Replacing the beveled gears in the hydraulic pump of a 1989 2090 Case tractor can be a complex task, and it is recommended that you consult the service manual for your specific tractor model before attempting the repair. However, here is a general guide on how to change out the beveled gears in the pump:
- Begin by draining the hydraulic oil from the pump and removing the pump from the tractor. This will likely involve disconnecting hoses, fittings, and any other attachments that are holding the pump in place.
- Once the pump is removed, you will need to disassemble it. This will involve removing the bolts and covers that are holding the pump together.
- Once the pump is disassembled, you will have access to the beveled gears. Carefully remove the old gears, being sure to note their orientation and position.
- Clean all parts thoroughly, including the gear housing, gears, and any other components.
- Install the new beveled gears, making sure that they are properly oriented and seated in their proper position.
- Reassemble the pump, making sure that all components are properly aligned and tightened.
- Reinstall the pump onto the tractor, reattaching all hoses, fittings, and other attachments.
- Refill the hydraulic system with the appropriate oil and test the pump to ensure that it is working properly.
Again, this is a general guide, and the specific steps involved in replacing the beveled gears in the hydraulic pump of a 1989 2090 Case tractor may vary depending on the specific model and condition of the pump. It is recommended that you consult the service manual for your tractor and/or seek the assistance of a qualified mechanic if you are unsure about any aspect of this repair.
