Question about Grilling
The igniter came unplug from the knob on my Brinkman Gas grill, how do you get to it to plug it back in
  • 63 Answers
SOURCE: Igniter problem
right in front where the red botton pushs in to light! grab the ring around that and un screw it!
Posted on Apr 05, 2009
  • 10865 Answers
SOURCE: the gas flow cannot be raised and a slight breeze puts out the fl
The new gas grills have a safety device built into the gas hose that can cause this problem until you get familiar with it. The flame on a gas grill should be blue. If you have a yellow flame it could be caused by a couple of different problems. First of all the burner might be worn out. If you have an older grill then you should inspect the burner to make sure that there are no cracks or holes and that all the burner holes are the same size. If you have a newer grill or burner, or your burner appears to be fine then the problem might be with the regulator. The regulator is a round metal object near the connector to your gas supply. Sometimes regulators get stuck. This can reduce the gas flow, make a yellow flame and keep your grill from getting hot. To solve a stuck regulator, turn off the fuel supply to your grill. Disconnect the main connector and open the grills control value. This will eliminate any pressure on the regulator. Sometimes this will reset the regulator, but sometimes they stay stuck. Take a small hard object like the handle of a screwdriver and give the regulator a gentle tap. Now you can reconnect everything and see how your grill works now. If you still have a yellow flame your propane tank might be low, the regulator may need replacing or you could have a blockage in the venturi tubes. So check your fuel level by pouring hot, not boiling water down the side of the tank. Feel along the side where you poured the water. The propane level is where the tank feels cold. If you have plenty of fuel, locate the venturi tubes. The venturi tubes are located along fuel lines right behind the control valves. These allow air to mix with the fuel before reaching the burners so they have a small open space. If that space is blocked it will restrict the fuel flow to the burner. Make sure it is clear of obstruction. If you have done all this and still have a yellow flame you may need to look at replacing
Posted on May 29, 2009
  • 10865 Answers
SOURCE: Last summer closed up grill had no problems..today not working
unhook the tank and hook it up again being sure that the regulator is right side u p.
these new grills have a safety valve that often partially closes and causes problems.
Posted on Jun 24, 2009
bbmcdonald
  • 14 Answers
SOURCE: I have a brinkman gas grill model 810 8501 s and
First I have a couple of questions for your question on how ti fix your Brinkmann Gas Grill, Model 810-8501-S
1). Did you push the igniter for 3-5 seconds after you turned on the Sear Burner (remember, this needs to be done AFTER you've turned the control knob to HIGH).
2). Once the burner is lit, you then need to continue to PUSH & HOLD the control knob for another 30 seconds as this somehow seals the deal, thus this should solve the problem.
3). However, if this does NOT work, you may have a defective Sear Burner and the best thing to do is to contact the Customer Service Department over at Brinkmann:
* The Brinkmann Corporation
Attn: Customer Service
4215 McEwen Road
Dallas, TX 75244
Toll Free:
(800) 468-5252
Local:
(972) 716-4262
OR you may send them an email through this link:
http://brinkmann.net/Customer%20Service/ContactUs.aspx
Hope this helps!
Posted on May 30, 2010
bbmcdonald
  • 14 Answers
SOURCE: new brinkman gas grill---side burner lights on
I have a few ideas that might help.
1). Before going to the expanse of new parts, your igniter AA battery MAY need replacing.
2). Your igniter wires might be loose. Remove the battery and check junction box found behind the Control Panel and connect any loose wires.
3). Check that the end of each of your main burner tubes are properly located over the gas valve fitting.
4). There MAY be an obstruction over the main tubes not allowing the gas lines to access it properly.
5). If obstructions in the hose or regulatory assembly is suspected, it would be best to contact Brinkmann directly at 800-527-0717
Have brand new 810-3330-s brinkman grill main igniter is receiving no gas, is there a screw to adjust flame?
BEWARE: DO NOT TRY SUCH HAZARDOUS TRICKS YOURSELF AS LOCATING A SCREW TO ADJUST GAS PRESSURE. CONTACT THE DEALER OR AUTHORIZED CUSTOMER CARE.
Mar 29, 2014 | Brinkmann Brinkman Barbecue Grill Gas...
Brinkman grill 3 burner pro series 8300 won't
To restore gas to the burners, follow the instructions below.
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling.
Jul 04, 2011 | Brinkmann Grilling
BOUGHT A BRINKMANN 2545 GRILL LAST NIGHT. WE HAVE IT ATTACHED TO GAS LINE COMING FROM HOUSE. GRILL WILL LIGHT BUT IT IS A LITTLR FLAME AND THE OTHER BURNERS WILL NOT LIGHT?
If you have a high pressure 2lb LP Gas System feeding your house, you will need and inline regulator for you grill.
If you have Natural Gas, the grill will have to be converted to Natural Gas. You can do this by changing burner orifices. You can purchase them from Brinkman. That is, if Brinkman approves the change to Natural Gas. Some gas grills aren't convertible.
Feb 09, 2011 | Brinkmann Grilling
I need instruction on how to put together model 8300 proseries Brinkman
Click on this Brinkman link for the manual you need. Scroll down to the 6th Brinkman model listed to find your model and click on it. You can then download this adobe file and print it up on your computer for free.
http://www.brinkmann.net/Customer%20Service/OwnersList.aspx?category=Gas+Grills
Have fun assembling it!
May 15, 2010 | Grilling
Flame appearing from in back of front panel
This is usually a regulator problem, or a gas leak where the regulator line attaches to the back side of the knobs. Test for a gas leak first. You can use a mixture of water and liquid dish/hand soap. Saturate the area where the hose connection is, turn on the tank, but leave the knobs in the off position and do not hit the igniter. If there is a leak, you should see some bubbling where it is. If there is no leak, turn the tank off, open the valves (turn the grill knobs on) and bleed the gas out of the lines. Once it has sat for a few minutes with the knobs in the "high" position, turn them off. Then leave them off and turn on the tank, followed by one of the knobs and ignite the grill. see if the flame went away. I've seen this happen where there is not enough pressure in the line. Turning the tank off, the knobs on, bleeding the line, then closing the knobs and opening the tank and letting the gas build up pressure in the line before turning the knobs back on or trying to light the grill should resolve it.
May 11, 2010 | Char-Broil CharBroil Master Flame Gas...
I have a brinkman gas grill model 810 8501 s and the searer will not stay burning unless I hold the knob in. As soon as I let go of the gas knob the searer goes out. Any ideas on how to fix?
4215 McEwen Road
Dallas, TX 75244
Toll Free:
(800) 468-5252
Local:
(972) 716-4262
Hope this helps!
Apr 06, 2010 | Brinkmann Stainless Steel All-In-One Gas...
Can't get knob off of brinkman grill
Which knob ? Maybe try pulling it off really hard but without damaging it. Make sure you dont break any of the plastic. If it's still under warranty I would exchange it. I had to purchase 3 grills from Walmart to find one that wasnt bent !
Jul 04, 2009 | Brinkmann 810-2300-B Grill
New brinkman gas grill---side burner lights on ignition control but main burners do not light with ignition control---am able to match light the main burners----any ideas anybody
Clean or replace the main igniter. The backs corrode and need to be cleaned or replaced. Home Depot carry replacement parts.
Apr 25, 2009 | Grilling
Igniter problem
Apr 04, 2009 | Brinkmann 810-2300-B Grill
Grilling Logo
59 people viewed this question
Top Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
