Question about Generac Electrical Supplies
I have a 17kw Generac standby generator with Nexus control and 16 circuit panel board .It says utility power lost then counts down to 0 and starts up even though there is utility power present
  • 4 Answers
Most likely your fuse(s) are/were blown in the transfer switch. Control/Sensing wiring may be inadequate or simply not installed. May have control board failure.
Posted on Oct 27, 2017
    Sergeant:
  • 202 Answers
Something might be wrong with your automatic transfer switch.
Posted on May 02, 2017
Generator hard to start and sputters like its missing
About 15,000 results (0.73 seconds) Search Results
    2 - Generac : Questions, Answers, How To, FAQs, Tips ...
    answers.generac.com/answers/1506-en_us/searchquestions.htm?...
    Can I run an 8kw standby generator on a 100 lb propane tank? 2 answers ... What am I getting for the extra cost of the Guardian unit? ... The engine starts hard and runs rough. 1. Air ... On auto start, unit sputters and I smell gas. ... Does the gas and electrical feed into the unit from the back as previous air cooled units?
    2 - Generac Questions and Answers
    answers.generac.com/answers/1506.../generac.../questions.htm?...
    On auto start, unit sputters and I smell gas. .... The 20kW automatic standby generator has the option to delay start up during an ... This is for a guardian 20kw. ....has been designed to make the battery installation and removal so difficult? ... The air cooled generators are designed to allow for the smallest footprint while still ...
    3 - Generac Questions and Answers
    Generac's Guardian Series 17kw automatic standby generator does not come with a.... The automatic response features of our air-cooled units initiates the unit's startup,.... This week I tried the same and it tries to start but just sputters and fails until .... A C delayed start still chocks 17kw generator would a hard start kit help?
    On auto start, unit sputters and I smell gas. On manual start ...
Feb 08, 2016 | Generac Guardian Air-Cooled Standby...
Why does it crank and almost start on 1st try?
Generac Generator Troubleshooting - YouTube
? 1:39
https://www.youtube.com/watch?v=AKN2dc59cxY
Dec 20, 2013 - Uploaded by Appliance Princess
I want to learn about Generac generator troubleshooting. ... I have a 16 kW propane fueled standby air-cooled generator. ... I have a brand new generac 20K guardian Evolution and the first time my power went out my generac ...
Generac Power Systems - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Utilities
Rating: 1.3 - ‎26 votes
Hey, Generac, make a change and start making generators that work, don't cost .....Standby generators are not supposed to be used as a primary power source ... and three months ago, I spent $4,000 to have a Guardian generator installed at ...
Generac standby generator - Propane - wont start?? - DoItYourself ...
www.doityourself.com/.../487838-generac-standby-generator-propane-w...
Feb 4, 2013 - I have a Generac 4LM41A standby generator that I need help introubleshooting and repairing. It is about 12 years old and hasn't been used ...
141 GENERAC complaints and reviews @ P'ed Consumer
Dec 12, 2015 | Generac GUARDIAN Standby Generator 10 kW/9...
Generac 17kw standby generator, starter will not engage into engine, just spins
If it spins and will not engage it needs removing and the bendix gear on the starter is probably worn or damaged
Aug 05, 2013 | Generac 100 Amp 120/240-Volt Transfer...
No lights are lit on my Nexus Remote monitor for my Generac standby generator. The generator is working - just went through the testing cycle. Batteries are less than 6 months old. Maybe I need to...
batteries only last about 3 months on these units. make sure you are within 20 ft of the generator and put in new batteries. The green light will blink is a minute or so.
Apr 23, 2011 | Generac Power Systems Generac 5928 Nexus...
5875 generac starts running when switched to auto , Utility is hot .. using nexus smart sw.
Check the N1 N2 fuses in transfer switch one or both of them are probably blown. N1 N2 fuses have the yellow wires on them if they are blown the generator thinks there is no utility power and will start There needs to be 220 volt on them .
Oct 31, 2010 | Generac Guardian 200 Amp Transfer Switch...
I bought a Generac 17kw with automatic transfer switch. I would like to use a 200 Amp manual throw transfer switch. The generator came with a pre wired sealtite pig tale and junction box. Inside the...
If you are using a Manual transfer switch, then you should manually operate the system. Why don't you use the switch it came with? Why would you use a 200a manual transfer switch on a 17kw generator? The idea is to move your critical circuits into the transfer switch panel. Then it would operate in auto.
Jul 02, 2010 | Generac Guardian 200 Amp Transfer Switch...
Generac gardian model:005885-0 running rough
Check the spark plugs, ignition coil etc and try to start it manually.
Jun 15, 2010 | Generac Guardian Quietsource 25,000 Watt...
Generac 4456 does not start on power loss
I install and work on these everyday. If you hooked up the transfer switch you probable have a control wire wrong. check the utility power sense wire. That lets it no when to start in auto. it could be a relay or fuses. or a control board.
Jul 01, 2009 | Generac Guardian 200 Amp Transfer Switch...
Generac control wires
just 4. I install generac switches and generators
Apr 17, 2009 | Generac 100 Amp 120/240-Volt Transfer...
Electrical Supplies Logo
216 people viewed this question
Top Generac Electrical Supplies Experts
 Kenneth
Kenneth
Don  Farrell
Don Farrell
Ottoniel
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
