26, 2010
emissionwiz
  • 76846 Answers
SOURCE: Still trouble with my 2001 Ford Windstar after replacing spark plugs and wires. It always starts instantly though still running a little rough. Sometimes the power doesn't kick right in to climb
I would suggest you run a compression check on this engine and also have the coolant recovery tank tested for the presence of combustion gases with a gas analyzer, any gases would indicate a leaking head gasket. Any engine cylinder that is lower than 5% of the highest reading cylinder in pounds per square inch has a problem like a scored cylinder or leaking intake or exhaust valve seat.
Posted on Jun 18, 2012
Exaust is getting extremely hot just from cranking it over,,and its doing alot of poping through exaust and carb,ive checked all timeing ,new plug cleaned carb could it be valves
Yes it could be valves. I will need to know the make, model and serial number of engine. On Briggs and Stratton engines these numbers are typically on the top of the valve cover or on the very front hidden just under engine shroud. It may read model, type/code. If its a Kohler it will read family, serial, etc. If you can provide these numbers I can help.
Sep 11, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a craftsman riding mower with model number 917.257552 and a kohler engine of model number CV14S and type number 1452. I have used it for 16 years and never had any trouble. Recently I had some...
Russ, it sounds like the needle is bad in the carburetor. if it dont seal right it will allow fuel to seep into the combustion chamber creating a hydro lock as some call it. the engine will seem tight and wont start also blow fuel out the exhaust. to fix this you will have to take the carb off and clean it real good and put a new needle in it it will run like new. good luck
May 19, 2017 | Garden
Kohler confidant 4 generator will not run.
i got the same gen and with the same problem
mike
Sep 24, 2009 | Kohler Electrical Supplies
Car spits and pops like the points are bad in a 60s car.no power
Yes these optispark systems had all sorts of problems in wet weather most of the time you could replace the cap portion and that would solve it but most of the time I would replace the whole thing including new plug wires, coil wire,and spark plugs .Due to the fact that you have to remove water pump to access opti spark
Sep 01, 2009 | 1995 Chevrolet Camaro
Kohler engine wont recharge on tractor
Either the stator went out or the voltage regulator is faulty and must be replaced
May 29, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Server shuts off.
pls try to chek to power pack for malfunctioning if it is replace the power pack with a better one
Apr 03, 2008 | Dell PowerEdge 2600 Server
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
