Question about Ovens
WhenI try to turn the oven on it says feature not available
My whirlpool oven is only 2 yrs old, and I went to turn it on and its saying feature not available?????
then turn off the whirlpool and allow it to stay for about 1r then turn it on again if the problem continues then contact your service provider.
Sep 06, 2017 | Whirlpool Ovens
My double oven by whirpool is displaying a message saying "feature not available" when I press the bake
First thing i would do is turn the circuit barker off to oven for one minuet and then turn it back on. feature not available is gone then press bake and start bake cycle. monitor the oven for 1 minute to ensure the error code does not display again. If it dose then you will need to get a repair service company to come check it out. they will have to enter the diagnostic mode and check for any other fault codes to make sure there is not something else causing the problem before the control board is replaced.
Jun 01, 2017 | Ovens
The power went off, when it came back on the oven time displayed. when we tried to turn on the oven the message feature not available came on
First try this: In your Household Circuit Panel, Turn the Circuit Breaker to the off position. Wait 30 Seconds and then turn it back on. Try to turn the oven on if it comes on you are in luck, if not look in your manual for first time set up instructions like setting the clock date and time, and go through the settings. Then try the oven again. If it comes on you are in luck.
Oct 15, 2014 | Whirlpool 24" Double Electric Built-In...
Used self cleaning process on my oven yesterday and today the oven will not turn on, we keep getting message to unlock the oven door even though it is. What can we do?
The oven gets extremely hot during the self-cleaning mode... the door switch might have got stuck in locked position, or broken in locked position (to be replaced), let's hope it's just stuck...which you'll need to work the mechanical lock-unlock latching back and forth to hopefully unstick....and if that doesn't work just re-run self-cleaning process but this time let the oven cool completely before unlocking the door. Hope this helps.
May 11, 2014 | GE Ovens
I have an older gas oven/stove top and would like to disconnect the feature that turns oven off after 12 hours
If you have older type gas oven look at the clock and reset so you see manual position. This will remove automatic cycle.
Mar 28, 2014 | Ovens
When I select bake, broil, etc, I get the message-feature not available
If is 6 months old call for warranty repair, turn off circuit breaker for a minute then repower this may clear it if not again call for warranty service
Jan 30, 2014 | Whirlpool RBD305PD Electric Double Oven
Oven not heating properly
most common problems:
1. calrod unit not working(heating element) easy replacement
2. breaker tripped.(sometimes a double breaker will only trip one of the circuit breakers so you end up with half power)
good luck
Jul 19, 2013 | Whirlpool Ovens
My daughter-in-law just moved in to a newer home with a stainless steel Kitchen Aid ceramic top stove. It has a warming oven, a convect feature etc. However, with options etc. it is very confusing to...
Kitchen Aid manuals are available from their support site: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD . The model number is needed to locate the manual. For ranges, the plaque with the model number is inside the oven door.
The KitchenAid ovens that I know will turn off when you press Off (unless the control lock is on - then you need to disable the control lock). The Warming Drawer will have a separate Off button. Dual oven units require you to select which oven and then press off.
See http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/KESS907XSP_Use%20and%20Care_EN.pdf for a similar range. (ceramic glass cooktop, convection feature and warming drawer)
I hope this helps.
Jul 02, 2011 | KitchenAid Ovens
Whirlpool oven ''feature not available''
That happened to my fairly new Whirlpool double oven. But I remembeedr the power in the neighborhood had flickered earlier in the day. So I went to the circuit breaker and shutoff power to the oven for about 30 seconds and turned back on. Everything normal now. I just assumed the slight flicker in the power affected to programming.
Jan 24, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Old Amana - no manual; can't operate self clean feature
Can you locate the model number on the oven? Also any particular name of the stove? The manufactured year. These should all be available on a stainless steel or aluminum attached plate , probably on the back of the stove or inside the door.
I wouldn't try using the self cleaning feature until we get some advice. it could lock up on you and not UNLOCK. Normally self cleaning takes place at 600 or more degrees .
I'm sure others still have the same stove., I will see what I can find for you.
Aug 21, 2008 | Amana AEW4530DDS Electric Single Oven
Ovens Logo
26 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
