Question about RCA Televison & Video
I have an old rca tv model number f36689 that will not come on. I hear a pop sound an it went out. Is it the fuse, if so what fuse do I need to get. If not that then what is the problem?
  • 236 Answers
SOURCE: RCA 32 in TV no picture no sound just a beeping noise TV power is on
You have a bad flyback transformer and shorted horizontal output transistor. Your set would have to be taken to a shop to have these parts replaced. Stargazer
Posted on Aug 10, 2007
I have a problem
Posted on Aug 11, 2008
my 36" rca green light blinks 3 times, no picture or sound
Posted on Jun 02, 2009
  • 6 Answers
SOURCE: "I need to program an old Panasonic TV with a RCA universal remote model RCR311St Help""I need to program an old Panasonic TV with a RCA universal remote model RCR311St Help"
Code For Model RCR311S Code 1003 for Panasonic TV Code 1054 for Panasonic TV Code 1062 for Panasonic TV Code 1109 for Panasonic TV Code 1170 for Panasonic TV Code 1248 for Panasonic TV GOOD LUCK THESE ARE THE CODES LISTED FOR YOUR REMOTE/
Posted on Jun 03, 2009
  • 335 Answers
SOURCE: 42'' lcd turns on no picture/menu
Your tv is being attacked by electrical surges which seem very violent and has already damaged some logic controls. Please invest in a AC filter which will protect your tv from such spikes....... but first you need to get your tv serviced from the electrical damaged it has already suffered.
Posted on Nov 03, 2009
Lightening stroke and my tv went blank. i open it and found the fuse blown change the fuse but heard a pack sound coming out of the largest capacitor
It simply means it is not only the fuse that needs replacement.
The capacitor is also faulty and needs replacement. Once lightning hits a device, its quite a number of components that will get burnt so replacing the board will do the work.
Also check the tips of the capacitor on the other side to see if the lead on it has not melted off causing the capacitor to be having a bridge.
Take care and good luck
Oct 11, 2010 | RCA F36689 36" TV
RCA F36689 when I turn on ,Cuts off, then back on then off
Possible bad IHVT or bad solder connects....T.
Dec 10, 2008 | RCA F36689 36" TV
RCA 52 inch
three strikes and it's out... rca does this, it is just showing it has tried 3 times for you and untill it is unplugged it won't try again.. you need to provide model #.. could be a few different things
hissing usually meens you have high voltage...that's good but then what don't you have?
ctc 169 - 179 could be high voltage divider... need more info
Oct 17, 2008 | RCA R52WH73 Projection Television
Rca d52130 herd pop tv went dead
dear friend your tv has a defective fly-back transformer 99 times out of 100 that is your problem.
get the model number and call your local electronics parts distribuitor to see if they have it, if not call tritronics 1800-638-3328 they probably have it and is not too expensive.less than $ when you get here is the million dollar question can you do it yourself? if you can't call the repairman and by having the fly-back that will decrese the cost of the repair, is just the labor.
good luck
Sep 02, 2008 | RCA D52130 52" Rear Projection Television
No , if fuse was blown you would not get the popping. How old is unit ? It sounds like your high volt splitter. common problem with rca. repair should not cost more than 250.00. you will want to have chassis number  and manu date for help
Jun 04, 2008 | RCA P52937 52" Rear Projection Television
TV has sound but no picture RCA ColorTrak 2000 P52150CP
If I had a model # it would be helpful but my guess is the deflection circuit failed and a fuse opened in that circuit. Could be vertical or hoizontal circuit failure but either way you will need test equip. as well as solder/desolder equip. to repair it. If set is over 10-12 years old you may consider replacing set in this case Sorry I can't be more help.
Jun 02, 2008 | Televison & Video
RCA Projection TV
that would be the inverter board, supplies power to the bulb, you would need to replace this part, but don't touch the board without wearing rubber gloves, as it can store a lot of voltage when they fail . when you get the board out discharge the capacitors to make it safe. cross the live and negative on the capacitors.
Jul 08, 2017 | RCA Televison & Video
Televison & Video Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
