Question about The Computers & Internet
Can I make the patterns on my craftorium romance USB bigger if so how mandy x
Instructions for Simplicity 1716 Pattern
you should be able to set your printer to print in bigger letters.
Nov 30, 2016 | Office Equipment & Supplies
Can I transfer pattern on the laptop to my sewing machine?
First the design has to be a file that is compatible with your machine, then you put it onto a USB stick and then put it into your machine. also design can be no bigger than your largest hoop. You will not hurt your machine, it will not be readable if it is not the right type of file. Janome machine requires a jef file OK
Good Luck
Sep 30, 2014 | Sewing Machines
Could tell me how to replace my old keyboard with the new one on my ASUS X58L Laptop..Thank you in anticipation. Mandy Jean Cole
Hi, you have to consult a computer repair shop.
As it is difficult item to change.
It does not cost so much.
My guess is 200 to 300 dollars.
Or you can buy a usb keyboard plug it in the usb port
and you can type on that ( just a suggestion )
Hope this was help full
Aug 17, 2011 | Computers & Internet
How do i upload photos from Olympus 7030 onto computer
Hi Mandy, if you have USB data cable then connect the cable with Camera between PC. Then turn on your camera and select USB connection (Optional). Then open My computer you find new device there. Just open that and copy the folder to Desktop.
Mar 06, 2011 | Olympus Stylus 7030 Digital Camera
Is the bell housing bolt pattern on a 1980 Ford escort the same as a cortina gearbox?
Yes, the splines are bigger on the 1.6 and up gearboxes on both the input and output shafts
May 30, 2009 | 1983 Ford Escort Gt
Niokia 5140i
try this code many 12345 if its not working that means ur phone shud be unlocked so it can work with all other crrairs 100% u r trying to use another carrier
plz do rate this post as good as u can mandy
Oct 18, 2008 | Nokia 5140i Cellular Phone
Computers & Internet Logo
24 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
