Question about Banner Office Equipment & Supplies
DGI BANNER PRINTER MACHINE MODEL NO DGI X-3204T
I have one dgi xp 3204t machine. my machine problem is do not take size.. screened display erorr paper size... how to solve this prblem
Hello, I have DGI XP-3204T machine, the problem is while printing, it starts on a good note but after completing approx 40-50% of printing firing of the ink gradually decreases, as a results lines are visible.Suggestions would be appreciated.
Apr 21, 2014 | Office Equipment & Supplies
Epson WF - 7520
My EPSON 7520 printer can't print the 1m banner I buy for that purpose, it's new, I design the banner & set up to print, before print when I check for preview it's divided for 4 portion. how can I fixe it? the last size the printer it takes 27cm * 42cm long, but I need to print 27cm * 100cm what can I do? I need help.
Jul 07, 2013 | Office Equipment & Supplies
How do i solve servo motor high error in solvent printer
Please follow the steps below to hard reset the printer and let me know the result.
1.Remove all the cables from the printer.
2.Wait for 10 mins.
3.Connect only the power cord and try to power on the printer.
4.If the problem is solved, then connect all other cables, otherwise let me know.
Aug 28, 2012 | Office Equipment & Supplies
Konica Minolta C351: stop Banner Mode?
this problem can be remove by upgrading its firmware. ask your technician to upgrade the firmware of the machine.dont replace the board. try this.
Apr 02, 2010 | Konica Minolta bizhub C351 All-In-One...
My lexmark X5495 always prints banner
Not sure which OS, you're using, but try this:
Go to Start > Printers > right-click your PDF printer and go to Properties
Go to Printing Preferences and ensure in all possible locations there that you don't have "banner" selected.
Jan 02, 2009 | Lexmark X5470 All-In-One InkJet Printer
Default page
You did not list the model number, but usually you go to Start>Settings>Printers and Faxes and right click on the Xerox Printer and choose properties. Go to the ADVANCED tab and choose Printing Defaults. Now look at the Advanced tab in this window and select Paper/Output. Look for Banner sheet and choose disable. Apply and save and exit.
Nov 05, 2008 | HP Photosmart C7280 Laser Printer
Printing problem
ISSUE: A blank page prints after every print job using an HP LaserJet series printer. SOLUTION: A separator page may be turned on in the printer driver, within the application, or on the network. Try printing from several applications. If a page prints out in only one application, that application may have a summary page selected to print out. If a page prints out from different applications, a separator page may be turned on in Windows or on the network. Use the following sections to turn off separator pages. Windows 95/98/Me Follow these steps to turn off the separator page in Windows 95/98/Me:
  1. Select Start .
  2. Select Settings .
  3. Select Printers .
  4. Highlight the appropriate HP LaserJet printer icon.
  5. Select File .
  6. Select Properties .
  7. In the section labeled Separator Page, select None .
  8. Click Apply .
  9. Click OK .
Windows NT 4.0/2000 Follow these steps to turn off the separator page in Windows NT4.0/2000
  1. Select Start .
  5. Select File .
  7. In the Advanced tab, select the Separator Page button.
  8. Delete the location for the separator page.
  9. Select OK .
Windows XP Follow these steps to turn off the separator page in Windows NT4.0/2000
  1. Select Start .
  3. Select Printers and Faxes .
  5. Right-click on the highlighted printer icon and select Properties from the Advanced tab.
  6. In the Advanced tab, select the Separator Page button.
  7. Delete the location for the separator page.
  8. Select OK .
Software or applications See documentation for the specific application that is printing a separator page. The following steps are an example of how to turn off the summary page in Microsoft(R) Word 97:
  1. Open Word 97 .
  2. Select File .
  3. Select Print .
  4. Select Options .
  5. Deselect Document Properties in the Include with Document section.
  6. Select OK .
Novell environments Banner pages can be sent to the printer in several different ways in a Novell environment. The following instructions detail several ways to disable the banner page. NOTE: Banner pages can also be sent from the HP Jetdirect device itself. This page can be enabled and disabled through a telnet session to the HP Jetdirect device. The telnet banner will only print in an lpd/unix ® environment. Novell's Capture Command To disable a banner page using a Novell DOS capture command at a system prompt, type the following commands: capture L=x Q=queuename NFF NB NT TI=x where:
  • L = x -- The value of x would be 1, 2 or 3 depending on the lpt port being used.
  • Q = queuename - The value of the queuename would be the Novell queue setup for this printer.
  • NFF -- No form feed.
  • NB -- No Banner.
  • NT -- No Tabs
  • TI = x -- The value of x would be the timeout amount in seconds. NOTE: If the client workstation is restarted, and if a capture command is part of a login script that is being used, these settings will be reset.
Printer Properties The banner page for Novell networks can also be enabled or disabled in the Printer Properties using the following steps:
  1. To open the Printers Folder ; click Start , Settings, and Printers .
  2. Right-click the appropriate HP LaserJet printer icon and select Properties .
  3. Select the Printer Settings , or Capture Settings tab. The banner page can be enabled or disabled here.
NetWare Clients Follow these steps to disable the banner page for Novell NetWare clients:
  1. Right-click Network Neighborhood and select Properties .
  2. Select the Configuration tab in the Network window.
  3. Highlight Novell NetWare Client and select Properties .
  4. Select the Default Capture tab. The banner can be enabled or disabled here.
Feb 23, 2008 | HP LaserJet 1010 Printer
Banner Printing
Hi Thank you so much for the best information wth banner design. i got my banner design method on here http://www.thewebpole.com/ @ from the domain name processing, with the free services of hosting, and mosr services like, * Photo Album
* Quick Blogcast
* Hosting with site builder
* Personalized Email Account
* Starter Web Page
* "For Sale" Page
* Parked Page w/ Domain
* Domain Forwarding & Masking
* 100-Pack Email Forwarding
* Total DNS Control
* Change of Registration
* Status Alerts
* Domain Locking
Jun 18, 2007 | HP Deskjet 6940dt InkJet Photo Printer
24 people viewed this question
Top Banner Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Banner Office Equipment and Supply Expert? Answer questions, earn points and help others
