What the problem if my TV remote does not function and the touch screen functions
SOURCE: DCRHC 30
Main bard replaice
Posted on Jul 17, 2007
SOURCE: "Tissot Touch" Touch screen failure
it all stems from the watch not actually being waterproof it's more water resistant than waterproof. The little indentations on the back that look like they are for a tool to unscrew it are actually holes i guess for the altimeter and meteo so it can sense pressure. Behind the back just behind the holes is a nylon gauze material and underneath this is a sensor slightly recessed and covered with some kind of waterproof substance. As far as i can see the problems lie here any water sweat or other foreign object than gets into this gauze will eventually will clog this gauze material which at first will affect the altimeter then the meteo. When the gauze has been clogged up severely i gets very dirty indeed which means when it gets wet it takes an age to dry out so if you wear it in the shower like i used to it will never dry out this causes the watch to malfunction quite severely. You can actually fix this problem yourself just get a very small flat screwdriver and lever the back off don't worry it's only a push fit and comes of easily you will see straight away a dirty damp smelly clogged up round piece of nylon gauze clean this up with a bit of WARM not boiling soapy water being careful not to disturb the pressure sensor and it's waterproof goo inside then dry it all and put it together
Hope this helps
Dom
England
Posted on Feb 26, 2008
IrishDruid
  • 2712 Answers
SOURCE: Manually changing screen size
HERE is an operating manual for your TV. You could probably find what you're looking for in there..
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 02, 2008
sdowney83
  • 62 Answers
SOURCE: Touch Screen not responding
KIng LeO>> Try re-calibrating the screen, settings>screen> then select "Align Screen". If after you do that, it still doesn't work, try a factory reset.
neldie>> Do a factory reset.
Use a program like PIM Backup (http://www.pocketpcfreewares.com/en/index.php?soft=1806)
Save the backup to your memory card, or back it up and copy it to your computer, the do the Factory Reset. You can then reinstall PIM Backup after the reset and use it to restore most of the stuff on your phone (contacts, call logs, text messages, etc.)
Factory Reset instructions:
•Hold down both soft keys (both above the send and end key's) and use the stylus to push the reset button in between the volume key and micro sd slot. Then the screen will turn on and tell you something to the extent of press "Send" to perform a factory reset. Hit send, and your good to go.
Posted on May 18, 2008
SOURCE: touch screen is not working
not working touch screen
Posted on Jun 25, 2010
We have a Model un40eh5300fxza tv, where on the remote is the OK button
    images for where on the remote is the OK button
    More images for where on the remote is the OK button
    RC: Tv code so i can use ok/select button on comcast remote
    www.remotecentral.com > ... > Consumer > Original Equipment Remotes
    Mar 3, 2010 - 13 posts - ‎7 authors
    I have the comcast dark grey remote and a vizio lcd tv .when i press the tv button i then can press the menu button it brings up my tv menu and ...
    Button Functions by Remote ' MyDISH ' DISH Customer ...
    https://www.mydish.com/support/.../remotes/button-functions-by-remote
    Register, Button, Button Sub-Category, Function, Condition ... on screen menu/pop-up, -. 2, Color Buttons, -, -, Function varies by screen and customer selection.
    Select/OK button doesn't work when Using Comcast remote with ...
    www.avsforum.com/...remote.../1533595-select-ok-button-doesn-t-work...
Jan 07, 2016 | Samsung Televison & Video
Cobolt 3 in 1 jumbo remote control
have u checked wether is is supported or not????
it may not be supported.............
Sep 18, 2008 | Televison & Video
Tip
Acessing Menu with universal remote
We used a One4All model URC3021BOO remote. We programmed BOTH the TV function and the DVD/vcr button with code 0807.  To access the menu PRESS TV then MENU button then DVD/VCR button will allow you to change menu functions using left and right and select buttons. *TV button will access Menu screen BUT NO menu functions. * DVD/VCR button will NOT access menu screen but WILL control menu functions if menu is already displayed. May work with other sharp products, or other universal remotes? These original (RRMCG1330PESA) remotes run 38.00+ to buy new so try this FIRST!
on Oct 29, 2008 | Sharp 13VT-J100 13 in. Combo
When i press the input button on my universal remote nothing happens
There are several codes for the same brand of TV. Make certain you have the perfect code to control all functions for your model, and be sure to change the remote to "TV" before pressing input button.
Mar 27, 2014 | Universal 8-in-1 Remote Control, Touch...
Remote control not working with tv
The remote control is an acess to the TV device for example only from a distance. A remote controll for functionality would require to insert batteries a power source making possible communiction with devices requiring reception transmittion of signals. The remote is handheld pointed to the direction of TV requiring signal before button pressed woudl achieve response. a common button to start the remote control experience is pressing on the power button, that displays a signal on the TV. The TV should momentarily produce a sound and lighting effect,, and displaying on the dark screen a light blue screen. The initial signal response from remote control to TV indicates devices are functioning as required. Additional buttons on the remote controll could perform functions of several available.
The remote control has master button, menu on which every additional function is deriveable. Once the menu button is pressed with remote pointed in the direction of TV, should dicplay a list of options on the blue screen already established by power button. Every additional remote control device functionality is achievable by only after the first two buttons have been powered and pressed to display option results on a screen of TV. The remote controll buttons remaining perform complementary functionalities. For example, the arrow keys on remote control make movement of the options displayed on the screen, where a comfrimation button or identified as select allows to confirm remote functions displayed on the screen. A remote control could have several functionalities only accessible once made to display in screen. The three most common buttons on a remote control are First power button that powers on the TV, menu button that displays a list of functionalities on the powered on bl;ank blue screen, and using the arrow buttons on the remote would moves an indicator arround the screen area options. The selection button makes confrimation of the option.
Dec 02, 2010 | Philips Televison & Video
Dear Sir, I have AIWA A219 TV. No remote functions are working, even manual switches are also not functioning, It got stuck on One channel, The error which is coming on screen is AGING 1724H Plz...
Dear Sir, I have AIWA c142ske TV. No remote functions are working, even manual switches are also not functioning, It got stuck on One channel, The error which is coming on screen is
Oct 12, 2010 | Aiwa F2000 20" TV
Protron LCD-TV -PLTV3250-32" Was given to me, without remote. This tv, has no Power-on button, just an on/off swicth, where ac cord goes in. This tv does not power on using this switch.My questions: is...
There is a touch sensitive panel on the front just below the screen above the speakers. You should see the functions printed there such as power, channel, volume, and menu. Just touch the desired function and it will work.
Mar 18, 2010 | Protron Televison & Video
Need codes
I have a Jumbo touch screen universal remote control Item #NV00268 and i lost the codes i am trying to program Tv brand (Akai) can u help?
Oct 01, 2009 | Philips Televison & Video
How do I set the time on Sony 46" TV with the Remote
The Harmony remote comes with most, if not all of the functions of your original TV remote built in to its hard and soft keys. Choose the "Devices" button to see a list of the devices controlled by your Harmony remote, then select the Television. Once you do that, your remote will show all the functions from your TV's remote.
Unfortunately, from there, you'll need to know how to change the time for your TV (I imagine there will be some sort of SETUP function on the TV). For that information, or anything else specific to a particular device, you need to reference the device's own user manual.
I hope this helps.
May 25, 2009 | Logitech Harmony One Advanced Universal...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
