Question about Cadco Ovens
Cadco oven will heat to low temperature but will not climb to actual set point
We have the set point at 356F but the oven will only get to 200F at best. The fan and motor are working. The heating elements are working. We are in manual mode.It's getting the correct power.
SOURCE: oven no heat
check fan element hasnt blown remove back plate in oven after switching off from mains of course and remove the retaining screws and you will see a fan and around that the element it will be obvious to see if its blown as there will be a hole on the casing if so replace and viola.
Posted on Feb 06, 2008
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    barkencoa
    • 3463 Answers
    SOURCE: smeg oven
    Sounds like you need a new oven element fitting.
    Posted on Dec 08, 2008
    • 3230 Answers
    SOURCE: GE JTP 1580W288 Set oven to Bake, switches to broil at bake temp
    The F2 Error code means the oven has detected an excess temperature condition. Most often this is due to a bad temperature sensor - the sensor costs about $75 from an online repair site.
    How to remove and replace the temperature sensor. In most GE ovens, when you open the door, you'll see the rod-shaped temperature sensor sticking out of the back wall at the upper left. It's about six inches long and a bit more than 1/8" in diameter, held in place with two screws.
    Turn off the circuit breaker (built-in ovens) or unplug the range before attempting the replacement.
    The replacement sensor will come with instructions, but basically it's a matter of removing the sensor, pulling out the wires to where they are connected and disconnecting them. You may have to snip. The replacement sensor will come with high-temp wire nuts to hold the new connection. Polarity doesn't matter; it's a straight resistance thermocouple. Hook it up, be sure you poke the connections back far enough so that they're on the other side of the thermal insulation and not resting against the back of the oven.
    If you continue getting the F2 error after replacing the sensor, then the problem is likely in the control module - this is the circuit board behind the keypad and clock.
    You'll need to remove the decorative bezel to get behind the control panel. Remove screws and set off parts in order - it's not complicated. Once the bezel is off there are two more screws that hold the panel in place. Then you can lift the panel up about a half inch and pivot it forward toward you. You'll see a bunch of wires going to a circuit board.
    On the panel you will notice some black plastic boxes that say "Potter & Brumfield" on them. These are relays. Check the relays - slide the black plastic cover straight up to expose the coil and the contacts. The coil, when energized, closes the contacts - look at all the relays. You can manually close the contacts with your finger (be gentle). If the contacts of one of them are stuck, they might be welded together. You can fix the problem by prying apart the welded contacts gently with a knife blade. Take some time to gently polish the relay contacts with a folded bit of fine grain sandpaper - this will get some more life out of them. Be gentle and careful - the relays aren't complicated but if you bend the contact or rip it out, you'll have to replace the controller, which will set you back a couple hundred dollars. If you unstick and burnish the relays, they will probably eventually weld together again as the rough spot will spark, but when you burnish them with sandpaper they should be good for some more life before they need to be replaced.
    If the problem isn't the temp sensor or welded relay contacts then the problem is obviously somewhere else, but temp sensor and relay contacts will account for the lion's share of F2 errors.
    Once again, be safe, be careful, be gentle. Ovens are not very complicated and they're tough, but always exercise care. Always disconnect electricity before messing with them.
    good luck,
    Posted on Jun 28, 2009
    • 291 Answers
    SOURCE: Oven doesn't reach temperature setting
    It could be the plug/receptacle that the element plugs into. It could also be that the elements have separate thermostats and that the one for the lower element is bad. If you can post the model number I can look at the electrical schematic and know for sure if it has one or two thermostats.
    Posted on Aug 31, 2009
    Cadco oven wont start ...give error code pre and por
    It looks like the controller board is shot. Get on the web with Cadco and request a complete parts list for the controller circuits. Meanwhile, pull the cover off the stove controls and blow in clean, dry compressed air over the circuit boards. Chances are you have a short or two in the circuitry!
    Dec 15, 2012 | Cadco Ovens
    Need to glue outer cold glass door to the door frame.. in cadco convection oven
    not sure which to use but id go to a window auto glass shop and inquire
    Dec 12, 2012 | Cadco Ovens
    The oven is not reaching its correct temperature.
    This type of problem normally can be ascribed to a defective thermostat. Unfortunately there is no test for a thermostat, it has to be replaced to see if the problem has been sorted out.
    One thing you can do is remove the thermostat bulb from the oven and place place it in a position where it will not heat up. Place an oven thermometer in the oven. Switch on and see of the temperature climbs above what you wee seeing before. This is a very much hands on test as you have no control over the temperature that the elements can get to. As soon as you see the temperature reach a point above that seen before, shut down immediately.
    Apr 12, 2011 | Tecnik Ovens
    Bosch built in double oven: had new element fitted to main fan oven, but now oven keeps on getting hotter does not stop heating up when right temp reached.
    Mar 27, 2011 | Bosch Ovens
    My Fisher and Paykel Aerotech OS302 oven will not heat up to desired temperature.
    Feb 06, 2011 | Fisher and Paykel AeroTech OS302 Electric...
    The oven temperature isn't correct. Ovenw Won't heat up.
    has the oven got a fan on it. if so then maybe fan is faulty.
    if convection oven then maybe one of elements is faulty
    or the thermostat is a problem
    regards
    richard saupe
    Appliance repairman colchester
    appliance repairman
    Mar 14, 2010 | GE Profile JT915 Electric Single Oven
    My GE wall oven will come on and heat up but shut off early. No codes, it just climbs to an incorrect (low) temp and shut off-Maybe the sesor?
    HI, You will need to check the oven sensor wires that link the actual sensor to the main control board. Make sure that the contacts are connected properly, and not loose, or corroded. If all the wiring checks out, test the sensor for the correct resistance readings.(you will need a multimeter for this test)
    The most common oven sensor should be approximately, 1100 ohms when at room temperature. The others may be close to as follows:
    100°F - 1143 ohms
    200°F - 1350 ohms
    300°F - 1553 ohms
    350°F - 1654 ohms
    400°F - 1753 ohms
    500°F - 1949 ohms
    If the sensor test is adequate, and the wiring is Ok at the control, this will lead to a failed control board. replace the control in this case.
    Oct 28, 2009 | Ovens
    Cadco unox Mod XAF193
    You can order the XC605 "air reduction kit" from the manufacturer catalogue.
    Oct 16, 2008 | Cadco Ovens
    Ovens Logo
    37 people viewed this question
    Top Cadco Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you a Cadco Oven Expert? Answer questions, earn points and help others
