Question about Hisense Televison & Video
Pls help how do u remove usb features on hisense tv without remote cuz its stucked now pls help
SOURCE: remote problem Hisense
I GOT A NEW HD WIDESCREEM POLAROID. DIRECTTV CONTROL PUTS ON POWER ON TV,CHANGES CHANNELS BUT DOES NOT CONTROL VOLUME NOR CONTROL DVD ANDVCR PLEASE HELP GODWIN
Posted on Jan 22, 2008
IrishDruid
  • 2712 Answers
SOURCE: hisense remote does not work with hisense tv
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
PABLOCSA
  • 1124 Answers
SOURCE: Hisense Remote
Use the "auto search" method to program the remote and it found a code on its own and get your tv unlocked. Try using 0478 code
Posted on Oct 17, 2008
marked
  • 6487 Answers
SOURCE: hisense tv
Try this code 142, inform us for any updates.....
Posted on Oct 23, 2008
  • 133 Answers
SOURCE: Panasonic PT-53WX42F-Stuck in Zoom mode
on the bottom left side of your dish remote, there should be a button that says format, that should help you
Posted on Jan 08, 2009
How do you turn up the volume on hisense ledn32d33 without a remote
See if the set has volume controls on it. Some sets have a power switch and volume/channel controls on them.
May 29, 2016 | Hisense Televison & Video
Hisense tv
so whats the remote you have there?
Oct 23, 2008 | Hisense TA42P40M 42 in. Plasma Television
I got it on photo mode but don't have remote to switch how do I put it back to TV mode without it Its a vizo model va26lhdtv10t
[PDF]USER MANUAL - Newegg.com
images10.newegg.com/User-Manual/User_Manual_89-262-370.pdf
To get the most out of your new VIZIO product, read these instructions ..... WIDE.Switch the display mode. MUTE. Turn the audio off or on. BACK. Go to the ...
How to Fix the Most Annoying Features of Your New HDTV ...www.wired.com/2014/12/hdtv-setup/WiredDec 25, 2014 - You don't need to get your set professionally calibrated to improve itspicture quality. ... That "Showroom" or "Demo" mode is made to make your TV stand out ... All right, you have your picture just perfect-or good enough to kick back and ...Do you have an HD cable box, but the picture you're seeing is still ...hisense stuck in usb mode - YouTube? 1:30https://www.youtube.com/watch?v=FZ6YS3zjf_wJul 23, 2014 - Uploaded by Michael GregoryThis video shows how to get your TV out of USB mode without aremote. ... Don't like this video ...
Jan 02, 2016 | Televison & Video
Tengo un control Rca Universal y necesito los codigos oara una tv Hisense.
If you have a universal remote, you can use its code search feature to seek a suitable code for your Hisense TV. If you search through all codes stored in the remote without success, you may have to try another programmable remote.
Oct 07, 2014 | RCA Universal Remote Control
The GUIDE button on the remote (model EN-33926A) for a Hisense 55K610GWN does not work
my children messed around with the remote and now i can turn the tv on from the actual tv but from the remote when i press channel up or down or hdmi buttons it turns the tv of.. remote model en-33926a
Dec 19, 2013 | Hisense Televison & Video
Sound goes to maximum by itself
Check your remote just to make sure you don't have a stuck button. Check the buttons on the TV as well. If they look ok, then you most likely have a bad Keyboard on the TV
Apr 10, 2012 | Hisense TL2620 26 in. LCD Television
Programming remote to hisense tv model # LCD1504US
Cable remotes and TV remotes often are incompatible.
Sep 27, 2017 | Hisense LCD1504 15 in. Television
Universal remote wont work on hisense tv TC 1828E
You may have to try a different universal remote control. All universal remote controls do not contain all possible codes.
Nov 26, 2017 | Televison & Video
Televison & Video Logo
21 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
