Question about Acer Office Equipment & Supplies
Acer P7280 does not power on
Hi! Trying to fix an old Acer P7280 DLP projector, the led is red when power cord is connected, and when i press the power button the led goes steady blue, but nothing happens. No beeps, no fans, no light. I have checked that all the micro swithes for the lid and the filters are engaging. What would be the next thing to check?
antiochpc
  • 1314 Answers
SOURCE: Compaq Presario 4400us
Either the new power supply you purchased is not functioning correctly. But, assuming it is now that you are getting some form of power to your PC, it is very likely the motherboard. Whatever fried your old power supply (or it could have just been the power supply itself) most likely fried your motherboard in the process. Probably not the CPU since the MB can't even post.
Posted on Jun 21, 2007
SOURCE: Power up problem
One thing u can do also. Open your system case, remove cmos battery clean cmos battery and then insert like same. And restart your system. Other wise check power connections voltage. If it is ok then definitely it will wirk.
Posted on Sep 07, 2007
  • 166 Answers
SOURCE: hi when i press the power button on the acer power
You may have a failed motherboard then. Failure of motherboards is usually due to breaking capacitors. A few years ago a capacitor company stole the "recipe" for making capacitors from another company and tried to make their own, unfortunately they did not get the ingredients right and the capacitors started breaking after 2-3 years of use. They sold these capacitors at very cheap prices and a lot of computer companies and power supply makers bought them. This is easy to diagnose. Look for capacitors (caps) (they look like little tiny soda cans) on your motherboard (mobo). They should be perfectly flat on top and not bulged or swelling or leaking anything. The dead giveaway is the fact that you are not getting anything after you changed the PSU. There are a few companies that will repair broken capacitor issues. Also if you add a bunch of extra components without upgrading the power supply you can suffer underpowered situations and that can cause internal parts to fail.
To eliminate some other stuff you could remove the memory and disconnect all the power plugs from the drives and then try to start it up. If it does not change the behavior at all (no beeps, no change in flashing lights) then you probably have motherboard issues. Make sure when disconnecting the memory chips (sticks) that you touch the metal on the inside of the case first to discharge static electricity. If it does change the behavior add 1 component or item back at a time to see what you can find out. Post back with what you find and please rate the solution.
Posted on Mar 30, 2009
budmrtn
  • 11361 Answers
SOURCE: Blue LED light comes on but nothing else happens when turned on
It can be the main board or the power supply, look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find
Posted on Nov 28, 2009
  • 23 Answers
SOURCE: When I tried to switch
Ordinarily my first thought would be that the lamp is needing replacement. But if it's brand new, the lamp should be OK. Can you open the lamp compartment to see if it was broken during transit, or perhaps it's not fully seated properly. If it's a broken lamp, then I would contact the dealer you purchased it from, or contact the manufacturer directly to have it replaced. Also, is the noise loud and unusual, or just the normal sound of a projector coming on? If it's very loud, it could be the fan motor. Check that the fan is blowing. If the fan is the problem, the projector will shut down to protect itself from overheating. That, too, should be covered under the waranty.
Posted on Jan 13, 2011
Testimonial: "Thx for help"
Tip
Toshiba TDP-P9 Lamp time reset
I had sleepless nights with my customers TDP-P9 projector where I changed the lamp.
The lamp timer resetting gave me headache but now I finally solved the right combo:
1: Unplug the power cord
2: Hold down 'On/standby' 'Input' and 'up arrow'
3: While keeping the buttons pressed, insert the power cord and wait for the projectors led's to flash briefly and then power button to keep illuminated and then starting to blink.
4: Release the buttons and power on, it should now have 0 hours in the timer.
on Apr 06, 2011 | Toshiba TDP-P9 DLP Projector
What is wrong with Acer P7280 projector? The lamp goes out after 10 min. use, and red lamp error led turn on
the lamp must be ok
the ballast may be fault
or the mainboard is fault
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jerry
Jun 18, 2014 | Acer P7280 OEM Projector Lamp
Acer p7280 projector lamp goes out after 10 min., and red error lamp light up.
The lamp must be ok
Have a nice day!
Lampdeng Limited
Jerry
Acer dlp 1120 show pinkish tint
for acer p1120 pinkish tint solved:
reset your lamp hours
do hard reset :
power off beamer
unplug power cord and press power at same time
replug power cord in beamer and press power button for 10 sec
now it should turn up normal again pink is gone
i called acer also with solution so they can also help you out if you dont get it done
Sep 11, 2013 | Acer P1120 3D Video Projector ACER
How can I connect BENQ MP510 multimedia projector with Acer Aspire one D255E notebook using windows 7? Do I need installation of extra driver for that?
Hi!
No you don't need a driver, connect it using a VGA Cable, then press FN Key at the same time with Fkeys that has a monitor screen Icon on your keyboard.
Hope this helps.
Mar 17, 2011 | BenQ MP510 DLP Projector
The problem with my projector is it keeps flashing green and red
hi,
your statement is not very specific but if the power led is flashing green and the lamp led is flashing red that indicates a fan failure.
contact optoma support here and enquire if you can have a warranty repair, or how much it may cost to have the fault fixed.
Feb 14, 2011 | Optoma HD65 DLP Projector
My projector will not power on. I've replaced the cables, the power source, and the bulb but still nothing. The red standby led on the control unit turns blue when power button is pressed but goes right...
The ballast unit has most likely failed. Replace the ballast unit, unless the lamp exploded and in which case, there may be glass fragments stopping a fan from turning.
Feb 03, 2011 | Optoma HD81 DLP Projector
Connection with laptop
1)Plug in either the vga or dvi into both the projector and the laptop.
2)Plug in the power cord to the projector,then turn the projector on.
3)Once it has past its warm-up period,find the function key on your laptop.(Fn)
4)Along the F1,F2,F3 ect keys,press find the one with the picture of the display.
5)When you have found it,hold down Fn and press the display key down until it clones the laptop and projector.
Jul 02, 2010 | Acer X1160 DLP Data Projector, 2,000 ANSI,...
How to start my projector when connected to laptop? '
Turn on the projector and laptop and connect the vga cord to the projector and the laptop (making sure there is a secure connection so it is tight but not overtight) and hold down function when your operating system has started (windows only mac is different) and press either F1 F2 F3 F4 or which ever one has the picture,icon, of the laptop and the external display.
Jul 05, 2009 | Acer PH530 DLP Projector
53 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
