Question about Deadbolt Locks & Locksmithing
Opening the lock, it's a weiser deadbolt - Deadbolt Locks & Locksmithing
  • 5103 Answers
SOURCE: PIN NUMBER
Take off the cover on the inside door of the lock. Grip it on the sides and pull up or twist. Press the Program button (on the left of the power board) once. Then type in desired code (4-8 digits) on the Touchpad followed by pressing the Lock button. If you hear a 2-second beep, the code is properly stored. If you don't hear the beep, the encoding period timed out. Then you need to repeat the sequence from pressing the Program button but do it faster. To store a second code, press the Program button twice and then type in the desired code followed by the Lock button. (Any earlier code will be lost during these steps.) Then replace the cover over the power board.
If you want to print out the programming information, go here: http://www.weiserlock.com/en/products/smartseries/powerbolt.aspx and scroll down to the Installation instructions. The programming instructions are at Step 5 on the PDF.
I hope this helps.
Posted on Jul 23, 2010
  • 17 Answers
SOURCE: I have a keyless weiser deadbolt. Can't find any
Very common for the keypad to stop working.
check that the keypad is not defective. You can disconnect the batteries and then unplug the keypad. Now put the batteries in without the keypad connected. If the beeping stopped, your keypad may need replacing.
You can get a replacement at the store where you bought it for free or call the Weiser support line and they will mail you one for free.
Posted on Dec 26, 2010
  • 15 Answers
SOURCE: Weiser keypad deadbolt lock deadbolt does not move
Hi... You have too be sure that the deadbolt is free when it go inside the deadbolt hole... however this system is very low power and the (over torque clutch) will sleep if the deadbolt it's not completely free.
Also if you try to open the door before you unlock it, you may block the the deadbolt inside the deadbolt hole. Take care too unlock the door before open-it...
Posted on May 14, 2011
  • 963 Answers
SOURCE: I have a weiser combination
Weiser has a lifetime warranty against mechanical and finish problems with their locks. Contact them from this link:
http://www.weiserlock.com/en/Products/SmartSeries/Powerbolt.aspx
Posted on Nov 06, 2011
  • 963 Answers
SOURCE: Weiser Power deadbolt works backwards on keypad
I have installed your Powerbolt, but when I push the Lock Button, it unlocks? What should I do?
First remove the cover on the inside of the Powerbolt unit. On the right hand side under the batteries, you will notice that is says "Door Direction Jumper". If the cap is mounted on Prongs 1 & 2, carefully remove it and move it over so that it mounts Prongs 2 & 3. A is right handed, B is left handed.
http://www.weiserlock.com/Support/Faq/50160000000HhmZAAS.aspx
Posted on Aug 19, 2012
Change batteries in weiser Powerbolt elec deadbolt
Pull the inside cover away from the door, to remove. This exposes the battery holder. Replace all four AA batteries with new alkaline AAs The cover snaps on. Align top first.
http://www.weiserlock.com/PDFs/instructions/Electronics/Powerbolt.pdf
Mar 31, 2014 | Weiser Lock POWERBOLT ELEC DEADBOLT
Need a video how to program my keyless entry deadbolt lock
Which manufacturer made the keyless deadbolt lock? Make sure that the batteries are good in the unit.
I have an older Weiser Powerbolt deadbolt lock that is programmed by taking off the cover on the inside of the door. This model has handheld remotes and the keypad. Inside there are three yellow buttons. Two match the cover's lock and unlock buttons. Press and hold the third button (in the center of the set of buttons). Then enter program in the code within a few seconds and press the enter button to set the code. If the unit beeps again, the code is set. If the unit doesn't beep, retry from the press and hold the Program button step.
Another model of the Weiser Powerbolt lock has the Program button either on the top left or lower right hand side of the board (depending on the way the door opens) under the cover. Press the Program button once and then enter the 4-8 digit code. Press the Lock button to set the code. If you hear a long beep, the code was accepted; otherwise try to program your code again.
Kwikset Powerbolt locks are programmed the same way as the second Weiser Powerbolt described above.
Kwikset SmartCode locks have their Program button in the center of the bottom of the control board. Otherwise the programming is the same as that given above for the second version of Weiser Powerbolt locks.
MiLocks have three buttons in a horizontal line. The left-most button is the Set button. Press this then enter the code followed by the Unlock button. The code must be entered within 5 seconds of pressing set.
Baldwin Hardware's Boulder series of keyless entry deadbolts are programmed just like the Kwikset SmartCode units.
I don't know of any videos. Most manufacturers do have PDF files with the programming instructions.
I hope this helps. Please add more information about your deadbolt for extra assistance.
(I end up replacing the batteries often on the lock I have; it seems like they last 6 months or less.)
Oct 20, 2013 | Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY...
I have a weiser combination lock and it seems to be bogging when keying the comb. in so i recharged my batteries and installed back into the lock and it still bogs. Is there one batterie better than...
Jun 28, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
The lock opens correctly but will not lock. It looks like when it trys to lock, the motor pulls the deadbolt in the same direction as when it is opening.
Programming/troubleshooting instructions:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Mar 21, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
Weiser powerbolt worked well for several months but now is not reliable anymore. Changing batteries did not help. It sounds like it is locking but sometimes fails to lock...we cannot trust it anymore
Good lock or good unlock
Feb 05, 2011 | Weiser Lock ED1460X3VKD Powerbolt 1000...
Weiser keypad deadbolt lock deadbolt does not move when motor runs
Dec 30, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
Bolt doesn't open all the way
You should replace your batteries as the motor that moved the deadbolt does not have enough power to move it with weak batteries. If that fails make sure the deadbolt moves freely when the lock is removed as the mis-aligned mounting will cause excessive force be exerted to move the deadbolt. See http://www.weiserlock.com/Support/Faq/50160000000HhbGAAS.aspx
Dec 13, 2010 | Weiser Lock ED1460X3VKD Powerbolt 1000...
I have a keyless weiser deadbolt. Can't find any model # but bar code inside reads 0550B05755CC. Has worked well until I tried to lock going out and only got long beep. Tried to recode and will not open or...
Dec 08, 2010 | Weiser Lock ED1460X3VKD Powerbolt 1000...
I have a weiser lock powerbolt 1000 and i just installed it and progammed it except the bolt wont lock unless the keys are in the door, if i type in the code with the keys in it works fine but when i...
The deadbolt may very free inside the deadbolt hole... This system is low torque and a over torque clutch may slip if the dead bolt it's not completely free inside the deadbolt hole... Also, if you try to open the door before to unlock it, you may block the deadbolt... take care to unlock the door before open it. to be sure that the dead lock is ok, you can turn the manual knob and be sure is turning very very easily.
Also are you no that POWERBOLT is a 3 codes memory? go to that link to see more info about that : http://www.fixya.com/support/t8006865-not_overwrite_old_codes_just_keeps
Have a good lock
Have a good unlock
Sep 11, 2010 | Weiser Lock Powerbolt 1000 Lock
Weiser combination lock beeps
You should check if the keyboard ribbon cable is properly connected and not pinched or cut ... Also it is possible that water has entered into the keyboard. In case you should remove and dry with a hair dryer.
Jul 09, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
Locks & Locksmithing Logo
154 people viewed this question
Top Deadbolt Locks & Locksmithing Experts
jdthefixer
Mark Wolfe
David Belitz
David Belitz
Are you a Deadbolt Lock and Locksmithing Expert? Answer questions, earn points and help others
