Hi, I have a problem with ti-nspire cx CAS, it has defective button. For eg. when I press 0, it will appear 01 on screen. When I press "enter" it appear "w".
  • 8068 Answers
SOURCE: My TI-nspire CAS doesn't want to go on! I changed
Try the other recipes from the TI knowledge base concerning a calculator failing to turn on
For the TI-Nspire™ Family:
  1. Remove thekeypad (for TI-Nspire) or the battery door (for TI-Nspire CAS) andremove at least 1 battery from each column of batteries. After 2-5seconds, reinsert the batteries and turn the unit on. This will causethe unit to reboot the operating system.
  2. Remove the keypad(for TI-Nspire) or the battery door (for TI-Nspire CAS) and remove atleast 1 battery from each column of batteries. After 2-5 seconds,reinsert the batteries and LEAVE THE UNIT OFF (do not turn on and thenback off). Hold down [Home] [Enter] [P], and while holdingthese keys, press [On]. The device will boot up as in the previousreset, but will display a menu with the following options. Please tryoptions 1, 2, 3, and 4 in that order. ** The [Home] key is located atthe top right of the TI-Nspire keypad and has a picture of a house onit.
Note:TI-Nspire family model options 2 and 4 above require that the OS be installed. The reset menu will only display if the unit is off and batteries have been removed/replaced as described above.
1. Cancel - The most non-intrusive reset option; no changes are made, the unit restarts.
2. Delete Operating System – The operating system will be deleted without deleting any documents.
3. Delete Document Folder Contents – This will delete the user’s documents, but will not delete the OS.
4. Complete Format – This will delete the OS and all documents for a total erase of memory.
Hope it helps you solve the problem.
Posted on Oct 18, 2009
  • 8068 Answers
Here is what the TI knowledge base says about a calculator failing to turn on.
  • 8068 Answers
SOURCE: Ti-nspire CAS buttons under enter button don't
It depends on the context.
The one on the lower side introduces a space. Used with the CTRL key it inserts an underscore.
The one to the right, with a symbol like a linefeed or newline, this one works in the context of matrices.
Used alone it adds a new row to a matrix. Used in conjunction with the CTRL key it inserts a new column in a matrix.
Outside the context of matices it does nothing.
Hope that this helps.
Posted on Nov 15, 2009
  • 35 Answers
SOURCE: my ti-nspire's keypad(ti-nspire)is not working
Remove the keypad and then replace it back onto the calculator. Make sure it fits properly and is on tight.
Posted on Mar 07, 2011
  • 8068 Answers
SOURCE: hey I am trying to use
deSolve( ) solves differential equations. The general syntax is deSolve(1stOR2ndOrderODE, Var, depVar). The first argument must be a first order or second order differential equation, the second argument is the independent variable, and the third is the dependent variable (the name of the function you are trying to obtain.)
Your command does not have a differential equation, and it does not have the dependent variable.
Posted on Sep 19, 2011
Hi! I have a TI-nspire CX CAS and I was wondering how to enable the results to be shown in thousands separators (1,000 or 1'000). Thanks for your help!
At first press on key, then Settings and finally Document Settings. From this menu on the position Base choose Decimal. See captured image below
Dec 22, 2015 | Texas Instruments TI-Nspire CX CAS...
My TI-nspire CX CAS just got a white screen with a black stripe.
Unplug the battery? I thought that the battery was built in.
Nov 13, 2014 | Texas Instruments TI-Nspire CX CAS...
TI-nspire cx changing from degrees to radians
Press Documents Settings. On line angle select radians, AND validate the change by moving the cursor on the OK button, and pressing it.
Jun 12, 2014 | Texas Instruments TI-Nspire CX CAS...
The calculator writes 8 all over
During operation of the TI-Nspire handheld it may be necessary to reset the device. Circumstances which may require a reset include; keys not responding, device will not turn on or a garbled display. To reset the device:
• Remove the keypad (for TI-Nspire with ClickPad, TI-Nspire with TouchPad, and TI-Nspire CAS with Touchpad) or the battery door (for TI-Nspire CAS with ClickPad) and remove at least one battery from each column of batteries. After 2-5 seconds, reinsert the batteries but do not turn the handheld on.
For the TI-Nspire and TI-Nspire CAS handheld units with ClickPad:
• Hold down [home] [enter] [P].
• While holding these keys press [on].
For the TI-Nspire and TI-Nspire CAS handheld units with TouchPad and the TI-Nspire CX and TI-Nspire CX CAS:
• Hold down [doc] [enter] [EE].
Please Note: For TI-Nspire Family handheld units that contain rechargeable batteries you can alternatively hold the above keys while pressing the [reset] button on the back of the handheld rather than removing the battery for 2-5 seconds.
• The device will boot up as in the previous reset, but will display a menu with the following options. Please try options 2, 3, and 4 in that order.
• 1: Cancel - The most non-intrusive reset option; no changes are made, the unit restarts.
• 2: Delete Operating System - The operating system will be deleted without deleting any documents on the system.
• 3: Delete Document Folder Contents - This will delete the user's documents, but will not delete the OS. Selecting this option is the same as using the RESET hole on the back of the unit.
• 4: Complete Format - This will delete the OS and all documents for a total wipe of the handheld.
Please note that the second and fourth option will require that the OS will need to be reinstalled
Mar 12, 2014 | Texas Instruments TI-Nspire Graphic...
My TI NSPIRE CX CAS is stuck at the loading screen - it keeps loading and then going back and repeating (only when plugged in). I have tried resetting it whilst holding down EE, doc and enter. When I do...
restarts.
unit.
Please note that the second and fourth option will require that the OS will need to be reinstalled.
Oct 09, 2013 | Texas Instruments TI-Nspire CX CAS...
How to get the ti nspire cx to give square root answers
You can not achieve this with the Ti-nspire cx. Only the CAS version will give the square root form. On the CAS there is an option in the settings called "EXACT" under calculation mode. The cx does not have this mode.
Jan 09, 2013 | Texas Instruments TI-Nspire Graphic...
My ti nspire cx cas is totally stuck at the loading screen , it keeps reloading and reloading with a sign at the left corner at the bottom that say's that my battery is empty ? what should i do ?
I have a doubt, when I choose to completely format the calculator it will clear your operating system, files saved on it, but the product key (ID protuto) will be deleted too?32d3cd84-9b87-4f5d-abfe-aa04ca86df4c.jpg
Dec 18, 2012 | Texas Instruments TI-Nspire CX CAS...
Hi, I have a problem with ti-nspire cx cas.
The Ti Nspire CX CAS has a built in battery. It must be recharged. If you plug it in a wall socket or in a USB charger you should be able to use while it is being recharged.
Nov 22, 2012 | Texas Instruments TI-Nspire Graphic...
Hi, I have a problem with ti-nspire cx cas, it doesn't charge via a usb cable.
Are you really talking about a TINspire CX or a TI NSpire. The TINspire CX (CAS or Not) comes with a rechargeable battery and an adapter/Charger. You plug the charger in an electric outlet and let it party charge. If the calculator battery fails to recharge then it must be defective. Any third party mini USB charger will recharge the battery.
The TINspire with touchpad (CAS or not) can use regular batteries or the optional rechargeable battery.
It is not necessary to connect the calculator to a computer to have it recharged.
As far as the calculator being recognized by the computer, you must install the communication software (TI computer Link Software for the older TINspire) or the TI Nspire teacher or student software for the CX. When you run the TINspire teacher or student software and then connect the calculator, you will have the opportunity to select it.
Aug 16, 2012 | Texas Instruments TI-Nspire Graphic...
How do you put the batteries in?
  1. Remove the keypad (for TI-Nspire) or the battery door (for TI-Nspire CAS) and remove at least 1 battery from each column of batteries. After 2-5 seconds, reinsert the batteries and turn the unit on. This will cause the unit to reboot the operating system.
  2. Remove the keypad (for TI-Nspire Family or TI-Nspire CAS Touchpad) or the battery door (for TI-Nspire CAS) and remove at least 1 battery from each column of batteries. After 2-5 seconds, reinsert the batteries and LEAVE THE UNIT OFF (do not turn on and then back off). If the TI-Nspire/TI-Nspire CAS is a Clickpad, hold down [Home] [Enter] [P], and while holding these keys, press [On]. If the TI-Nspire/TI-Nspire CAS is a Touchpad, instead hold down [Doc] [Enter] [EE], and while holding these keys, press [On]. The device will boot up as in the previous reset, but will display a menu with the following options. Please try options 1, 2, 3, and 4 in that order. ** The [Home] key is located at the top right of the TI-Nspire keypad and has a picture of a house on it.
Aug 26, 2011 | Texas Instruments TI-83 Plus Calculator
k24674
jasbo
jasbo
