Question about Dehumidifiers
How do you clean old vintage bottles? The kind you find in old basements & etc. How do you get that old slime out of them?
Whirlpool Basement Dehumidifer is freezing up about l/3 from the bottom. Compressor will not turn off. Coils were cleaned and cleaned fan is running freely. Sitting in well ventilated area and temp...
IIt may very well be that the the air intake filter needs to be removed and cleaned. But, before doing this, turn the unit OFF & unplug it. Allow the unit to completely thaw, before removing the filter.Never operate the unit without the filter in place, As this could damage the unit.
Hope this helps you & thanks for choosing FixYa.
Sep 11, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
My 35 pint (42 54351) dehumidifier is only ~2 years old. It will not stay on, even though the basement is very damp. Is there anything I can do?
There are 5 basic, but solvable reasons for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have an analog unit, set
the humidity extraction knob on Maximum.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
I hope this helps you to further troubleshoot and solve the problem. Thanks for choosing FixYa.
Aug 15, 2011 | Kenmore 54351 Dehumidifier
The dehumidifier is getting cold condensation on the top outside of the unit and no water in the bucket. Model BGD-510A. I cleaned the filter and the coils and still have this problem.
Kathryn, if you are operating it in a basement application, the problem is that air temperature at floor level, is colder than at shoulder level. Dehumidifiers struggle to work at temperatures between 40 & 65 degrees F (Unless they are Low Temp model designed for basement applications). And will ice up at times. Raising the unit up off the floor onto a sturdy table, counter top, etc that can handle the weight of the unit, plus a full bucket of water, will usually resolve the problem.
If it's not a basement application, try lowering the humidity extraction level to 35%. In you have an analog unit, turn the control knob to Maximum.
I hope this helps you and thanks for choosing FixYa.
Aug 10, 2011 | Dehumidifiers
My basement dehumidifier runs but extracts no water from the air. It worked when I first turned it on in June but I only emptied it once. In the past I emptied it every day in the summer. Do I need a...
Gayle, your unit has some age on it, but it may still be salvageable .
There are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2..
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. Or set to Maximum if yours
is a manually controlled unit.
level
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. As far as repairs are concerned: The unit is 14 - 16 years old and the cost to repair, may be as much (or close to it) as purchasing a new unit. If you decide to purchase a new unit, be sure it's a "Low Temperature" model, as yours is being used primarily in a basement application.
I hope I have helped you and thanks for choosing FixYa.
Jul 24, 2011 | Whirlpool Dehumidifiers
My lg dehumidifier 3 yrs old acts like it is running normally but does not extract any water from the basement air. what can i do?
There are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1, 2 & 5.
level
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this has helped you troubleshoot and solve the problem. Thanks for choosing FixYa.
Jul 23, 2011 | LG LHD45EL Dehumidifier
I have a 2 year old Frigidaire dehumidifier model FDM7051 and this summer when I turned it on it runs continuously with the fan moving normal amounts of air. The air filter and coils are clean and I have...
Don, unless your dehumidifier is a Low temperature model, that very well may be the problem.
The air temp in a basement at floor level is colder than that chest level. Dehumidifiers don't work well at temperatures at 40 degrees F or less. Raising the unit up off the floor on to a sturdy table, counter top, etc, that is strong enough to handle it's weight, plus a full tank of water, will generally solve the problem. The higher up you can safely put it, the better. Also, lower the humidity extraction level to 35%. As 50% is just not low enough in a basement application.
Hope this helps you to solve the problem.
Jul 20, 2011 | Frigidaire Dehumidifiers
I am not getting any water in the collection tank. I cleaned the filter and reset the controls. Humidity in basement is 65% and I set the control to 50 %. Any suggestions? Thanks.
There are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 5. Especially, since, yours is a basement application.
level
problem.
Hope this helps you to troubleshoot & solve the problem.
Jul 06, 2011 | DeLonghi Dehumidifiers
A very old, extremely heavy dehumidifier sat in my mother's basement for decades. I decided to dispose of it, but I was unaware of the freon inside it. In order to extricate the dehumidifier I had no...
Yep the ref is all gone, The EPA says that the oil is hazardous, actually its just mineral oil the at one time had ref. R-22 in with it.
Jul 03, 2011 | Dehumidifiers
My D40 runs OK but I am getting absolutely zero moisture removal. I hear it runing but when I smelled dampness in my basement for a few days I looked at it and discovered that is bone dry. Is it shot? ...
No, it's probably not shot. Just may need some adjustments. Below are the common causes of the problem you're having.
1. The humidity extraction level is set to HIGH. Lower it to 32 - 35%
2. Air intake filter is dirty or clogged and needs to be removed and cleaned.
3. Clear air obstruction. Maintain at least 12" of clear air space around the entire unit, while in operation.
4. The ambient air temperature at floor level is between 40 - 60 degrees F. This is particularly true in basement applications. Raise the unit up off the floor, onto a sturdy table, cabinet, etc, that will hold the weight of the unit, plus a full tank of water. The air temp at chest level is warmer than floor level in a basement. Unless, your dehumidifier is what's called a Low Temperature Model (designed for basements) it may be contributing to the problem. Although, based on all the odds, numbers 1 & 2 above, are going to be the culprit.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 12, 2011 | Friedrich D40 Dehumidifier
DH400P
I had a similar problem with the pump not working and the water flowing into the main drainage bucket instead. I had to disassemble the housing...not an easy project to reassemble...and found that the pump has its own smaller drainage tank with a float device, a pump pre-filter, the actual pump, then of course, more drainage tubes. The entire pump drainage system of components needed cleaned of accumulated, mucoid, slime! I cleaned the channel in which water flows into the pump's tank...located on the screen filter side of the dehumidifier. Then I moved to the other side of the dehumidifier and cleaned-out the entire pump drainage tank. Note that the pump's drainage tank only empties about 1/2 inch of water each time the pump activates. Thus, there is always alot of water in the pump's drainage tank. Thus, alot of time for slime to accumulate. Next, I cleaned off the float mechanism. I then cleaned-out the pump's pre-filter. Cleaning out the pump's pre-filter was paramount to the pump functioning properly and quietly! I checked that my pump was properly installed and NOT rubbing against its mounting so that it operated quietly. I added fresh water to the pump's tank several times to insure that the pump was working properly and that all slime was eliminated. Finally, I reassembled the housing...not an easy task! My pump now functions like new. All this work had to be done to insure proper function of the dehumidifier's pump system. My dehumidifier is only 11 months old. It is still covered by the one year warranty, but it is too expensive to ship the entire unit, as Delonghi requires you to do at your expense for them to fix it under warranty. You can be assured that I will check for future slime build-up to keep my dehumidifier functioning properly. The dehumidifier works great, it's just that it's high maintenance.
Jun 15, 2008 | DeLonghi DE400P Dehumidifier
Dehumidifiers Logo
49 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
