Question about Sony Cameras
What is wrong with my sony camera when it says unable to use card
Sony DSLR A 100 camera
    Sergeant:
  • 283 Answers
Try a different card.
Posted on Apr 28, 2017
Sony DSLR-A100 eroor 0x58
Well, the good news is that there's probably no fault with the camera itself. It could be something as simple as the CF card being pushed in the wrong way. A look through the user manual will likely help you get to the bottom of your issue:
Sony Alpha DSLR A100 manual
Aug 13, 2014 | Sony Alpha DSLR-A100 Digital Camera
Alpha DSLR-A100 Digital Camera: i got problem with memory card. keep showing the m...
not all memory cards fit sony alpha perhaps you have bought wrong cd.try using your sd slot
May 06, 2010 | Sony Alpha DSLR-A100 Digital Camera
Sony dslr a200 camera error
Couple of things to try: 1. If you've downloaded the pics from your memory card, format it in the camera. 2. Go into the menu and scroll to "reset"...follow the on-screen instructions. 3. Remove the card and battery...press all the buttons..leave it alone for 20 minutes...insert the card and then the battery...turn it on.
Nov 25, 2009 | Sony Alpha DSLR-A200K Digital Camera
I have had my sony for about 2 years and suddenly last night while shooting pictures, the message "unable to format card" appeared on my screen - what can I do?
It's just the memory card. This error message comes up when the card sustains damage to any degree. Did you lend your camera or card to anyone or put the card into the wrong reading drive by accident? It may be time for a new memory card/stick. Exchange it if it's still under warranty.
Jun 07, 2009 | Sony Alpha DSLR-A100 Digital Camera
What do i do when I turn on my sony alpha 100 and it tells me unable to use but I formatted it and it still says unable to use???
It's most likely a problem with the memory card. This message comes up when the card sustains damage to any degree. Did you lend your camera or card to anyone or put the card into the wrong reading drive by accident? It may be time for a new memory card/stick. Exchange it if it's still under warranty.
Jun 06, 2009 | Sony Alpha DSLR-A100 Digital Camera
Sony A100:put in empty CF cards, says card full, won't format
Might be 2GB card is more then enough for camera hardware o handle. Try 1GB card in this camera.
Mar 15, 2009 | Sony DSLR-A100 K Digital SLRCamera Digital...
Sony Alpha 100 gives error message when attempting to take pic.
Hi! I just had the same problem with my Sony A100, when I tried two different CF cards. I was getting the same error message as reported above: "Unable to use card" then "Format?" then that format fails. Thinking the camera is broken, I checked online camera repair sites and also called Sony directly. Sony's flat rate, and that of PrecisionCamera is $228 to fix CF card failure. Then my daughter said, "the CF card in my room works fine in the camera" - and lo and behold - it does. The CF card that works is brand PQI and is marked Hi-Speed 60 2Gb. The cards that do NOT work are marked SanDisk Ultra II 1.0Gb and SanDisk 128 Mb. So my advice is, before you give up on the camera as broken, try a number of different CF cards first.
The second cause of CF failure is if someone has pushed a CF card in the wrong way. That can bend one or more of the tiny metal contact pins in the CF socket in the camera. Look carefully to see that all the pins are straight up. [I don't know how one can straighten these pins, or if the whole socket would need to be replaced...but at least you can determine the cause of the CF failure.]
Best regards - Michael
Jan 07, 2009 | Sony Alpha DSLR-A100 Digital Camera
I can't format any memory card (CF) with my Sony Alpha 100
you have a lock on your memory card check that !!
Jan 03, 2009 | Cameras
Cf card reader sony a 100 dslr
Buy a camera that does not use CF. Time to upgrade.
Nov 12, 2008 | Sony Alpha DSLR-A100 Digital Camera
Sony DSLR a 100 driver for PC
You can get it from the sony web site.
Oct 22, 2008 | Sony Alpha DSLR-A100 Digital Camera
Cameras Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
