Question about Garden
The trim line keeos tangling around the motor stem atop the spool?
3 Suggested Answers
SOURCE: Line gets tangled in gear under feed spool
Problem solved. We noticed something was broken off a small part inside the spool holder. My husband took it to the local hardware store, and one of the employees gave him the part from a trimmer that had been returned.
Posted on Apr 07, 2009
SOURCE: I have bought and installed
make sure the knife edge is still attached to the guard. if not, there is nothing there to cut the extra line
Posted on Jul 11, 2011
How do I get my zebco to retrieve the line
Your reel has pickup pins on the spool that will guide the line onto the spool when you reel in.
Try holding gentle tension on the slack line just above your reel and start reeling in. If this does not work then remove the top cover of the reel and look to see if the line is tangled up on the inside around the center shaft underneath the pickup pin cover.
if this is the case, simply unscrew the pickup pin cover from the center shaft. It will be on the tight. Remove the tangled line and reassemble.
Sep 18, 2014 | Zebco 33 Platinum Spincast Reel, 5 Ball...
How do put the cutting cord on the spool so that it can be pulled out after wearing down
Hi, Robert I will try to explain the best I can. There are many different ways the manufacturers build the heads and spools for grass trimmers. Remove the spool from the head of your trimmer. Some just pull out, while others have different ways and adapters that screw out, if you have never removed yours look in your owners manual or if you don't have a manual you will have to find the way you remove the spool from the head. When you remove the spool, remember which way it goes.back in. Once the spool is removed if there is still a small amount of line remaining observe the way it is held on the spool. If no line remains look at the bottom of the spool for an eyelet or holes right at the bottom or on the side. If you see an eyelet just tie the line to it. If there is nothing but one hole that means that with the right size of line it will go in tight to hold line. If 2 holes are present insert in one hole and out the other. If you have a 2 line trimmer then 2 holes means in one hole and out the other which makes sense. Whatever is the way to hold the line in, sometimes it just doesn't hold the line on once you start winding line on. There are a few manufacturers I find you can use on all spools and is easy.Take some packing tape or any kind of tape you want to use. Wrap around line then tape to bottom of spool, the easiest way to hold on and works on any make of trimmer. Look at the spool and there is usually an arrow on outside to give you the direction to wind. It is important how you wind line on spool, try to wind neatly like back and forth in even rows so that later the line doesn't get tangled up. But it is also very important not to twist the line. What I mean by that is the way the line comes off the package it comes in. Wind the line the same way it is wound on pack. I hope I am explaining it properly and that you understand what I mean. Put the spool and pack end to end and unroll the line out of the pack the same it is rolled in the package. That is to prevent the line from getting always tangled up and you having to remove the spool to get untangled. I think you probably get what I mean. Do not put too much line on the spool, leave about 1/4" from top of spool. Install the spool the exact same way it came off. I hope I have helped you and that you understand the way I explained it. All the best and good luck. I will gladly answer any other questions.
Feb 06, 2011 | Garden
Spool does not release line when tapped
You do not need to bump the head to advance the line. The machine has automatic line feed. If the line will not advance, then there is a problem with the line spool, possibly a tangle inside on it. Here is your instruction manual.
http://tinyurl.com/2vz3fhb
Sep 27, 2010 | Black & Decker String Trimmer Cordless 12"...
How do you cast it? I kept getting tangled...the ...
Put thumb on spool, flick into free spool. look at spot you want to cast too. Cast SMOOTHLY taking thumb off as you get to about 45* to front. *IMPORTANT8 THUMB ON SPOOL THE INSTANT THE TERMINAL END OF LINE HITS WATER!!!!!!!
May 19, 2010 | Pinnacle Solene SLP10 Baitcast Reel
Poulan Weed Eater Trim Line Constantly Jams
Sounds as if the line is wound on the spool the wrong way, causing it to want to always feed string.
Jim
Jun 13, 2009 | Poulan Garden
Apr 06, 2009 | Black & Decker St7000 13'' Automatic Feed...
Singer 750 how to rewind the bobbing?
1. Push in indent (illustration 1) on hand wheel disc. This will stop the needle from moving.
2. Place spool of thread on spool pin.
3. Slide spool pin holder/cap (illustration 2) firmly over rim of spool to prevent thread from tangling.
4. Lead thread passing it first through the lower slot of the thread guide. Next through the upper slot, leading the thread to the right and around (illustration 3).
5. Wind thread clockwise around front of bobbin winder tension disc (illustration 4).
7. Pass thread end, from inside, through small hole in rim of bobbin.
8. Holding thread end, step on speed controller to run machine until desired amount of thread is wound. (Winding stops automatically once bobbin is full.)
9. Cut thread; push bobbin to the left and remove it from bobbin winder pin.
10. Trim thread end from top of bobbin.
11. Press the bobbin winding indent on hand wheel to its original position. If necessary, turn hand wheel to engage needle movement.
Feb 09, 2009 | Sewing Machines
I am trying to spool trimming line into my black and decker GH1000. It is supposed to feed automatically. It is not. I'm afraid I fed the line onto the spool incorrectly. Need help
Yes, it does feed automatically.
Please make sure the trimming line spooled in your spool regularly.
If above does not work, please go to service center to change a lever inside spool housing.
Aug 29, 2008 | Black & Decker String Trimmer Cordless 12"...
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
