Question about Garden
Where is the carb inlet screen on my troybilt tb6044 xp
I have a Troy-Bilt XP grass trimmer...only run on full choke, I replaced the fuel filter because there was plugged.Still no help. I ordered a new carb and replaced it and still had the same problem.
When you installed the new carb did you adjust it for your engine? Idle control, idle mixture, fast misture? Running only with choke indicates that engine is not getting enough gas routinely via the main jet.
Sep 22, 2017 | Troy-Bilt Garden
Which fuel line is the intake line at the carburetor?
The fuel line goes:
  1. From the filter in the tank to the carb, usually the bottom most connector.
  2. From the carb to the Primer. The tube in the center of the primer bulb.
  3. From the primer, outer tube to the fuel tank.
Get the manual online from Troy-bilt herehttp://www.troybilt.com/equipment/troybilt/tb146-ec-4-cycle-garden-cultivator
j
May 07, 2014 | Troy-Bilt TB146 EC 4-Cycle Garden...
Troybilt push mower will not start
Might be bad gas. Empty tank refill with fresh gas with Stabile. Might have to remove carb bowl clean and reinstall. Flush out tank with a little gas before refilling, disconnect fuel line to flush.
Aug 24, 2012 | Troy Garden
I have a troybilt lawn mower has a 17.5 briggs in it has ohv my question is how to check to make sure its still in time
You can do a quick check, bring the piston up to top dead centre non compression stroke, at this point the exhaust and inlet valve should be rocking if not the valve timing is out.
Jul 01, 2012 | Troy Garden
I have a troybilt xp 2600 with honda engine,when i turn on the fuel petcock valve fuel drips directly in back of air filter.anyone familiar with this type of issue?
This sounds like a foreign object in the fuel inlet valve. You will need to go through the carb and clean/replace parts as needed.
Feb 18, 2012 | Garden
I have a troybilt mower with a honda 160 engine (#gcv160an5a) that will not start. I have cleaned the carb, replaced the spark plug, cleaned the air filter, new gas and oil. The spark plug is dry after...
You may have to replace the carb.But before you do.Check the the fuel line.There is a small screen in the carb,it may be clogged.Inside the tank is a small cylindrical filter,make sure it is good.Break the fuel line at the in line filter,to make sure gas is getting to there,if it is the problem is in the carb.
May 20, 2011 | Honda Garden
My Troybilt starts, idles, then stops. What is
1st thing to try is clean and rebuild carb(easy job) ...good luck
Apr 07, 2010 | Troy Bilt 5.5hp Self Propelled Mower
How come there are no manuals for the troy-bilt Model#303531 / TB340 XP? Not even on TroyBilt website.?
The unit may say "troybilt" on it but may have been made by another company, like MTD, RYOBI, or Homelite. Check out those manufacturers.
Sep 25, 2009 | Troy Garden
My troybilt wont run smooth
First: You will want to check the fuel lines for cracks/breaks. They become brittle over time.
Next: Disassemble the carburetor and spray with carb. cleaner. Make sure that the small screen in carb. is free of debris.Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb.
And finally: If neither one of these solutions solve the problem, then you will need to buy a carb. kit and replace the needle valve, gasket(s), diaphragm, and small screen.
If you need further assistance, just let me know.
Jim
Jun 09, 2009 | Troy Bilt Tb70ss Gas Trimmer
Troybilt 6.5 briggs won't start floods gas
if it sat more than 3 months with out being started it needs a carb clean this can be done in an hour if your at all mechanically incline
1. remove carb and take it apart
2. buy a can of carb cleaner
3. spray carb cleaner in every hole ypu can find
4. becareful around rubber with carb cleaner it will swell it up
5. put carb together and reinstall
if the inside of carb is real bad get a rebuild kit and replace the parts
Apr 13, 2009 | Garden
Garden Logo
57 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
