Question about Amana Washing Machines
Amana 7300 washer, the fabric softener bay is filled with water after every load. Never used to happen
zeusfaber
  • 247 Answers
SOURCE: Bleach and fabric softener dispensers full of water
This is a problem common to virtually all front-loaders. Pull the dispenser drawer right out (it is designed to come right out - you might just need to give it a bit of a jiggle to get it past the stop) Remove the cover/caps from the drawer (sometimes this is a snap-on cover over the back of the drawer, sometimes a top-hat shaped cover over the siphon spigots). Give everything a thorough clean off with hot water (scrubbing with an old toothbrush helps), then reassemble. A.
Posted on Jul 16, 2007
SOURCE: fabric softener dispenser is filled with water
I had this same problem. I found a repair manual online and found out how to get into Service Test Mode. There is a test (t12) for the dispenser motor/mechanise. Running this test basically just runs water through each of the dispenser compartments (prewash, wash, bleach, fabric softner). All ran fine - no error codes. I continued to run the test on the fabric softner dispenser repeatedly and after 5-10 cycles it started draining properly. I think a tube (or valve or opening) was just clogged with the built up softner. I also put some vinegar in the compartment a time or two just to clean out any residue. Be careful with the Service Test Mode - read directions carefully - the manual warns that if you don't get out of it corretly that it can lock up you washer.
Posted on Sep 02, 2008
beltronic205
  • 1466 Answers
SOURCE: fabric softener will not drain
Try cleaning out ..this should cure . the other thing that can cause this is a faulty solonoid valve as some machines have a seperate valve for this action....
Posted on Nov 25, 2009
  • 256 Answers
SOURCE: fabric softener dispenser fills up with clear water after
Purchase some fabric softener and place it in its normal location at the beginning of the cycle. At the end of the cycle check to see if fabric softener has been dispensed and whether there is water in the cup.
If the fabric softener is gone, but there is water in the fabric softener cup, then your problem may be with the water valve assembly. The water valve assembly (as one complete unit) has a separate solenoid for hot and cold water temperatures, bleach and fabric softener. The fabric softener solenoid on the water valve assembly could be defective (allowing water to fill the fabric softener cup).
Contact an appliance service company.
Posted on Feb 17, 2010
SOURCE: kenmore 3.5 super capacity front load washer won't dispense fabric softener
Kenmore 110 front load washer wil not dispense fabric softner. Code 21. Have already checked pump and filter obstructions
Posted on Apr 18, 2010
How do I get the fabric softener dispenser to keep from filling with water?
Remove dispenser and clean the drain hole from under neath try with q tip.sounds gunked up.
Sep 01, 2014 | Frigidaire Affinity ATF6000F Front Load...
Strange yellowish circle appearing on white shirts
i believe the stains are actually semi burn marks. If you are drying your whites try a lower heat setting. i had this problem with my kenmore dryer before too. Got bad especially with towels. Make sure your vent is not clogged and your filter is cleaned regularly to let the heat flow better. should help.
Sep 17, 2007 | Whirlpool LER8648L Electric Dryer
Front load washer dispenses fabric softener drawer fills water
either the auto dispenser is sticking , take out and clean with hot water. Or flow control valve needs replacing.
Feb 24, 2014 | Bosch Washing Machines
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
Oct 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
How to add fabric softner to the amana washer with locking lid
Check and see if there is a cup in the top of the agitator. Some machines have you put it there, turning back and forth during wash doesn't bother it, but the spin to empty the wash water causes the softener to go out through slots in the top of the cup and be held in the agitator. when it stops the softener drains into the tub, ready for the rinse cycle.
May 30, 2012 | Amana Washing Machines
Fabric softener premature release
In my case it was simply a matter of cleaning the nozzles that spray the water into the MAIN DETERGENT compartment. Turns our that when the washer was filling up, some nozzles were partially clogged and were directing water to the side where the softener compartment was, causing the fluid level to rise and therefore releasing the softener early. The washer was NOT spraying water in the softener side, what happens is that the dispenser tray is configured in a way that when the fluid reaches a certain max level in the softener/bleach trays, it completely drains. A way to test for this problem would be to completely dry the softener tray and start the wash cycle like you normally would (including detergent), only without adding any softener to the tray and see if after filling there is any water in the softener tray, this would prove that the water is coming from the other side.
Apr 13, 2012 | Whirlpool GHW9400 Front Load Washer
When i put in the fabric softener and run a load there is water filling the bleach and fabric softener compartments when the wash is completed. That did not happen in the first few years I owned the...
That same thing happens to mine. You can take the whole little drawer out and empty the water. I don't know why it does this to begin with, but obviously you don't want to leave the water in it so there is a button behind the back end of the "detergent" holder spot, push down on it and pull out the drawer. Then just empty it and slide it back in.
Jan 01, 2011 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Fabric softener compartment is filling up with water.
the hose need to be clean there is something that let the water get stuck there check inside if you see what is cluge in the unit or the internal hose, try to clean it with warm water
May 23, 2010 | GE Energy Star WCVH6260F Front Load Washer
Fabric softener dispenser fills up with clear water after washing cycle is complete. I do not use fabric softener .
Feb 17, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
MAYTAG STACKABLE WASHER/DRYER FABRIC SOFTENER DISPENSER
check the lable on the softnef bottle it should tell you how much to use and how to delute it .
Jan 22, 2009 | Maytag LSE7806A Top Load Stacked...
Washing Machines Logo
43 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
