Set_er_prt_cart - Office Equipment & Supplies
I do not have Prt Scr on my laptop, is a HP G61. I tried Fn+ Ins but it doesn`t work. Can you help me ? Thanks
There are two Home keys.
Go to the Home button to the right, of the Delete key.
(Which is to the right of the Insert/Scroll key)
Has prt scr under Home.
Also use Fn key.
(I just used the Zoom In feature. You just set your mouse cursor in the middle of the photo, then move mouse cursor around)
Mar 25, 2013 | HP Pavilion G61336NR Notebook
Lexmark S405 false empty cartridge
Update your printer firmware . If you'er still having problems, try replacing the cartridges (please make sure you're using genuine Lexmark cartridges). Compatible or non genuine Lexmark carts may or may not work with the printer.
Sep 05, 2012 | Lexmark Interpret S405 Wireless All-in-One...
The color on my Phillips 60 rear projection big
that means that the phone needs to be unlock by the network provider
Mar 13, 2010 | Philips 60PP9202 60" Rear Projection...
My new computer won't print using the ''Prt Scr'' key
Sorry, I did not mean for my post to be a clarification request.
Sep 15, 2009 | Computers & Internet
How to use tax buttons on victor 1208-2 calcutator
1. Slide the "Rate Set/Item/PRT/On/Off" switch to "Rate Set" position
2. Enter the rate value.
3. Slide the "Rate Set/Item/PRT/On/Off" switch to "PRT" position.
You can also dowload the instruction manual
Jul 26, 2009 | Victor 1208-2 Calculator
Yamaha RX-V995 receiver turns on & then powers off 2 seconds late
I suggest you run self diag.  press [FM/AM] key + [Input mode] key and press the [power/standby] switch.
ps prt = power supply problem
dc prt = shorted output or leakly cap in channel
tmp prt means to hot on heatsink
you'll likely have to measure the resistances of the output FETs to find a short,
Jan 02, 2009 | Yamaha RX-V995 Receiver
Hp printer will not print through the computer
Sometime USB PRT they reinstall a new PRT with a new usb port.
Check if you have a new entry w same prt name+ copy n inside your Control panel "Printer and faxes "applet.
Select the new Prt (with latest Copy N number) as Default printer and let me know if it's working.
Dec 28, 2008 | Office Equipment & Supplies
Printer is not communicating with computer
USB printer sometime reinstall themselves using a different USB port.
1 ) Check if you have multiple prt in your "settings"/ "prt and faxes" presenting same description + (copy n)
2 ) use as default the printer with the latest and highest number of copy.
You can remove all other copies with same model description.
Dec 28, 2008 | Adobe Photoshop 7.0 for PC
