Question about Garden
What spark plug do I use on a Trim rite 453 edger and what would the gap be?
  • 76 Answers
SOURCE: What should the spark plug gap be set at for a
see manual
the gap should be 0.030
Posted on Jul 17, 2009
  • 76 Answers
SOURCE: What is the spark plug gap for a craftman edger?
see the link
see page 10
should be 0.030
  • 718 Answers
SOURCE: craftsman edger has never started. I've got good
This has got to be the first case I have seen where all the ducks are in a row and you just have some real bad luck! First thing has it been sitting around with fuel in it for a long time if yes your carb is clogged it needs to be cleaned thoroughly. Is your fuel to oil ratio correct and did you double check gap amount for this machine. Try this and see what happens. Good luck let me hear about it.
Posted on Oct 19, 2009
  • 7 Answers
SOURCE: troy-bilt gas edger trencher won't start. Spark
Remove spark plug and pour 5mls or one teaspoon of premixed gas in the engine. Depress trottle to full with choke on "run", pull starter about 10 to 12 times If it starts and run for a while and then shuts off your carb needs servicing. If not remove muffler and look for a spark arrestor screen. This could be plugged up with soot. If it is, replace and this would have been your problem. While the muffler is off slowly pull starter rope and examine the piston if gas and oil oozes backwards as the piston moves to the top then the piston and rings need replacing.
Posted on Nov 10, 2009
  • 144 Answers
SOURCE: my homelite trim n edger
Hi cookinmechan. I will try to help out. Did you check the air filter to be sure it is clean? It could be the fuel tank vent that is located in the tank cap. Air should be able to go in and nothing should be able to come out, making it difficult for the carb fuel pump to bring the fuel to carb. Check the fuel lines for any cracks or degragation that could be plugging them. The carburator might need cleaning and new carb kit. There is a fine mesh filter in the carb that needs to be cleaned or replaced. That is a common problem with this type of carb. There could also be an air leak so you might want to check the screws and bolts for proper torque to make sure that doesn't happen. Is there a primer on the carb? Make sure it is working and hasn't come hard so that it doesn't pump enough gas to help start engine. Something that most people and some mechanics don't look at is carbon build up in the exhaust port making it difficult for exhaust. Remove the muffler and look for carbon build up. Sometimes there is not much of an opening for proper exhaust. To clean, bring piston to top dead center and get a piece of wood or plastic to scrape out carbon. Do not use any type of metal so no damage is done to piston or cylinder wall. I hope this helps you out a bit. All the best and good luck. Questions welcome.
Posted on Feb 10, 2011
316.79108. What is the proper gap for the sparkplug?
The gaps are 99% preset... Get a E3 spark plug, they cover multiple part number plugs. For example, if you have a BPMR6Y, a BPMR7Y, RCJ6, etc, one of the E3 plugs will cover them all and will already be gapped accordingly. If your equipment isn't running smoothly, it's most definitely not the gap of the plug... unless you're working on a pre 95 vehicle.
Oct 03, 2015 | Craftsman Weed Wacker Lawn Edgers
What is spark plug gap settings for a toro tb22ec trimmer
You don't have to gap the plugs on 2 cycle and 4 cycle equipment. They are already pregapped. Look at the part number of the plug and go get yourself an E3 brand plug which covers multiple plug plugs on the market.
Sep 28, 2015 | Toro Garden
Wat is the spark plug gap fo 50hp mercury two stoke 2009
The plug gap is most likely .040, however can you please confirm your serial number?
Sep 10, 2014 | Mercury Force Tilt Trim Motor, 25-50 HP...
Bosch spark plug gap for a fs46 weeteater
Stihl recommend 0.020 (20 thousands of an inch) or 0.5 mm. Incidentally the plug gap is independent of the plug make.
Jacko from down under
Aug 15, 2014 | Stihl Km 38 45 46 55 Trimmer Clutch Drum
What is the spark plug gap for a Ryobi string trimmer model RY30550 ?
No need to gap from a new spark plug unless the plug was dropped on the electrode.
May 02, 2014 | Ryobi Garden
How to get the right gap for a spark plug
you can just call the auto parts store and the can tell you the gap for your spark plugs for that car, and buy a spark plug gaper from auto parts store and check them/ set them also, but mosy plugs come already gaped from the store
Dec 10, 2011 | 2002 Lincoln LS
Rough idle- code reader - multiple misfires after replacing- plugs - spark plug wires- rotor -distributor cap- filters
do u hav the wires on the rite plugs-crosses are common--are plugs gapped rite--get a haynes manual for problems--dirty idle valve questionable
Dec 15, 2010 | 1998 GMC Jimmy
Spark plug gap
What plug are you currently using?
if its a DJ7Y gap at 0.025 tapered seat
if its a DJ7J gap at 0.030 tapered seat
if its a CJ8 gap at 0.025 gasket
if its aCJ6Y gap at0.030 gasket
if its a CJ6 gap at 0.030 gasket
these are champion plugs
if you have different cross reference your make
Jul 05, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
